corrigaj Report post Posted 07/07/2005 04:57 PM I'm trying to use $RV_PreviousModule in a Run VB Script Module: select case $RV_PreviousModule case "$RV[sayDOB]" verifyDOB() case else msgbox "Not Found",vbexclamation end select I can't seem to evaluate the previous module. I tried using msgbox $RV_PreviousModule but the box comes up blank. Any Ideas? Share this post Link to post
SupportTeam Report post Posted 07/07/2005 08:52 PM Which version of Voiceguide are you using? Can you please post a trace log capturing the call and running of this script & VBScript module. Share this post Link to post
