Interupted Call Cause Future Call Hangups
I can run my script just fine but if someone hangs up in the middle of the script all future calls just hang up. It almost looks like the wave file is allocated to the first call, and then never gets deallocated. Is that what is happening here?
Can someone tell me how to fix this?
This is the log of the successfull call and then the hangup.
055136.43 0 ApiMode=[TAPI]
055136.62 0 Tapi device 5 is: H323 Line
055136.66 0 Tapi device 4 is: IPCONF LINE
055136.70 0 Tapi device 3 is: LPT1T
055136.74 0 Tapi device 2 is: WAN Miniport (L2TP)
055136.81 0 Tapi device 1 is: RAS VPN Line 0
055136.84 0 Tapi device 0 is: SmartUSB56 Voice Modem
055137.20 0 init vgmulti ver 5.2.3063
055137.38 0 Inband Signaling Config file not specified
055137.49 0 Loading VMB data begin
055137.51 0 Loading VMB data - about to delete old entries
055137.54 0 vm sort start on 8 entries.
055137.55 0 vm sort end.
055137.56 0 Loading VMB data end
055140.73 0 dial start any summary:|0:ivd<0|
055140.76 0 init clear settings on 1 devices.
055140.90 0 Initialising...
055140.91 0 init attach vgs on 1 devices.
055140.92 0 Script Load C:\Program Files\VoiceGuide\Scripts\dbtest\dbtest.vgs
055141.14 0 init lineopen on 1 devices.
055141.15 0 Calling .lineOpen on device 1
055142.72 0 lineOpen(0)=>
055142.73 0 Calling .GetLineHandle on LineId 0
055142.74 0 hLine=66286
055142.85 0 Calling .GetProviderInfo on LineId 0
055142.92 0 tapi ProviderInfo: Windows Telephony Service Provider for Universal Modem Driver
055142.93 0 set provider type: PROVTYPE_MODEM
055142.94 0 Calling lineSetNumRings on lLineHandle 66286
055142.96 0 Waiting for a call...
055144.22 0 dial start any summary:|0:idx=0|
055153.52 0 callstate OFFERING 66235 0 4
055153.70 0 ring 1
055154.38 0 dial start any summary:|0:hc>0|
055159.47 0 ring 2
055159.48 0 rv clear
055159.51 0 Answer the call at 6/28/2005 5:51:59 AM
055159.52 0 lineAnswer(66235) => 66218
055159.54 0 callstate ACCEPTED 66235 0 0
055159.68 0 tapi Reply (LineEvReply) ok 66218 0
055159.77 0 callstate CONNECTED 66235 0 0
055159.78 0 callstate CONNECTED 66235,0,0
055159.79 0 WorkingModeTAPI@Connected=
055159.81 0 WorkingModeScript@Connected=
055159.83 0 Inband detection not enabled
055159.84 0 StartLoadedVgs at 6/28/2005 5:51:59 AM, v5.2.3063
055159.85 0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\dbtest\}
055159.87 0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\dbtest}
055159.89 0 rv add [$RV_STARTTIME]{6/28/2005 5:51:59 AM}
055159.90 0 rv add [$RV_DEVICEID]{0}
055159.91 0 rv add [$RV_CIDNAME]{}
055159.93 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
055159.94 0 rv add [$RV_CIDNUMBER]{}
055159.96 0 timer clear
055159.97 0 [welcome] Playing
055159.99 0 [welcome] Playing (C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav)
055200.00 0 play set playid=126441
055200.49 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav]
055200.50 0 timer clear
055200.52 0 RunModule PLAY end
055200.56 0 wa(2853,12644100)
055203.35 0 play end current play (playid=126441)
055203.36 0 ScriptEventCode 8001 iLineState=1100
055203.39 0 LsPlayMsg EV_PLAY_FINISHED
055203.41 0 timer set 10 EV_TIMEOUT_HANGUP
055203.43 0 timer set 3 EV_TIMEOUT_GOTOMODULE
055206.34 0 timer fired EV_TIMEOUT_GOTOMODULE
055206.35 0 ScriptEventCode 9002 iLineState=1101
055206.36 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
055206.39 0 timer clear
055206.40 0 [getPhone] Number Input
055206.41 0 [getPhone] Playing (PayGetAmount.wav)
055206.42 0 play set playid=132861
055206.93 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\dbtest\PayGetAmount.wav]
055206.94 0 timer clear
055206.99 0 wa(6637,13286100)
055213.60 0 play end current play (playid=132861)
055213.64 0 ScriptEventCode 8001 iLineState=1300
055213.67 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
055213.68 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
055213.69 0 timer set 5 EV_TIMEOUT_REPLAYMSG
055213.74 0 dtmf # (66235,35,2)
055213.75 0 ScriptEventCode 35 iLineState=1301
055213.76 0 LsGetNbrsRxDigits #
055213.77 0 timer clear
055213.78 0 rv add [getPhone]{}
055213.81 0 AddRVns [getPhone_PathTaken]{fail}
055213.85 0 timer clear
055213.86 0 [FailtoActivate] Playing
055213.89 0 [FailtoActivate] Playing (IpGoodbye.wav)
055213.92 0 play set playid=140361
055214.61 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\dbtest\IpGoodbye.wav]
055214.63 0 timer clear
055214.64 0 RunModule PLAY end
055214.71 0 wa(2141,14036100)
055216.72 0 play end current play (playid=140361)
055216.73 0 ScriptEventCode 8001 iLineState=1100
055216.75 0 LsPlayMsg EV_PLAY_FINISHED
055216.79 0 timer set 10 EV_TIMEOUT_HANGUP
055216.80 0 timer set 1 EV_TIMEOUT_GOTOMODULE
055217.73 0 timer fired EV_TIMEOUT_GOTOMODULE
055217.74 0 ScriptEventCode 9002 iLineState=1101
055217.75 0 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE
055217.77 0 timer clear
055217.78 0 rv add [Hangup Time]{6/28/2005 5:52:17 AM}
055217.79 0 Hanging up call... [Hangup Module]
055217.87 0 RecSoundStop ok
055217.92 0 PlaySoundStop err=0
055217.96 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
055218.05 0 fnHangupCall end
055218.21 0 callstate DISCONNECTED 66235 1 0
055218.22 0 ScriptEventCode 9250 iLineState=900
055218.24 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
055218.25 0 rv add [Hangup Time]{6/28/2005 5:52:18 AM}
055218.26 0 Hanging up call...
055218.36 0 RecSoundStop ok
055218.42 0 PlaySoundStop err=0
055218.45 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
055218.52 0 fnHangupCall end
055218.55 0 callstate IDLE 66235 0 0
055218.57 0 WorkingMode@Idle=
055218.60 0 timer clear
055218.73 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
055218.76 0 tapi Reply (LineEvReply) ok 66201 0
055218.79 0 tapi Reply (LineEvReply) ok 66184 0
055219.70 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
055219.71 0 ScriptEventCode 9008 iLineState=900
055219.72 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
055219.73 0 ReinitTelephony due to IDLE
055219.75 0 tapic lineDeallocateCall(MainCall:66235) 0
055220.51 0 lineOpen(0)=>
055220.52 0 Waiting for a call...
055220.53 0 LineHandle=66167
055220.56 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
055220.58 0 dial start any summary:|0:rdy=0|
055223.59 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
055223.60 0 ScriptEventCode 9013 iLineState=900
055223.62 0 dial start any summary:|0:idx=0|
055228.79 0 callstate OFFERING 66116 0 4
055228.84 0 ring 1
055229.12 0 sys cleanup Start
055229.13 0 sys cleanup End
055229.71 0 dial start any summary:|0:hc>0|
055234.84 0 ring 2
055234.85 0 rv clear
055234.86 0 Answer the call at 6/28/2005 5:52:34 AM
055234.87 0 lineAnswer(66116) => 66099
055234.89 0 callstate ACCEPTED 66116 0 0
055235.03 0 tapi Reply (LineEvReply) ok 66099 0
055235.12 0 callstate CONNECTED 66116 0 0
055235.13 0 callstate CONNECTED 66116,0,0
055235.14 0 WorkingModeTAPI@Connected=
055235.16 0 WorkingModeScript@Connected=
055235.18 0 Inband detection not enabled
055235.19 0 StartLoadedVgs at 6/28/2005 5:52:35 AM, v5.2.3063
055235.29 0 AddRVns [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\dbtest\}
055235.30 0 AddRVns [scriptPath]{C:\Program Files\VoiceGuide\Scripts\dbtest}
055235.31 0 rv add [$RV_STARTTIME]{6/28/2005 5:52:35 AM}
055235.33 0 rv add [$RV_DEVICEID]{0}
055235.34 0 rv add [$RV_CIDNAME]{}
055235.35 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
055235.36 0 rv add [$RV_CIDNUMBER]{}
055235.38 0 timer clear
055235.39 0 [welcome] Playing
055235.40 0 [welcome] Playing (C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav)
055235.42 0 play set playid=161862
055235.56 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4,play pss EnsureWaveOutIsOpenAndReady=>tr 5 waveOutOpen(id=0) MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program Files\VoiceGuide\system\voice\VmbWelcomeMsgDefault.wav]
055235.57 0 play set playid=161862
055235.77 0 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4,play pss EnsureWaveOutIsOpenAndReady=>tr 5 waveOutOpen(id=0) MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
055235.78 0 rv add [Hangup Time]{6/28/2005 5:52:35 AM}
055235.79 0 Hanging up call... [srlib PlaySoundStart]
055235.82 0 RecSoundStop ok
055235.88 0 PlaySoundStop err=0
055235.88 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
055235.93 0 fnHangupCall end
055235.94 0 RunModule PLAY end
055235.96 0 play end current play (playid=0)
055235.97 0 ScriptEventCode 8001 iLineState=900
055235.98 0 LsAwaitingCalls EV_PLAY_FINISHED
055236.03 0 play end current play (playid=0)
055236.04 0 ScriptEventCode 8001 iLineState=900
055236.04 0 LsAwaitingCalls EV_PLAY_FINISHED
055236.13 0 callstate DISCONNECTED 66116 1 0
055236.13 0 ScriptEventCode 9250 iLineState=900
055236.14 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
055236.16 0 rv add [Hangup Time]{6/28/2005 5:52:36 AM}
055236.17 0 Hanging up call...
055236.20 0 RecSoundStop ok
055236.24 0 PlaySoundStop err=0
055236.25 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
055236.29 0 fnHangupCall end
055236.30 0 callstate IDLE 66116 0 0
055236.31 0 WorkingMode@Idle=
055236.32 0 timer clear
055236.41 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
055236.42 0 tapi Reply (LineEvReply) ok 66082 0
055236.44 0 tapi Reply (LineEvReply) ok 66065 0
055237.35 0 timer fired EV_TIMEOUT_TIMETOREINITLINE
055237.36 0 ScriptEventCode 9008 iLineState=900
055237.37 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
055237.38 0 ReinitTelephony due to IDLE
055237.39 0 tapic lineDeallocateCall(MainCall:66116) 0
055237.78 0 lineOpen(0)=>
055237.79 0 Waiting for a call...
055237.80 0 LineHandle=66048
055237.82 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
055238.07 0 dial start any summary:|0:rdy=0|
055240.83 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
055240.84 0 ScriptEventCode 9013 iLineState=900
055241.10 0 dial start any summary:|0:idx=0|
055248.77 0 Unloading Main Window
Problem here relates to the Wave drivers.
Many USB modems have problems with Wave drivers.
You only option is to get another modem (or a Dialogic card).
If you are getting another modem try an external serial based modem...
(for a recent thread about another user who had problems with a USB modem please see: http://voiceguide.com/forums/index.php?showtopic=2950)
