Get Numbers Module
Can the VBScript area inside the Get Numbers module also be used to query a database to confirm an entered number? I assume so, but as the help guide didn't specifically mention it I thought I'd check before building theh application.
Geoff
Yes, you can run any VBScript you want as long as it in the end returns either a "verify_passed" or a "verify_failed" result back to VoiceGuide.
