Transfer Module
I am not sure why my transfer module doesn’t take either success or fail path. Worse then this it doesn’t either transfer the call.
Bellow is my log file for testing the transfer module in VG script. I have tested this module three time, two times, I entered the long distance number, and once a local number. On all case there was not transfer call.
Please help to solve this problem.
Thanks.
Farzad
105647.25 6 linedevstate 2048 0 0
105647.27 6 callstate OFFERING 65730 0 4
105647.27 6 rv clear
105647.27 6 Answer the call at 7/18/2005 10:56:47 AM
105647.27 6 lineAnswer(65730) => 66208
105647.28 6 callinfo CALLEDID
105647.28 6 callinfo ORIGIN
105647.28 6 ring 0
105647.39 0 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0|
105647.81 6 callstate CONNECTED 65730 1 0
105647.81 6 callstate CONNECTED 65730,1,0
105647.83 6 WorkingModeTAPI@Connected=
105647.83 6 WorkingModeScript@Connected=
105647.83 6 Inband detection not enabled
105647.83 6 StartLoadedVgs at 7/18/2005 10:56:47 AM, script interpretor VgMulti v5.2.4000 7
105647.83 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
105647.84 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts}
105647.84 6 rv lg add [$RV_STARTTIME]{7/18/2005 10:56:47 AM}
105647.84 6 rv lg add [$RV_DEVICEID]{6}
105647.86 6 rv lg add [$RV_CIDNAME]{}
105647.86 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
105647.86 6 rv lg add [$RV_CIDNUMBER]{}
105647.88 6 tapi Reply (LineEvReply) ok 66208 0
105647.88 6 callinfo MONITORMODES
105647.88 6 timer clear
105647.89 6 [Get Numbers 2] Number Input
105647.89 6 [Get Numbers 2] Playing (C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\EnterTelephoneNum.wav)
105647.89 6 play set playid=736453
105647.95 6 PlaySoundStart ok [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\EnterTelephoneNum.wav]
105647.95 6 timer clear
105647.97 6 wa(2226,73645300)
105647.97 6 callinfo MONITORMODES
105650.25 6 wb(73645300)
105650.27 6 play end current play (playid=736453)
105650.27 6 ScriptEventCode 8001 iLineState=1300
105650.28 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
105650.28 6 timer set 10 EV_TIMEOUT_HANGUP
105650.28 6 timer set 6 EV_TIMEOUT_ENTERDATA
105651.39 6 dtmf 1 (65730,49,2)
105651.39 6 ScriptEventCode 49 iLineState=1301
105651.39 6 LsGetNbrsRxDigits 1
105651.41 6 [Get Numbers 2] Number Input 1
105651.41 6 path {1} not found
105651.41 6 timer set 6 EV_TIMEOUT_ENTERDATA
105652.09 6 dtmf 4 (65730,52,2)
105652.09 6 ScriptEventCode 52 iLineState=1301
105652.11 6 LsGetNbrsRxDigits 4
105652.11 6 [Get Numbers 2] Number Input 14
105652.11 6 path {14} not found
105652.13 6 timer set 6 EV_TIMEOUT_ENTERDATA
105652.77 6 dtmf 0 (65730,48,2)
105652.77 6 ScriptEventCode 48 iLineState=1301
105652.78 6 LsGetNbrsRxDigits 0
105652.78 6 [Get Numbers 2] Number Input 140
105652.78 6 path {140} not found
105652.80 6 timer set 6 EV_TIMEOUT_ENTERDATA
105653.72 6 dtmf 8 (65730,56,2)
105653.72 6 ScriptEventCode 56 iLineState=1301
105653.72 6 LsGetNbrsRxDigits 8
105653.73 6 [Get Numbers 2] Number Input 1408
105653.73 6 path {1408} not found
105653.73 6 timer set 6 EV_TIMEOUT_ENTERDATA
105656.63 6 dtmf 5 (65730,53,2)
105656.64 6 ScriptEventCode 53 iLineState=1301
105656.64 6 LsGetNbrsRxDigits 5
105656.64 6 [Get Numbers 2] Number Input 14085
105656.66 6 path {14085} not found
105656.66 6 timer set 6 EV_TIMEOUT_ENTERDATA
105657.03 6 dtmf 0 (65730,48,2)
105657.03 6 ScriptEventCode 48 iLineState=1301
105657.03 6 LsGetNbrsRxDigits 0
105657.05 6 [Get Numbers 2] Number Input 140850
105657.05 6 path {140850} not found
105657.05 6 timer set 6 EV_TIMEOUT_ENTERDATA
105657.36 6 dtmf 7 (65730,55,2)
105657.36 6 ScriptEventCode 55 iLineState=1301
105657.38 6 LsGetNbrsRxDigits 7
105657.38 6 [Get Numbers 2] Number Input 1408507
105657.38 6 path {1408507} not found
105657.39 6 timer set 6 EV_TIMEOUT_ENTERDATA
105657.64 6 dtmf 5 (65730,53,2)
105657.64 6 ScriptEventCode 53 iLineState=1301
105657.66 6 LsGetNbrsRxDigits 5
105657.66 6 [Get Numbers 2] Number Input 14085075
105657.66 6 path {14085075} not found
105657.67 6 timer set 6 EV_TIMEOUT_ENTERDATA
105658.03 6 dtmf 0 (65730,48,2)
105658.03 6 ScriptEventCode 48 iLineState=1301
105658.05 6 LsGetNbrsRxDigits 0
105658.05 6 [Get Numbers 2] Number Input 140850750
105658.05 6 path {140850750} not found
105658.06 6 timer set 6 EV_TIMEOUT_ENTERDATA
105658.27 6 dtmf 0 (65730,48,2)
105658.28 6 ScriptEventCode 48 iLineState=1301
105658.28 6 LsGetNbrsRxDigits 0
105658.28 6 [Get Numbers 2] Number Input 1408507500
105658.30 6 path {1408507500} not found
105658.30 6 timer set 6 EV_TIMEOUT_ENTERDATA
105658.59 6 dtmf 2 (65730,50,2)
105658.61 6 ScriptEventCode 50 iLineState=1301
105658.61 6 LsGetNbrsRxDigits 2
105658.61 6 [Get Numbers 2] Number Input 14085075002
105658.63 6 path {14085075002} not found
105658.63 6 timer set 6 EV_TIMEOUT_ENTERDATA
105700.98 6 dtmf # (65730,35,2)
105700.98 6 ScriptEventCode 35 iLineState=1301
105701.00 6 LsGetNbrsRxDigits #
105701.00 6 timer clear
105701.00 6 rv lg add [Get Numbers 2]{14085075002}
105701.02 6 path {14085075002} not found
105701.02 6 rv ns add [Get Numbers 2_PathTaken]{success}
105701.02 6 timer clear
105701.03 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
105701.36 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
105701.36 6 ScriptEventCode 9012 iLineState=1900
105701.36 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
105701.38 6 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
105701.38 6 rv replace start: [$RV[Get Numbers 2]]
105701.38 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{7/18/2005 10:56:47 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Get Numbers 2]{14085075002}[Get Numbers 2_PathTaken]{success}
105701.39 6 rv replace end: [14085075002]
105701.39 6 [Transfer Call 3] Dial and Conference to 14085075002 (Generate)
105701.39 0 Search for free lines in LineID range [6-9]
105701.41 6 dial busy: active call
105701.41 7 dial reserving [dxxxB1C2] as no list specified
105701.41 6 dial found free dev=2 (LineId=7)
105701.42 7 Calling 14085075002 (related LineId=6)
105701.42 6 MakeCallEx => 66225
105701.44 7 TapiCbTrigSet 66225 7003
105701.44 6 timer set 3600 EV_TIMEOUT_HANGUP
105701.44 7 timer set 3600 EV_TIMEOUT_HANGUP
105701.50 0 dial start any summary:|6:hc>0|7:rdy=2|8:idx=0|9:idx=0|
105701.97 7 tapi Reply (LineEvReply) ok 66225 0
105701.97 7 TcTrig.lTrigType = TcTrig_MakeCallForConferenceFinished
105701.97 7 Setting conference to occur in 3 seconds (not waiting for PROCEEDING)
105701.98 7 timer set 3 EV_TIMEOUT_BRIDGEAFTERDIALING
105701.98 7 TapiCbTrigClear
105702.00 7 linedevstate 2048 0 0
105702.00 7 callstate DIALTONE 66044 0 0
105702.02 7 callstate DIALING 66044 0 0
105702.02 7 callstate PROCEEDING 66044 0 0
105702.02 7 callinfo CALLEDID
105702.03 7 callinfo REASON
105702.05 7 Lev_CallerID [0000,,14085075002]
105702.05 7 callinfo ORIGIN
105702.53 0 dial start any summary:|6:hc>0|7:hc>0|8:idx=0|9:idx=0|
105705.22 7 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
105705.22 7 ScriptEventCode 9014 iLineState=1910
105705.22 7 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
105705.23 6 rv ns add [Conf_DevName_1]{dxxxB1C1}
105705.23 6 rv ns add [Conf_LineId_1]{6}
105705.23 6 rv lg add [Conf_DevName_2]{dxxxB1C2}
105705.25 6 rv lg add [Conf_LineId_2]{7}
105705.25 7 rv ns add [Conf_DevName_1]{dxxxB1C1}
105705.25 7 rv ns add [Conf_LineId_1]{6}
105705.27 7 rv lg add [Conf_DevName_2]{dxxxB1C2}
105705.27 7 rv lg add [Conf_LineId_2]{7}
105705.27 7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
105705.30 7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
105705.30 7 Conferenced to 6 (dxxxB1C2) at 10:57:05 AM
105705.30 6 [Transfer Call 3] Conferenced to 7 (dxxxB1C1) at 10:57:05 AM
105710.59 7 callstate CONNECTED 66044 1 0
105710.59 7 callstate CONNECTED 66044,1,0
105710.61 7 WorkingModeTAPI@Connected=
105710.61 7 WorkingModeScript@Connected=
105710.63 7 2nd leg of call recieved CONNECTED event
105818.22 6 callstate DISCONNECTED 65730 0 0
105818.22 6 ScriptEventCode 9250 iLineState=1910
105818.23 6 LsXferWaitEndCall EV_REMOTEPARTY_DISCONNECT
105818.23 6 rv lg add [Hangup Time]{7/18/2005 10:58:18 AM}
105818.23 6 Hanging up call...
105818.25 6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_ call
105818.28 6 DialogicScUnroute dxxxB1C1</>dxxxB1C2 MATCH_
105818.28 7 rv lg add [Hangup Time]{7/18/2005 10:58:18 AM}
105818.28 7 Hanging up call... [2nd leg]
105818.30 7 RecSoundStop ok
105818.30 7 PlaySoundStop err=0
105818.31 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105818.31 7 Waiting for a call...
105818.33 7 fnHangupCall end
105818.33 6 RecSoundStop ok
105818.34 6 PlaySoundStop err=0
105818.34 6 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105818.36 6 fnHangupCall end
105818.38 7 callstate DISCONNECTED 66044 0 0
105818.38 7 ScriptEventCode 9250 iLineState=900
105818.39 7 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
105818.39 7 rv lg add [Hangup Time]{7/18/2005 10:58:18 AM}
105818.39 7 Hanging up call...
105818.41 7 RecSoundStop ok
105818.42 7 PlaySoundStop err=0
105818.42 7 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
105818.44 7 Waiting for a call...
105818.44 7 fnHangupCall end
105818.44 7 linedevstate 2048 0 0
105818.45 7 callstate IDLE 66044 0 0
105818.45 7 WorkingMode@Idle=
105818.45 7 timer clear
105818.47 7 LineState(iLineId).iVgsIdx = 0
105818.47 7 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
105818.48 7 tapi Reply (LineEvReply) ok 66131 0
105818.48 6 linedevstate 2048 0 0
105818.48 6 callstate IDLE 65730 0 0
105818.50 6 WorkingMode@Idle=
105818.50 6 timer clear
105818.52 6 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
105818.52 6 tapi Reply (LineEvReply) ok 65920 0
105818.53 7 tapi Reply (LineEvReply) err 66324 LINEERR_INVALCALLSTATE [8000001C]
105819.52 6 timer fired EV_TIMEOUT_TIMETOREINITLINE
105819.52 6 ScriptEventCode 9008 iLineState=900
105819.52 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
105819.53 6 ReinitTelephony due to IDLE
105819.53 6 tapic lineDeallocateCall(MainCall:65730) 0
105819.66 6 lineOpen(6)=>
105819.66 6 Waiting for a call...
105819.67 6 LineHandle=65683
105819.67 6 amchk set AMdet=False in Reinit@idle
105819.67 6 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
105819.69 7 timer fired EV_TIMEOUT_TIMETOREINITLINE
105819.69 7 ScriptEventCode 9008 iLineState=900
105819.69 7 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
105819.70 7 ReinitTelephony due to IDLE
105819.72 0 dial start any summary:|6:rdy=0|7:hc>0|8:idx=0|9:idx=0|
105819.72 7 tapic lineDeallocateCall(MainCall:66044) 0
105819.83 7 lineOpen(7)=>
105819.88 7 Waiting for a call...
105819.88 7 LineHandle=66295
105819.89 7 amchk set AMdet=False in Reinit@idle
105819.89 7 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
105820.72 0 dial start any summary:|6:rdy=0|7:rdy=0|8:idx=0|9:idx=0|
105823.19 6 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
105823.19 6 ScriptEventCode 9013 iLineState=900
105823.19 7 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
105823.20 7 ScriptEventCode 9013 iLineState=900
105823.75 0 dial start any summary:|6:idx=0|7:idx=0|8:idx=0|9:idx=0|
*****second test to international number.
105949.81 6 linedevstate 2048 0 0
105949.83 6 callstate OFFERING 66045 0 4
105949.83 6 rv clear
105949.83 6 Answer the call at 7/18/2005 10:59:49 AM
105949.83 6 lineAnswer(66045) => 66074
105949.84 6 callinfo CALLEDID
105949.84 6 callinfo ORIGIN
105949.84 6 ring 0
105950.06 0 dial start any summary:|6:hc>0|7:idx=0|8:idx=0|9:idx=0|
105950.38 6 callstate CONNECTED 66045 1 0
105950.38 6 callstate CONNECTED 66045,1,0
105950.38 6 WorkingModeTAPI@Connected=
105950.39 6 WorkingModeScript@Connected=
105950.39 6 Inband detection not enabled
105950.39 6 StartLoadedVgs at 7/18/2005 10:59:50 AM, script interpretor VgMulti v5.2.4000 7
105950.39 6 rv ns add [scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}
105950.41 6 rv ns add [scriptPath]{C:\Program Files\VoiceGuide\Scripts}
105950.41 6 rv lg add [$RV_STARTTIME]{7/18/2005 10:59:50 AM}
105950.41 6 rv lg add [$RV_DEVICEID]{6}
105950.41 6 rv lg add [$RV_CIDNAME]{}
105950.42 6 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
105950.42 6 rv lg add [$RV_CIDNUMBER]{}
105950.42 6 tapi Reply (LineEvReply) ok 66074 0
105950.44 6 callinfo MONITORMODES
105950.44 6 timer clear
105950.44 6 [Get Numbers 2] Number Input
105950.45 6 [Get Numbers 2] Playing (C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\EnterTelephoneNum.wav)
105950.45 6 play set playid=919015
105950.52 6 PlaySoundStart ok [C:\Program Files\ivg\Scripts\PBPScript\MCAC\voice files\1\EnterTelephoneNum.wav]
105950.52 6 timer clear
105950.52 6 wa(2226,91901500)
105950.53 6 callinfo MONITORMODES
105952.81 6 play end current play (playid=919015)
105952.83 6 ScriptEventCode 8001 iLineState=1300
105952.83 6 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
105952.83 6 timer set 10 EV_TIMEOUT_HANGUP
105952.84 6 timer set 6 EV_TIMEOUT_ENTERDATA
105953.64 6 dtmf 0 (66045,48,2)
105953.66 6 ScriptEventCode 48 iLineState=1301
105953.66 6 LsGetNbrsRxDigits 0
105953.66 6 [Get Numbers 2] Number Input 0
105953.67 6 path {0} not found
105953.67 6 timer set 6 EV_TIMEOUT_ENTERDATA
105954.02 6 dtmf 1 (66045,49,2)
105954.02 6 ScriptEventCode 49 iLineState=1301
105954.03 6 LsGetNbrsRxDigits 1
105954.03 6 [Get Numbers 2] Number Input 01
105954.03 6 path {01} not found
105954.05 6 timer set 6 EV_TIMEOUT_ENTERDATA
105954.17 6 dtmf 1 (66045,49,2)
105954.17 6 ScriptEventCode 49 iLineState=1301
105954.19 6 LsGetNbrsRxDigits 1
105954.19 6 [Get Numbers 2] Number Input 011
105954.19 6 path {011} not found
105954.20 6 timer set 6 EV_TIMEOUT_ENTERDATA
105956.13 6 dtmf 9 (66045,57,2)
105956.13 6 ScriptEventCode 57 iLineState=1301
105956.13 6 LsGetNbrsRxDigits 9
105956.14 6 [Get Numbers 2] Number Input 0119
105956.14 6 path {0119} not found
105956.14 6 timer set 6 EV_TIMEOUT_ENTERDATA
105956.81 6 dtmf 8 (66045,56,2)
105956.81 6 ScriptEventCode 56 iLineState=1301
105956.83 6 LsGetNbrsRxDigits 8
105956.83 6 [Get Numbers 2] Number Input 01198
105956.83 6 path {01198} not found
105956.84 6 timer set 6 EV_TIMEOUT_ENTERDATA
105957.05 6 dtmf 9 (66045,57,2)
105957.06 6 ScriptEventCode 57 iLineState=1301
105957.06 6 LsGetNbrsRxDigits 9
105957.06 6 [Get Numbers 2] Number Input 011989
105957.08 6 path {011989} not found
105957.08 6 timer set 6 EV_TIMEOUT_ENTERDATA
105957.34 6 dtmf 1 (66045,49,2)
105957.34 6 ScriptEventCode 49 iLineState=1301
105957.36 6 LsGetNbrsRxDigits 1
105957.36 6 [Get Numbers 2] Number Input 0119891
105957.36 6 path {0119891} not found
105957.38 6 timer set 6 EV_TIMEOUT_ENTERDATA
105957.64 6 dtmf 7 (66045,55,2)
105957.64 6 ScriptEventCode 55 iLineState=1301
105957.66 6 LsGetNbrsRxDigits 7
105957.66 6 [Get Numbers 2] Number Input 01198917
105957.67 6 path {01198917} not found
105957.67 6 timer set 6 EV_TIMEOUT_ENTERDATA
105958.11 6 dtmf 3 (66045,51,2)
105958.11 6 ScriptEventCode 51 iLineState=1301
105958.13 6 LsGetNbrsRxDigits 3
105958.13 6 [Get Numbers 2] Number Input 011989173
105958.13 6 path {011989173} not found
105958.14 6 timer set 6 EV_TIMEOUT_ENTERDATA
105958.81 6 dtmf 1 (66045,49,2)
105958.83 6 ScriptEventCode 49 iLineState=1301
105958.83 6 LsGetNbrsRxDigits 1
105958.83 6 [Get Numbers 2] Number Input 0119891731
105958.84 6 path {0119891731} not found
105958.84 6 timer set 6 EV_TIMEOUT_ENTERDATA
105959.02 6 dtmf 3 (66045,51,2)
105959.02 6 ScriptEventCode 51 iLineState=1301
105959.02 6 LsGetNbrsRxDigits 3
105959.03 6 [Get Numbers 2] Number Input 01198917313
105959.03 6 path {01198917313} not found
105959.03 6 timer set 6 EV_TIMEOUT_ENTERDATA
105959.55 6 dtmf 6 (66045,54,2)
105959.56 6 ScriptEventCode 54 iLineState=1301
105959.56 6 LsGetNbrsRxDigits 6
105959.56 6 [Get Numbers 2] Number Input 011989173136
105959.56 6 path {011989173136} not found
105959.58 6 timer set 6 EV_TIMEOUT_ENTERDATA
105959.91 6 dtmf 0 (66045,48,2)
105959.92 6 ScriptEventCode 48 iLineState=1301
105959.92 6 LsGetNbrsRxDigits 0
105959.92 6 [Get Numbers 2] Number Input 0119891731360
105959.94 6 path {0119891731360} not found
105959.94 6 timer set 6 EV_TIMEOUT_ENTERDATA
110000.16 6 dtmf 3 (66045,51,2)
110000.16 6 ScriptEventCode 51 iLineState=1301
110000.16 6 LsGetNbrsRxDigits 3
110000.17 6 [Get Numbers 2] Number Input 01198917313603
110000.17 6 path {01198917313603} not found
110000.17 6 timer set 6 EV_TIMEOUT_ENTERDATA
110000.39 6 dtmf 5 (66045,53,2)
110000.39 6 ScriptEventCode 53 iLineState=1301
110000.41 6 LsGetNbrsRxDigits 5
110000.41 6 [Get Numbers 2] Number Input 011989173136035
110000.41 6 path {011989173136035} not found
110000.42 6 timer set 6 EV_TIMEOUT_ENTERDATA
110001.23 6 dtmf # (66045,35,2)
110001.23 6 ScriptEventCode 35 iLineState=1301
110001.23 6 LsGetNbrsRxDigits #
110001.25 6 timer clear
110001.25 6 rv lg add [Get Numbers 2]{011989173136035}
110001.25 6 path {011989173136035} not found
110001.27 6 rv ns add [Get Numbers 2_PathTaken]{success}
110001.27 6 timer clear
110001.27 6 timer set 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER
110001.63 6 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
110001.63 6 ScriptEventCode 9012 iLineState=1900
110001.63 6 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER
110001.64 6 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
110001.64 6 rv replace start: [$RV[Get Numbers 2]]
110001.64 6 rv ns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[scriptsPath]{C:\Program Files\VoiceGuide\Scripts\}[scriptPath]{C:\Program Files\VoiceGuide\Scripts}[$RV_STARTTIME]{7/18/2005 10:59:50 AM}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{}[Get Numbers 2]{011989173136035}[Get Numbers 2_PathTaken]{success}
110001.66 6 rv replace end: [011989173136035]
110001.66 6 [Transfer Call 3] Dial and Conference to 011989173136035 (Generate)
110001.67 0 Search for free lines in LineID range [6-9]
110001.67 6 dial busy: active call
110001.67 7 dial reserving [dxxxB1C2] as no list specified
110001.69 6 dial found free dev=2 (LineId=7)
110001.69 7 Calling 011989173136035 (related LineId=6)
110001.70 6 MakeCallEx => 65823
110001.70 7 TapiCbTrigSet 65823 7003
110001.70 6 timer set 3600 EV_TIMEOUT_HANGUP
110001.72 7 timer set 3600 EV_TIMEOUT_HANGUP
110002.20 0 dial start any summary:|6:hc>0|7:rdy=2|8:idx=0|9:idx=0|
110002.23 7 tapi Reply (LineEvReply) ok 65823 0
110002.23 7 TcTrig.lTrigType = TcTrig_MakeCallForConferenceFinished
110002.25 7 Setting conference to occur in 3 seconds (not waiting for PROCEEDING)
110002.25 7 timer set 3 EV_TIMEOUT_BRIDGEAFTERDIALING
110002.25 7 TapiCbTrigClear
110002.27 7 linedevstate 2048 0 0
110002.27 7 callstate DIALTONE 66313 0 0
110002.28 7 callstate DIALING 66313 0 0
110002.28 7 callstate PROCEEDING 66313 0 0
110002.30 7 callinfo CALLEDID
110002.30 7 callinfo REASON
110002.31 7 Lev_CallerID [0000,,011989173136035]
110002.31 7 callinfo ORIGIN
110003.20 0 dial start any summary:|6:hc>0|7:hc>0|8:idx=0|9:idx=0|
110005.73 7 timer fired EV_TIMEOUT_BRIDGEAFTERDIALING
110005.73 7 ScriptEventCode 9014 iLineState=1910
110005.73 7 LsXferWaitEndCall EV_TIMEOUT_BRIDGEAFTERDIALING
110005.75 6 rv ns add [Conf_DevName_1]{dxxxB1C1}
110005.75 6 rv ns add [Conf_LineId_1]{6}
110005.75 6 rv lg add [Conf_DevName_2]{dxxxB1C2}
110005.77 6 rv lg add [Conf_LineId_2]{7}
110005.77 7 rv ns add [Conf_DevName_1]{dxxxB1C1}
110005.77 7 rv ns add [Conf_LineId_1]{6}
110005.78 7 rv lg add [Conf_DevName_2]{dxxxB1C2}
110005.78 7 rv lg add [Conf_LineId_2]{7}
110005.78 7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 call
110005.81 7 DialogicScRoute dxxxB1C1<=>dxxxB1C2 SC_FULLDUP:
110005.81 7 Conferenced to 6 (dxxxB1C2) at 11:00:05 AM
110005.81 6 [Transfer Call 3] Conferenced to 7 (dxxxB1C1) at 11:00:05 AM
110011.45 7 callstate CONNECTED 66313 1 0
110011.47 7 callstate CONNECTED 66313,1,0
110011.47 7 WorkingModeTAPI@Connected=
110011.47 7 WorkingModeScript@Connected=
110011.48 7 2nd leg of call recieved CONNECTED event
Trace shows outgoing call was made on second line (dxxxB1C2) and then the two calls were connected, then original caller hung up about a minute later:
What did the original caller into the system hear?
Did number 14085075002 ring at all?
Can you call 14085075002 when just using the Dialer?
