Mattm Report post Posted 07/28/2005 07:03 PM I wish to write a statement via built in module or VbScript that uses a result variable from a previous module, Say $RV[sampleModule] as a play file module and I want to use the result of the if, then statement in a query. I was trying to do a VbScript module named GetDescription like.... Dim ItemKey Dim Choice Choice=$RV[sampleModule] If Choice=1 then ItemKey=1359 else if Choice=2 then ItemKey=1360 else if Choice=3 then ItemKey=1500 else ItemKey=0 end if end if end if set vg = CreateObject("VoiceGuide.CommandLink") vg.RvSet $RV_LINEID, "ItemKey", ItemKey set vg = Nothing ' Then reference the result in a query module like so.... SELECT Description FROM ItemDesc WHERE Key=$RV[itemKey] I may be far off base with the way I am approaching this, I there is a better way feel free to suggest it or point me to a location in which I can find my answer. Thank you Share this post Link to post
SupportTeam Report post Posted 07/29/2005 02:24 AM From looking at it, it all seems spot on. The script should work just the way you wrote it. Have you tried it in VG yet? Share this post Link to post
Mattm Report post Posted 08/01/2005 02:14 PM When I run this in VG when it hits thre VBScript it takes the fail path. At level 0 this is the only error I receive. 091324.32 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range 091346.74 1 ERROR 6.0.2028 TW__LineEvCallState_Error:Subscript out of range Share this post Link to post
SupportTeam Report post Posted 08/01/2005 02:16 PM Is the VBScript returning an explicit 'Success' result or RV list to VG? If you are still haveing problems please increase level to 8 or higher and post trace and the VG script itself. Share this post Link to post
Mattm Report post Posted 08/01/2005 03:07 PM This is the log at level 8 around the VbScript 100534.04 1 event TDX_PLAY, code=129, state=6001 100534.04 1 timer clear 100534.04 1 state [GetItemKey] Running VB Script... 100534.04 1 rv replace start: [Dim ItemKey Dim Choice Choice=$RV[ProductChoice] If Choice=1 then ItemKey=1359 else if Choice=2 then ItemKey=1360 else if Choice=3 then ItemKey=1500 else ItemKey=0 end if end if end if ] 100534.05 1 vbs ran [vbs_1_1.vbs], cmd [wscript "C:\Program Files\VoiceGuide\data\vbs_1_1.vbs" //I //T:60] 100534.07 1 Run Script waiting. iRunWait=1 (shellid=2396, process=6212) 100534.07 1 timer set 1 EV_TIMEOUT_CHECKONSTATE 100535.07 1 event EV_TIMEOUT_CHECKONSTATE, code=9007, state=1501 100535.07 1 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 100535.07 1 task completed (shellid=2396, process=6212) vgm=29, iRunWait=1, iRunWait_ExeResult_NextVgm=0 100535.07 1 no result file returned from program (VGRUNRESULT_1.TXT or SHLRESLT.TXT) 100535.07 1 task completed LsRunWaitChooseNext iNextVgm=12 100535.08 1 fn RunModule start 100535.08 1 timer clear Share this post Link to post
SupportTeam Report post Posted 08/01/2005 11:40 PM The VBScript is not returning an explicit 'Success' result or RV list to VG... From: http://www.voiceguide.com/vghelp/html/modVbs.htm Quote A "Success" or Result Variable list must be returned to VoiceGuide (either though a Run_ResultReturn COM function or a Result File) in order for it to go down the Success path. If no result is returned then the "Fail" path is taken after the VBScript completes. Calls to Script_Gosub(), Script_Goto() and Script_Return() functions result in immediate running of the next module. Share this post Link to post
Mattm Report post Posted 08/02/2005 04:18 PM I used: Dim Key Dim Choice Choice=$RV[ProductChoice] If Choice=1 then Key="1300" else if Choice=2 then Key="1500" else if Choice=3 then Key="1600" else Key=0 end if end if end if set vg = CreateObject("VoiceGuide.CommandLink") vg.Run_ResultReturn $RV_LINEID, "[itemKey]{Key}" set vg = Nothing And it returned Key as the result variable not the 'value of Key. Is there anyway to fix that? Share this post Link to post
ktruk Report post Posted 08/02/2005 08:43 PM Change: Quote vg.Run_ResultReturn $RV_LINEID, "[itemKey]{Key}" to: Quote vg.Run_ResultReturn $RV_LINEID, "[itemKey]{" & Key & "}" You have to "build" the string by patching in the variable value. Share this post Link to post
Mattm Report post Posted 08/03/2005 06:40 PM Thanks that worked perfect. Share this post Link to post
