Outlook Contact Access
Hi !
Is there any way for us to have access to outlook contact info from voice guide script, per example to validate a phone number
Richard
This can be done from within a VBScript module.
You should be able to find more info on this in programming sites, but here as a starter is a short script showing you how to retrieve info from Outlook:
Public sub ListContacts()
   Dim oContact As ContactItem
   Dim oItems As Outlook.Items
   Dim sContact As String
   Dim sDelim As String
   Dim sFolderList As String
   Dim sFolders() As String
   Dim lListCount As Long
   Dim lContactCount As Long
   Dim i As Integer
   On Error GoTo ListContacts_Error
   lContactCount = 0
   'restrict to just contacts (might also be DistList there)
   Set oItems = m_oFold.Items.Restrict("[Messa­geClass] =
'IPM.Contact'")
   lListCount = oItems.Count
   ' Automation code example.
   For i = 1 To lListCount
       lContactCount = lContactCount + 1
       With oContact
           sContact = "Name: " & oItems(i).FullName _
              & ", Email: " & oItems(i).Email1Address
           msgbox sContact
       End With
   Next
   Set oItems = Nothing
   Set oContact = Nothing
ListContacts_Exit:
   Exit Function
ListContacts_Error:
   msgbox err.description & " reading contacts."
   Resume ListContacts_Exit
End Function
