Guest amitginotra Report post Posted 07/26/2005 05:16 AM I am planning to use Voiceguide along with Brooktrout card. I will be using Brooktrout for another Fax application. I will be using Brooktrout TR114 card. Is it possible to use the same card for multiple applications at the same time. I mean, can voiceGuide and our Fax application use the same card simultaneously? Also, can I use Dialogic card with Multiple applications? Share this post Link to post
SupportTeam Report post Posted 07/26/2005 05:19 AM You should be able to VoiceGuide does not mind if some other application is using other lines on the card. Share this post Link to post
Guest amitginotra Report post Posted 07/26/2005 06:10 AM can you please refer me some customers who are successfully using VoiceGuide with Brookstrout card. Just I wana verify that there are not problem with its compatibilty. Share this post Link to post
SupportTeam Report post Posted 07/26/2005 06:50 AM As far as I know very few customers use Brooktrout. Pretty much all the customers use Dialogic. Share this post Link to post
