Hung Isdn Ports / Random Drop Calls
SYSTEM CONFIGURATION
System Windows 2000 - Service Pack 4
VoiceGuide 6.0.1047 VG Dialer 30 lines licenses
Dialogic PCI D/300-E1
Dialogic DCM 5.0 Build 2195 Service PAck 4 / Release SR. 5.1.1 Version DNAS Build30
E1 connected to a class 4 switch with EuroIsdn link. Calls are working fine, but
after some hours, ports are hung on the IVR. In ocassions calls are drop in the middle of a prompt. PRoblem is resolved resetting (only) the PC server.
is it needed any sw upgrade?
any suggestion?
Note: After the system comes up, we have tested it all the channels and it works fine, but after some time and calls the environment starts to be tricky.
Are you using the SR5.1.1 Service Pack 1?
In what state are the ports when you consider them 'Hung'? Is something unexpected shown on the screen or is there some other indication? Please post a screenshot if appropriate.
