Database Query Problem
i m not able to access data i ms access format thought database query model when the script runs it does not pics the data in access cell plz. reply.....
Could you please post a copy of VoiceGuide's Debug Printout which captures the database call, this will allow us to see what happened.
Also please post the script and databse you are using.
