Error While Setting A Perion For Current Time
Hello
I m using VG version 6.0.2027.
When i tried to set a period with contains current time, on save it shows following error.
201753.73 0 ERROR 6.0.2027 MemStructVgm_ClearVgm err[Type mismatch]
201753.75 0 ERROR 6.0.2027 MemStructVgm_ClearVgm err[Type mismatch]
and when make a phone call, it shows
"Hanging up the call fail/False path not defined."
210330.59 1 ERROR 6.0.2027 TW__LineEvCallState_Error:Subscript out of range
What could be the reason.
thanks in advance
Muhammad Waseem
Could you please post a copy of VoiceGuide's Debug Printout which captures the problem outgoing call, this will allow us to see what happened.
The log files would be saved in \log\ directory as well.
hello,
let me explain some more about the case.
Before it was working fine, but now i have instaled the system on a new machine.
if no period falls in current time, then application works fine. But when a period fals in current time, it gives an error and shows
"Hanging up line : Fail/False path not define " in VG window and only one line error in erroe log that is
"134807.73 1 ERROR 6.0.2027 TW__LineEvCallState_Error:Subscript out of range"
and at the user end it shows system is not receving cal or not picking up the lines.
continuous bell rings on.
waiting........
Please set the trace level to 8 and restart VG and reproduce the error, and then post the trace again.
Trace should then show enough info to let us see what is happening.
Hello, i have solved this problem, but now i m facing some other problem.
I have two boards in my machine for 8 lines as total.
i have configured "line 1" as incoming and "line 2" as out bound.
system tries to amke a call for telephonic conference but it generates the following error
system tries to make a conference but fails, what could be the reason.
thanks
Error8.txt
Trace shows that no number was specified to be dialed - so the line is effectively picked up and after 17 seconds the busy tone is heard on it - and then the script goes down the 'busy' path...
183119.56  1 state [Calling Specialist] Monitored Dial and Connect to
183119.58  0 Search for free lines in list [2] in LineID range [0-8]
183119.58  1 dial  busy: active call
183119.58  2 dial  reserving: found in comma delimited id list [,2,]
183119.58  1      no on-hold file specified to play
183119.59  2 state dialing    (for conference with dxxxB1C1)
183119.59  2      lineMakeCall(,DX_PAMDOPTEN) => 0
183119.61  2      call progress option selected: Voice or Answering Machine is detected. Listen for disconnect tones. (DX_PAMDOPTEN)
183119.61  1 timer set 3600  EV_TIMEOUT_HANGUP
183119.61  2 timer set 3600  EV_TIMEOUT_HANGUP
183120.14  2 tw    DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
183120.14  2 event TDX_SETHOOK, code=135, state=1922
183120.16  2      LsXfer_6_dc_WaitOutcomeOutgoingCall_DialingSide : 135,[TDX_SETHOOK],0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
183120.16  1      LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 135,[TDX_SETHOOK],0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
183120.16  1      LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 135(EV_UNKNOWN_135),TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
183120.16  1      path {tdx_sethook} not found
183137.89  2 tw    DialogicEvent 133,TDX_CALLP,7,0,0,CR_BUSY,,
183137.89  2 event BUSY, code=133, state=1922
183137.91  2      LsXfer_6_dc_WaitOutcomeOutgoingCall_DialingSide : 133,[bUSY],7,0,0,CR_BUSY,,
183137.91  1      LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 133,[bUSY],7,0,0,CR_BUSY,,
183137.91  1      LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 133(EV_UNKNOWN_133),BUSY,7,0,0,CR_BUSY,,
183137.92  1      TsReset as event indicates 2nd leg did not connect.
183137.94  1      going down path for trigger string  {busy}
