Incorrect Start Module
I am a new user, using an outbound application. Very frequently the log file indicates that only 1 in 3 calls are started with the start module stipulated in the script. Is there a reason for this? The system configurations all point to the same script which has a specified start module.
Also, it seems to take my system (with dialogic cards) on average 30 seconds to make an incomplete call. Is there a way to shorten this cycle?
Thanks,
Peter
Could you please post a copy of VoiceGuide's Debug Printout which captures the incoming calls, this will allow us to see what is happening.
