Call Transfer (via Telco)
I have VG 4.8.45, Dialogic 4PCI and have a call transfer feature enabled by the telco which works this way:
flash
dial number
on connect flash to disconnect
What's happening is that when I try the different option of the transfer module is that the 3rd line will only ring once and that's it. It need to ring until answered then flash must occur (to disconnect VG form party 1 and party 3).
thanks
Ryan
Sounds like the script is now performing a blind transfer, ie:
flash
dial number
hangup
What you should do is use "announced transfer" and specify "!" in the "Complete announced call transfer" field.
You will then get:
flash
dial number
wait for person answering transfer to accept transfer by pressing “1”
flash
hangup
Use menu Edit - > PBX Command Strings to specify "!" in the "Complete announced call transfer" field.
