Disconnect Tone After Hangup
Hello. I'm working with VG for Dialogic 6.0.2028.
My problem is that VoiceGuide sometimes detects the DISCONNECT tone after the hangup of the call (I don't understand why) and it starts a new call. The new call detection happens while the 'script after the call is finished' is running.
The problem is shown in the trace:
080646,31 6 tw DialogicEvent 134,TDX_CST,196,0,0,DE_TONEON,TID_DISCONNECT,
080646,31 6 event DISCONNECT, code=134, state=1100
080646,31 6 LsPlayMsg EV_UNKNOWN_134,DISCONNECT
080646,33 6 path {DISCONNECT} not found
080646,33 6 rv add [Hangup Time]{06/07/2005 8:06:46}
080646,33 6 state Hanging up call...
080646,33 6 HangupCall_Common hCall=6
080646,33 6 rec RecSoundStop ok
080646,34 6 play PlaySoundStop ok
080646,34 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
080646,34 6 fnHangupCall end
080646,34 6 event TID_DISCONNECT, code=134, state=900
080646,34 6 LsAwaitingCalls EV_UNKNOWN_134
080646,36 6 event TDX_CST, code=134, state=900
080646,36 6 LsAwaitingCalls EV_UNKNOWN_134
080646,39 6 event callstate IDLE 6 0 0
080646,39 6 WorkingMode@Idle=
080646,39 6 timer clear
080646,39 6 rec RecSoundStop ok
080646,41 6 play PlaySoundStop ok
080646,41 6 rv add [CallEndTime]{06/07/2005 8:06:46}
080646,42 6 After Hangup script:[FinLlamada.vgs]
080646,42 6 FindFullPathToScript_VgsOrVgp start [C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\FinLlamada.vgs]
080646,42 6 FindFullPathToScript_VgsOrVgp 1
080646,42 0 LoadedVgs_Find C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\FinLlamada.vgs at idx=3
080646,42 6 fn RunModule start
080646,42 6 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
080646,44 6 event TDX_SETHOOK, code=135, state=6001
080646,44 6 timer clear
080646,44 6 state [Log Fin] Running VB Script...
080646,44 6 rv replace start (strlen>500)
080646,44 6 rvns [PathSysVoice]{C:\Archivos de programa\VoiceGuide\system\voice\}[PathApp]{C:\Archivos de programa\VoiceGuide\}[PathDataVm]{C:\Archivos de programa\VoiceGuide\data\}[PathVgSys]{C:\Archivos de programa\VoiceGuide\system\}[scriptsPath]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\}[$RV_STARTTIME]{06/07/2005 8:05:23}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Archivos de programa\VoiceGuide\}[scriptsPath]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\}[$RV_CIDNUMBER]{}[loginOK]{0}[DirInstal]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00}[DirAplic]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\iServConf}[ConfigDirectorios_ResultReturn]{success}[FichLog]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\log\llamadas050706_linea06.txt}[ConfigFichLog_ResultReturn]{success}[Log Inicio_ResultReturn]{success}[Reset contError 1_Input]{1}[Reset contError 1]{1}[contError]{1}[Reset loginOK_Input]{0}[Reset loginOK]{0}[loginOK]{0}[CodigoOper]{3001}[CodigoOper_PathTaken]{success}[wavErro
]{ErrorVerifCodOper.wav}[idOperador]{47}[NombreOperador]{3A(ALICANTE)}[ClaveOper
dor]{confia}[set loginOK_Input]{1}[set loginOK]{1}[loginOK]{1}[Reset contError MP_Input]{0}[Reset contError MP]{0}[contError]{0}[Reset Repaso_Input]{0}[Reset Repaso]{0}[repaso]{0}[scriptEnd_Time]{06/07/2005 8:06:12}[scriptEnd_Goto_Script]{trfOper.vgs}[scriptEnd_Goto_Module]{Log TransferOper}[scriptStart_Time]{06/07/2005 8:06:12}[scriptStart_CalledFrom_Script]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\servVocal.vgs}[scriptStart_CalledFrom_Module]{Menu Principal}[scriptsPath]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\}[Grabar NombreProv]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\NombreProv_6.wav}[Grabar NombreProv_RecLen100ms]{40}[Grabar NombreProv_EndRecCause]{silence}[NumTransf_1]{0942205618}[NumTransf_2]{094220560
}[NumTransf_3]{942205616}[NumTransf_4]{0942205603}[NumTransf_5]{0942205629}[Cuen
aNumTransf]{5}[RandomNumber]{3}[set indice aleatorio_Input]{3}[set indice aleatorio]{3}[indiceOper]{3}[Reset ciclos_Input]{0}[Reset ciclos]{0}[ciclos]{0}[Reset intentos_Input]{0}[Reset intentos]{0}[intentos]{0}[increm intentos_Input]{0+1}[increm intentos]{1}[intentos]{1}[Transferir a operador]{DISCONNECT}[Play recupera]{TID_DISCONNECT}[Max intentos_Input]{1=5}[Max intentos]{False}[Hangup Time]{06/07/2005 8:06:46}[CallEndTime]{06/07/2005 8:06:46}
080646,45 6 vbs ran [vbs_6_13.vbs], cmd [wscript "C:\Archivos de programa\VoiceGuide\data\vbs_6_13.vbs" //I //T:60]
080646,50 6 Run Script waiting. iRunWait=1 (shellid=660, process=50420)
080646,50 6 timer set 1 EV_TIMEOUT_CHECKONSTATE
080646,92 6 event callstate OFFERING 6 0 0
080646,92 6 script interpretor: VgMulti v6.0.2028
080646,92 6 tw ring 1
080646,94 6 ring time since last ring (ms): 0
080646,94 6 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
080646,94 6 event TDX_CST, code=134, state=1501
080646,94 6 LsRunWaitTillFinished EV_UNKNOWN_134
080647,06 6 cl Run_ResultReturn >>success<<
080647,06 6 rv add [Log Fin_ResultReturn]{success}
080647,06 6 path {success} not found
080647,08 6 cl module's runwait=1, WavPlayHasNowFinished=0
080647,08 6 rv add [Hangup Time]{06/07/2005 8:06:47}
080647,08 6 state Hanging up call... [Run_ResultReturn - no path match (same vgm)]
080647,08 6 HangupCall_Common hCall=6
080647,08 6 HangupCall_Common Mode=AfterHangupRun
080647,09 6 init atidle reinit : start
080647,09 6 init atidle reinit iConferenceOtherLegLid=-1
080647,09 6 init atidle reinit : reset all LineState variables
080647,09 6 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
080647,09 6 state Waiting for a call...
080647,09 6 rv clear all
080647,11 6 init LineState ResetAtStartOfNewCall.
080647,11 6 Terminating process (new call).
080647,11 6 Start without answering the call
080647,11 6 StartLoadedVgs at 06/07/2005 8:06:47
080647,11 6 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
080647,13 6 set sScriptToRunOnHangup=[FinLlamada.vgs] in StartLoadedVgs
080647,13 6 rv add [$RV_STARTTIME]{06/07/2005 8:06:47}
080647,13 6 rv add [$RV_DEVICEID]{6}
080647,13 6 rv add [$RV_CIDNAME]{}
080647,13 6 rvns add [PathApp]{C:\Archivos de programa\VoiceGuide\}
080647,14 6 rvns add [scriptsPath]{C:\Archivos de programa\Inelcom\ISPL\Confiabilizacion\Servidor Vocal A00\Scripts\}
080647,14 6 rv add [$RV_CIDNUMBER]{}
080647,14 6 fn RunModule start
There are two traces that show the message "Hanging up call...". When is the call really hangup?
Trace shows new call has arrived when the 'OnHangup' script (FinLlamada.vgs) was running.
The new call arrived here:
and VG waited for FinLlamada.vgs to finish before starting the new script which is to be ran when new call arrives here:
