Guest Guest_Xavier Report post Posted 07/21/2005 08:20 PM Hello, I just purchased ATT Natural Voices Server. I am trying to install it on a WP system with no luck. The assistance from the vendor is very slow. Pls let me know if anybody has already install it. Thanks Xavier Share this post Link to post
SupportTeam Report post Posted 07/21/2005 10:39 PM Are you installing the SAPI TTS Engines (as listed here: https://www.regsoft.net/regsoft/vieworderpa...productid=56116 ) or are you installing some other product? I can see that AT&T have a product called "ATT Natural Voices Server" which seems to be something different to the TTS Engines which are all that you need to use AT&T TTS from within VoiceGuide. What are the actual problems you have encountered with installation? are you installing TTS Engines or the ATT Natural Voices Server? If ATT Natural Voices Server then for what purpose did you buy ATT Natural Voices Server? You may also want to look at: http://www.voiceguide.com/forums/index.php...p?showtopic=421 http://www.voiceguide.com/forums/index.php...p?showtopic=397 Share this post Link to post
