Say Numbers
I see files vbs_5_SayNumber.vbs thru vbs_16_SayNumber.vbs for
Dialogic ports within the data subfolder.
I made few changes to TimeHHNN function not to pronounce Zero Zero
on even hour, but VG ignores it how can I make it consider my changes.
if left(sNN, 1) = "0" Then
if Right(sNN, 1) = "0" Then
sNN_WavList = tens2wav(sHH) & "," & ".wav"& sAMPM
Exit Function
Else
sNN_WavList = "0.wav," & Right(sNN, 1) & ".wav"
end if
Else
sNN_WavList = tens2wav(sNN)
end if
TimeHHNN = tens2wav(sHH) & "," & sNN_WavList & "," & sAMPM
Please try changing the TimeHHNN function entry in lib_num2wav.vbs file to:
'name : Time am/pm - HHNN
'info : Say the hour and minute in am/pm format
'arg1 : Time in format HHNN or HH:NN
Function TimeHHNN(ByVal arg1)
arg1 = replace(arg1, ":", "")
If Len(arg1) < 4 Then
  Exit Function
End If
sHH = Left(arg1,2)
sNN = Right(arg1,2)
If sHH >= 12 Then
  sHH = sHH - 12
  if sHH = 0 then
    sHH = "12"
  end if
  if sHH < 10 then
    sHH = "0" & sHH
  end if
  sAMPM = "pm.wav"
Else
  sAMPM = "am.wav"
end if
if left(sHH, 1) = "0" Then
  sHH_WavList = Right(sHH, 1) & ".wav"
Else
  sHH_WavList = tens2wav(sHH)
end if
  if Right(sNN, 1) = "0" then
    'do not play anything for minutes,
    sNN_WavList  = ""
  else
  end if
Else
end if
if sNN_WavList <> "" then
else
  'could add an "o'clock" sound file here...
  TimeHHNN = tens2wav(sHH) & "," & sAMPM
end if
End Function
