Guest Jack_VR Report post Posted 07/04/2005 02:56 PM Hi, After we installed VG 4 Dialogic patch, we have a big problem about call length feature, we can NOT get the value of it. We've tried a couple of ways to get it, but all the return values are 0. So, what happened to $RV_CALLLENGTH? For example, 1. We used this script from your example in the calling out script: set vg = CreateObject("VoiceGuide.CommandLink") 'see how long the call on current line has been going on for: sReturnValue = vg.RvGet($RV_LINEID, "RV_CALLLENGTH") set vg = Nothing MsgBox sReturnValue It shows 0. 2. As I posted before, in our hang up script, the $RV_CALLLENGTH worked fine before we installed VG 4 Dialogic patch, but we only can get 0 now. By the way, you guys asked for posting the log, I did. But after a week, I still get no response from you guys about it, why? Jack Share this post Link to post
SupportTeam Report post Posted 07/05/2005 11:08 PM We're still looking into this. Will respond again within 24 hours. Share this post Link to post
SupportTeam Report post Posted 07/07/2005 11:55 AM We have found the problem with $RV_CALLLENGTH. Please update your VoiceGuide directory with this .exe $RV_CALLLENGTH should now work. VgMulti_6.0.2055.zip Share this post Link to post
Guest Jack_VR Report post Posted 07/11/2005 05:29 PM Thanks, I'll try it. Regards, Jack Share this post Link to post
