ktruk Report post Posted 07/21/2005 08:36 AM I really want to rename my dialogic channels - is there a way to do this? And avoid the name being repeated on the status line? In Vg4Dialogic, if you rename the lines in CONFIG.XML to something other than "DxxB1C1" in either the "<Name>" or "<Network_IF>" tags then either the line doesnt run or you get a status error! If you rename both, it maks no difference. Is there a setting somewhere in the Dialogic driver side of things that could be changed? Can a new Tag be added in the Channel Tag for "LineDescription"? Share this post Link to post
SupportTeam Report post Posted 07/21/2005 10:18 AM The line names specified in CONFIG.XML must reflect the Dialogic's line names notation. Is there a setting somewhere in the Dialogic driver side of things that could be changed? No. Share this post Link to post
