David Flaks Report post Posted 07/12/2005 01:56 AM Is there a limit to the length of the Result Variable string length. I have used an OutDial_New.xml file that I believe has no errors, but when it imported into VoiceGuide, it seemed to change certain characters at the end of the string. I have attached the Trace file and below is the OutDial_New.xml file <?xml version="1.0" encoding="UTF-8"?> <dataroot xmlns:od="urn:schemas-microsoft-com:officedata"> <OutDialEntry> <PhoneNumber>883-5757</PhoneNumber> <DayTimeStart>0900</DayTimeStart> <DayTimeStop>1900</DayTimeStop> <DaysCallAllowed>MoTuWeThFrSa</DaysCallAllowed> <LineSelection>dxxxB1C1</LineSelection> <Priority>2</Priority> <OnAnswer>C:\TeleCaller\OSA\HumanOSA2.vgs</OnAnswer> <OnAnswerMachine>C:\TeleCaller\OSA\AnsMachOSA2.vgs</OnAnswerMachine> <CallRetries>2</CallRetries> <RetryDelay>30</RetryDelay> <RV>[RecordID]{OSA235529}[PatName]{HELEN HAGGERTY}[ApptDate]{0711}[ApptTime]{C:\Telecaller\WAVtime\1000.wav}[Provider]{C:\TeleCaller\OSA\WAV\HANDAL2.wav}[CallToReschedule]{C:\TeleCaller\OSA\WAV\CallToReschedule2.wav}[Goodbye]{C:\TeleCaller\OSA\WAV\Goodbye2.wav}</RV> <OnNotConnected>C:\TeleCaller\OSA\No_Answer.vbs $RV[RecordID] $RV[OutDial_Result]</OnNotConnected> </OutDialEntry> </dataroot> latest_trace.rtf Share this post Link to post
SupportTeam Report post Posted 07/12/2005 11:18 AM Is there a limit to the length of the Result Variable string length. No. I have used an OutDial_New.xml file that I believe has no errors, but when it imported into VoiceGuide, it seemed to change certain characters at the end of the string. Trace appears to be for a different load. There is no call to number 883-5757 in the attached trace. What line number/timestamp in the attached trace are you referring to? Share this post Link to post
