Guest Eric Schuyler Report post Posted 06/28/2005 08:23 PM I just registered my VoiceGuide software and I've got my first script running! I am having a problem with leaving a voicemail message and returning to a script module. In a Play module, I have the following paths: on {0} goto [Goodbye] on {1} goto [Get CIN] on {2} goto [Voicemail Box 0001] return [Gold Choice Phone] When I press 2, I get the "Please record your message" prompt from the voicemail system as expected. When I press 0 at the end of my message, the call hangs up, instead of returning to the [Gold Choice Phone] module. Am I doing something wrong, or is this a voicemail issue? If I press 1 to end my message instead of 0, I get a menu which gives options for 1,2, or 3, but no exit choice. I have attached a ZIP file with the four log files generated during a call. Please help me sort this out! Regards, Eric Share this post Link to post
SupportTeam Report post Posted 06/28/2005 10:08 PM The .ZIP file did not attach. Please attach it again. Share this post Link to post
Guest Eric Schuyler Report post Posted 06/29/2005 12:31 PM Here is the ZIP file - thanks for your help. Regards, Eric logs.zip Share this post Link to post
