Set Variables
Your SQL statement should probably be this:
INSERT INTO T_CDC (NUMCDC) VALUES ('$RV[GetCode]')
But if NUMCDC field is defined to be a number field then the SQL statement should probably be this:
INSERT INTO T_CDC (NUMCDC) VALUES ($RV[GetCode])
Is this what you're asking about or are you asking about something else?
What module use to save phone number pressed on phone by client in a variable " getphonenumber"
If you want to save the information is a database then you would use the "Db Query" module... which looks like you are using right now...
