ktruk Report post Posted 07/22/2005 02:55 PM Keep getting the following error when looking in event logs for vg4Dialogic: 154504.48 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range Also noticed that when you open CONFIGLINE.XML in explorer, it gives a validation error. I think the file should only one overall containing tag "<tones>" but the "<parms>" section forms a second tag-block outside of "<tones>". I guess if VG is only reading (writing) the file this doesn't matter, but, in my opinion, it should be a "well formed" file. IE gives the following errors: Only one top level element is allowed in an XML document. Error processing resource 'file:///C:/Program Files/VoiceGuide/da... Could this have anything to do with the subscript error? Also: same (or similar) error given when VGMULTI.EXE crashes on exit...? Share this post Link to post
SupportTeam Report post Posted 07/22/2005 11:31 PM We'll have a look at CONFIGLINE.XML to make it more standard. We're aware of "Subscript out of range" messages in debug trace logs - we'll look into what is causing them and ensure they no longer appear in logs. They do not seem to affect the correct operation of the software. Share this post Link to post
ktruk Report post Posted 07/23/2005 01:07 PM The following error given in *tw.txt log file appears to be related to the misplaced "<Parms>" tag section: 135540.326 001 xml parse error at line 194:junk after document element Also, there another error listed in the *vgm.txt log file possibly related to the subscript range problem: 135552.05 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range ... ... 135552.59 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState I will post full logs shortly in another thread. Share this post Link to post
