Select (ms Access) Statement In Vbs
Dears,
I have not yet given up, but thought it would be faster if I consult you. I am receiving an error with the following details:
Error: No Value given for one or more required parameters
Code: 80040E10
Source: Microsoft JET Database Engine
The VBScript is not able to evalue the experssion with the SELECT statement:
rs.Open "SELECT FileNo, mobileno FROM appfile WHERE FileNo = ModuleData", cn, adOpenStatic
I have placed a msgbox() before and after the statement to make sure that the connection to the database was established. The Variable ModuleData contacins the value that was returned from a previous Database Quert Module and the msgbox() function displays the contents.
I have tried placing the $RV[GetFileNumber] with no luck, and tried placing it as '$RV[GetFileNumber]' but it returned an empty string.
Any comments or suggestions? I am attaching the script to this message:
Const adOpenForwardOnly = 0
Const adOpenKeyset = 1
Const adOpenDynamic = 2
Const adOpenStatic = 3
'Const vbGeneralDate = 0
'Const vbLongDate = 1
'Const vbShortDate = 2
'Const vbLongTime = 3
'Const vbShortTime = 4
DIM PrevModuleName
DIM ModuleData
DIM FNo, MNo, HNo
PrevModuleName = "$RV_PreviousModule"
set cn = CreateObject("ADODB.Connection")
cn.Open "Provider=MicroSoft.Jet.OLEDB.4.0;Data Source=$RV[scriptPath]\appdb.mdb"
if cn.State = 1 then
vg.Admin_TraceLogAdd $RV_LineID, 5, "vbs connection to APPDB.MDB made ok"
set rs.ActiveConnection = cn
'msgbox("Successfull Connection to the Database was established")
SELECT Case PrevModuleName
Case "QryFileNo"
ModuleData = "$RV[File Number]"
msgbox(ModuleData & " " &PrevModuleName)
msgbox("[" & MobileNo & "]")
Case "QryMobileNo"
msgbox(ModuleData & PrevModuleName)
Case "QryHomeNo"
End SELECT
else
msgbox("I am sorry, but I was not able to connect to your database")
End if
cn.Close
Set rs = nothing
Set cn = nothing
Set vg = nothing
Instead of
use:
"SELECT FileNo, mobileno FROM appfile WHERE FileNo = " & ModuleData
ie:
rs.Open "SELECT FileNo, mobileno FROM appfile WHERE FileNo = " & ModuleData, cn, adOpenStatic
ModuleData is the variable containing your data...
If you still have problems please post your entire script.
Hi There,
I tried the solution, which made the case better, but I am still not getting the result I am looking for.
The ModuleData contains that result variable of a "Get Numbers" Module that is an integer variant. I have converted it using the cSTR function, but then received an error that it is not quoted using (") <= CHR(34) or (') <= CHR(39) to when I have added those using ModuleData = CHR(34) & CSTR($RV[FILE NUMBER]) & CHR(34)
Now, the script is executing, but the msgbox is returing an empty result that tells me that the condition in the SELECT statement is not becoming TRUE.
I am attaching the VoiceGuide Script for your review and comments. (I have attached it to my previous post, but the forum didn't show it :( )
PS. The MS Access DB details is as follows:
DB Name: APPDB
Table Name: APPFILE
Table Structure:
FileNo : TEXT, Size 15
MobileNo: TEXT, Size 15
HomeNo: TEXT, Size 15
The script still did not get attached.
Please email the script to support@voiceguide.com (refrenceing this post in the email) and we will look at it.
In the script there is first query made using a DBQuery module and then another query is made inside the VBScript module as well.
The queries are the same - so the one made in the DBQuery module should be sufficient - do the DBQuery modules return the right data for you?
You may need to specify the column and table names exacly as well - Mobileno and MobileNo may not mean the same thing and maybe that's why you are getting errros.
Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what happens.
Also, in DBQuery modules the database is specified as residing in:
C:\Documents and Settings\Aziz\Desktop\Jobs Phone\Appointment System\APPDB.mdb
Where is the APPDB.mdb actually located?
Please also post the APPDB.mdb file (or email it to us and we will post it).
The_Automated_Appointement_System_v2.1.vgs
Glad to hear it's all resolved.
Looks like you have changed the fields to match the caps with the names in database.
