Guest Philipp Report post Posted 06/03/2003 11:05 AM Hi, I-m testing Voice Guide at the moment. I'm using a AVM Fritz Card PCI. It brings a Tapi Voice Modem Driver with it. For testing reasons I've tried to attach the Expample Scripts to it. But the incoming call is not accepted. It does nothing. Here's the Trace Log 79428 16 tapie callstate OFFERING 65809 1 4 89432 16 tapie callstate DISCONNECTED 65809,2,0 89432 16 ERROR 4.9.0 Unknown State [0] 89452 16 PlaySoundStop ok 89452 16 HangupCall called from [] 89452 16 Hanging up call... 89452 16 PlaySoundStop ok 89452 16 Waiting for a call... 89452 16 fnHangupCall end 89452 16 tapie callstate IDLE 65809 0 0 89452 16 WorkingMode@Idle=Offered 89452 16 LineState(iLineId).iVgsIdx = 0 89452 16 set EV_TIMEOUT_TIMETOREINITLINE 1 89472 16 set EV_TIMEOUT_TIMETOREINITLINE 2 89472 16 tapi Reply 65792 0 90433 16 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 90433 16 ReinitTelephony due to IDLE start 90433 16 tapic lineDeallocateCall(MainCall:65809) 0 90533 16 lineOpen(16) => 0 90533 16 Waiting for a call... 90533 16 lineOpen(16)LineHandle=65791 Share this post Link to post
SupportTeam Report post Posted 06/05/2003 01:54 PM This card's TAPI driver does not behave in the same way as a standard Voice Modem TAPI driver (or most other Telephony Cards/Devices TAPI drivers)... If you can obtain from AVM details on what the differences are, or how does AVM recommend for software to communicate with it's driver to make it work, and if the software changes required are not too great then I can see about having the VoiceGuide software modified to make it work with this card (this is not the first time somebody has asked about AVM Fritz Card PCI... I suspect getting VoiceGuide to work with AVM will be a long process and it's probably best to just purchase a Dialogic card... Share this post Link to post
