Call Disconnect
I am using VG for Dialogic. When I transfer the call, it gets disconnected during the first few minutes, I do not know what causes it to disconnect.
here is the log file:
145942.38 1 event TDX_CST, code=134, state=1201
145942.41 1 LsRecRecording EV_UNKNOWN_134,TDX_CST
145942.44 1 path {TDX_CST} not found
150030.48 1 tw DialogicEvent 134,TDX_CST,199,0,0,DE_TONEON,TID_RNGBK1,
150030.52 1 event RINGBACK, code=134, state=1201
150030.55 1 LsRecRecording EV_UNKNOWN_134,RINGBACK
150030.56 1 path {RINGBACK} not found
150030.59 1 event TID_RNGBK1, code=134, state=1201
150030.63 1 LsRecRecording EV_UNKNOWN_134,TID_RNGBK1
150030.64 1 path {TID_RNGBK1} not found
150030.67 1 event TDX_CST, code=134, state=1201
150030.70 1 LsRecRecording EV_UNKNOWN_134,TDX_CST
150030.72 1 path {TDX_CST} not found
150032.83 1 tw DialogicEvent 134,TDX_CST,194,0,0,DE_TONEON,TID_DIAL_INTL,
150032.84 1 event DIALTONE, code=134, state=1201
150032.88 1 LsRecRecording EV_UNKNOWN_134,DIALTONE
150032.91 1 path {DIALTONE} not found
150032.92 1 event TID_DIAL_INTL, code=134, state=1201
150032.95 1 LsRecRecording EV_UNKNOWN_134,TID_DIAL_INTL
150032.98 1 path {TID_DIAL_INTL} not found
150033.02 1 event TDX_CST, code=134, state=1201
150033.03 1 LsRecRecording EV_UNKNOWN_134,TDX_CST
150033.06 1 path {TDX_CST} not found
150040.45 1 tw DialogicEvent 134,TDX_CST,193,0,0,DE_TONEON,TID_DIAL_LCL,
150040.47 1 event DIALTONE, code=134, state=1201
150040.50 1 LsRecRecording EV_UNKNOWN_134,DIALTONE
150040.53 1 path {DIALTONE} not found
150040.55 1 event TID_DIAL_LCL, code=134, state=1201
150040.58 1 LsRecRecording EV_UNKNOWN_134,TID_DIAL_LCL
150040.61 1 path {TID_DIAL_LCL} not found
150040.63 1 event TDX_CST, code=134, state=1201
150040.66 1 LsRecRecording EV_UNKNOWN_134,TDX_CST
150040.67 1 path {TDX_CST} not found
150130.84 1 tw DialogicEvent 134,TDX_CST,194,0,0,DE_TONEON,TID_DIAL_INTL,
150130.88 1 event DIALTONE, code=134, state=1201
150130.91 1 LsRecRecording EV_UNKNOWN_134,DIALTONE
150130.94 1 path {DIALTONE} not found
150130.97 1 event TID_DIAL_INTL, code=134, state=1201
150130.98 1 LsRecRecording EV_UNKNOWN_134,TID_DIAL_INTL
150131.02 1 path {TID_DIAL_INTL} not found
150131.05 1 event TDX_CST, code=134, state=1201
150131.06 1 LsRecRecording EV_UNKNOWN_134,TDX_CST
150131.09 1 path {TDX_CST} not found
150136.75 1 event callstate DISCONNECTED 1 0 0
150136.78 1 event EV_REMOTEPARTY_DISCONNECT, code=9250, state=1201
150136.80 1 LsRecRecording EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
150136.83 1 path {EV_REMOTEPARTY_DISCONNECT} not found
150136.89 1 rv rec length: RecordCall_RecLen100ms = 1604
150136.92 1 rv add [RecordCall_RecLen100ms]{1604}
150136.97 1 rv add [RecordCall_EndRecCause]{disconnect}
150137.08 1 rv add [Hangup Time]{8/1/2005 3:01:37 PM}
150137.11 1 state Hanging up call... [During LsRecRecording]
150137.13 1 HangupCall_Common hCall=1
150137.16 1 rec RecSoundStop ok
150137.19 1 play PlaySoundStop ok
150137.22 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
150137.23 1 fnHangupCall end
150137.27 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_LCOF,,
150137.28 1 event TDX_CST, code=134, state=900
150137.31 1 LsAwaitingCalls EV_UNKNOWN_134
150137.34 1 tw DialogicEvent 130,TDX_RECORD,0,0,0,TM_USRSTOP,,
150137.38 1 event TDX_RECORD, code=130, state=900
150137.39 1 LsAwaitingCalls EV_UNKNOWN_130
150137.42 1 event EV_REC_FINISHED, code=8003, state=900
150137.44 1 LsAwaitingCalls EV_REC_FINISHED
150137.47 1 event callstate IDLE 1 0 0
150137.50 1 WorkingMode@Idle=
150137.52 1 timer clear
150137.55 1 rec RecSoundStop ok
150137.58 1 play PlaySoundStop ok
150137.59 1 rv add [CallEndTime]{8/1/2005 3:01:37 PM}
More then likely your disconnect tone definition is not narrow enough and you are getting false detections of disconnect tone.
Please post the 'tw' trace capturing the hangup - it will show more detail of what is happening.
(You can enable the automatic saving of the logs to files in \log\ directory.)
Where do you find the disconnect tone definition. Please keep in mind that I am using VG for Dialogic.
