Guest ggomezv Report post Posted 07/22/2005 03:54 PM I'm evaluating voice mail and I've the following problem: When the wellcome wav plays , it lasts about 12 seconds and hangs . I've disabled all my wave drivers leaving only the modem wave driver. Here's the trace log: 104652.57 0 callstate OFFERING 66155 0 4 104652.57 0 rv clear 104652.57 0 Answer the call at 22/07/2005 10:46:52 a.m. 104652.58 0 lineAnswer(66155) => 66241 104652.58 0 ring 1 104652.58 0 callstate ACCEPTED 66155 0 0 104653.29 0 dial start any summary:|0:hc>0| 104655.87 0 tapi Reply (LineEvReply) ok 66241 0 104655.87 0 callstate CONNECTED 66155 0 0 104655.87 0 callstate CONNECTED 66155,0,0 104655.88 0 WorkingModeTAPI@Connected= 104655.88 0 WorkingModeScript@Connected= 104655.88 0 Inband detection not enabled 104655.88 0 StartLoadedVgs at 22/07/2005 10:46:55 a.m., script interpretor VgMulti v5.2.4000 0 104655.89 0 rv ns add [scriptsPath]{C:\Bansi\} 104655.89 0 rv ns add [scriptPath]{C:\Bansi} 104655.89 0 rv lg add [$RV_STARTTIME]{22/07/2005 10:46:55 a.m.} 104655.89 0 rv lg add [$RV_DEVICEID]{0} 104655.90 0 rv lg add [$RV_CIDNAME]{} 104655.00 0 rv ns add [PathApp]{C:\Program Files\VoiceGuide\} 104655.00 0 rv lg add [$RV_CIDNUMBER]{} 104656.03 0 timer clear 104656.03 0 [Welcome] Playing 104656.04 0 [Welcome] Playing (C:\VOC\Bienvenida.wav) 104656.04 0 play set playid=985647 104656.53 0 PlaySoundStart ok [C:\VOC\Bienvenida.wav] 104656.58 0 timer clear 104656.58 0 RunModule PLAY end 104656.60 0 wa(50151,98564700) 104708.50 0 dtmf D (66155,68,2) 104708.61 0 ScriptEventCode 68 iLineState=1100 104708.61 0 rv lg add [Hangup Time]{22/07/2005 10:47:08 a.m.} 104708.61 0 Hanging up call... [Global End-of-Call DTMF (D)] 104708.64 0 RecSoundStop ok 104710.04 0 PlaySoundStop err=0 104710.04 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 104710.05 0 fnHangupCall end 104711.35 0 callstate DISCONNECTED 66155 1 0 104711.36 0 ScriptEventCode 9250 iLineState=900 104711.36 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT 104711.36 0 rv lg add [Hangup Time]{22/07/2005 10:47:11 a.m.} 104711.37 0 Hanging up call... 104711.42 0 RecSoundStop ok 104711.48 0 PlaySoundStop err=0 104711.49 0 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 104711.49 0 fnHangupCall end 104711.50 0 callstate IDLE 66155 0 0 104711.50 0 WorkingMode@Idle= 104711.51 0 timer clear 104711.51 0 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 104711.51 0 tapi Reply (LineEvReply) ok 66036 0 104711.52 0 tapi Reply (LineEvReply) ok 65950 0 104712.42 0 timer fired EV_TIMEOUT_TIMETOREINITLINE 104712.59 0 ScriptEventCode 9008 iLineState=900 104712.59 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 104712.59 0 ReinitTelephony due to IDLE 104712.61 0 tapic lineDeallocateCall(MainCall:66155) 0 104713.06 0 lineOpen(0)=> 104713.10 0 Waiting for a call... 104713.10 0 LineHandle=66019 104713.11 0 amchk set AMdet=False in Reinit@idle 104713.11 0 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 104713.17 0 dial start any summary:|0:rdy=0| 104716.26 0 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 104716.26 0 ScriptEventCode 9013 iLineState=900 104716.39 0 dial start any summary:|0:idx=0| Any idea why this is happenning? Thanks in advance for your help. GGV Share this post Link to post
SupportTeam Report post Posted 07/22/2005 03:57 PM 104708.50 0 dtmf D (66155,68,2) ... 104708.61 0 Hanging up call... [Global End-of-Call DTMF (D)] The mode is reporting that is has heard DTMF tone "D" on the line, so VG hangs up the call. Your options are to re-record the message which is playing at the time this tone is detected or (better yet) get a Dialogic card instead of the modem. Share this post Link to post
