Popupcallerid=n In Vg.ini
THis is not documented - at least I haven't found it - but in VG.ini there is a parm:
PopupCallerID=
Mine was set to 2 and the popup would not occur. The trace log reports that caller id is incomplete and it had a comma after the number. This indicated (I guess) it also wanted the name to be sent. In checking with my phone company, they only send the number in the service I have. On a guess I chnged this to a 1 and the popup worked! I would guess that indicates only look for the number while 2 indicates wait for both number and name. I can only guess that the value of 0 or blank might mean ignore - I have not tested it - or it could be accept any combination or ??
Any comment from Support?? If so, where can we find documentation on other such goodies?
Thanks ... abe
0=ignore CID
1=number only
2=number AND name
Yes, 1 is equivalent to 'number only'.
v4.9.1 of VG will have the various settings stated in plain English and visible as a drop down combo list in the "Line Configuration" section of VoiceGuide.
