Concatenate
Hello!
My problem is that when I concatenate several rows from a query into a variable and then I want to send this info to somebody via email I can see that the variable contains all the rows but I can also see the operators used to concatenate.
In a Evaluation expression module I initialize a variable, namely SMS, that will contain all the rows from a query. In another Evaluation exp. module I want to concatenate every row from the query and even if I´ve tried with both operators "+" and "&" with the following expression, I still can see them in the email.
"$RV[sMS]"&"$RV[CASE bank_1_1]"&";"&"$RV[CASE bank_2_1]"&"/"&"$RV[CASE bank_3_1]"&Chr(10)
Can you help me?
Jose
Can you post the entire script?
As a start, try changing to this:
"$RV[sMS]$RV[CASE bank_1_1];$RV[CASE bank_2_1]/$RV[CASE bank_3_1]" & Chr(10)
Hello!
Still the same problem. When I try with this:
I still can see the & sign and the new line character does not work. Here comes the output:
SAS;+4687620460/NULL
VW;+4686951701/NULL & Chr(10)SEB;020775500/+468775500 &
Chr(10)Visa;020793146/+14105819994* & Chr(10)
I send you the script. Thank you for your help!
Jose
blockdirekt.vgs
I see you are using the Evaluate Expression module, not a VBScript module...
Just use this:
Try using another Evaluate Expression module to assign linefeed to another variable, and then you can use that RV as part of expression. ie. assign this expression:
Chr(10)
to an RV - say $RV[LF] - and then you can use
$RV[sMS]$RV[CASE bank_1_1];$RV[CASE bank_2_1]/$RV[CASE bank_3_1]$RV[LF]
But you may just want to look at using VBScript for creating this string.
Hello!
I think I was not clear enough. What I need is to have a variable, called SMS, that will contain between 3 or 4 rows from a query to a DB and I need to have a linefeed after each row. For example:
Since the variable SMS is empty from the beginning the first row is ok and the linefeed works fine there, but when I try to concatenate the second row then things happen like the linefeed does not work any more and I get the + operator everywhere.
I have declared Chr(10) in a own variable and I do as you suggested but still have problems.
Thank you for your help,time!
Jose
If you want to concatenate multiple returned fields from multiple returned rows then its easier to just use VBScript to do this.
There is a recent thread on this very similar topic:
http://voiceguide.com/forums/index.php?showtopic=3083
Basically in your case you want to do something like this in a VSCript module:
for i = 1 to $RV[CASE bank_RowCount]
 s1 ="RV[CASE bank_1_" & i & "]"
 s2 = "RV[CASE bank_2_" & i & "]"
 s3 = "RV[CASE bank_3_" & i & "]"
 sReturnValue = sReturnValue & vg.RvGet($RV_LINEID, s1) & ";" & vg.RvGet($RV_LINEID, s2) & "/" & vg.RvGet($RV_LINEID, s3) & vbCrLf
next
vg.Run_ResultReturn $RV_LINEID, "[SMS]{"& sReturnValue &"}"
set vg = Nothing
Then $RV[sMS] should then contain all the data formatted with a CRLF between each row.
Please modify your script appropriately and if you still have problems please post the script and the trace capturing the call.
Hello!
Thnak you! Now it is working as it should but I have another problem: Inside a VBS module I need to know the length of two variables that I created in an Evalutate exp. module.
I cannot find anything any help and I am trying whithout any luck. I have this:
sms="RV[sMS]"
if len(sms) > 70 then
vg.Run_ResultReturn $RV_LINEID, "success"
but no matter the length of the variable I know get "success". I have also tried
with:
if len("$RV[sMS]") > 70 then
and
if len($RV[sMS]) > 70 then
but without any luck.
Thank you!
Jose
When running the module, in VoiceGuide's trace log you will see a reference to a .VBS file that VG creates with all of the RVs replaced with their values - please post the file that the trace log entry refers to.
File will be called something like this: vbs_X_Y.vbs and is located in VG's \data\ subdirectory.
The log entry will look something like this:
085823.69 10 vbs ran [vbs_10_1.vbs], cmd [wscript "c:\Program Files\VoiceGuide\data\vbs_10_1.vbs" //I //T:10]
