TomStorey Report post Posted 07/01/2005 12:18 PM If you use Run_ResultReturn in VBScript does the program stop at that point or does it continue on to the end of the script? Can you run Run_ResultReturn more then one time in a single script? Does Script_Return stop the script at that point or go on? Share this post Link to post
SupportTeam Report post Posted 07/02/2005 12:22 AM If you use Run_ResultReturn in VBScript does the program stop at that point or does it continue on to the end of the script? The VBScript continues on. It does not stop. The VoiceGuide script will jump on to the next module if a matching path exists. Can you run Run_ResultReturn more then one time in a single script? Not advisable. If the VG scruipt goes to the next module then the next Run_ResultReturn message will be sent ot that module, and it may cause a path from that module to be taken. What are you trying to achieve? Does Script_Return stop the script at that point or go on? Same as with Run_ResultReturn: VBScript goes on. VoiceGuide Script jumps to the next module and continues. Share this post Link to post
