Guest Geoff Report post Posted 07/26/2005 11:57 PM Are you able to explain what your plans are for a VOIP version of VoiceGuide, and a generally overview of how it will work? It's new to a lot of us, and I'm still trying to get my head around how VOIP fits together with an IVR.... Is the idea that VG will communicate directly with the PC's broadband connection, rather than with a Dialogic (or similar) card that takes external calls? What kind of release time frame are we looking at? Thanks, Geoff Share this post Link to post
SupportTeam Report post Posted 07/27/2005 12:57 AM You can pretty much take any phone system and connect it up to VoIP lines using a VoIP media gateway. They are quite cheap and that is how most systems get connected up to VoIP lines without changing existing hardware. What type of system are you looking at setting up? Share this post Link to post
Guest Geoff Report post Posted 08/07/2005 12:31 PM I am investigating the possibilities of running VoiceGuide directly from a VOIP connection. Is that on the cards? Thanks Geoff Share this post Link to post
SupportTeam Report post Posted 08/07/2005 10:26 PM Right now the only way to do this is to use a Media Gateway. Share this post Link to post
