ktruk Report post Posted 08/08/2005 10:13 PM 1. Hi, I am currently using vg4tapi, behind a pabx, and wondered if I could switch a fax call to a dedicated fax extention on the pabx, using a call transfer module? (blind transfer). If tapi does not support this, does the dialogic version? 2. You have posted a new release of vg4dialogic. Any chance of a "new/fixed features list" to go wth it? Thx. Share this post Link to post
SupportTeam Report post Posted 08/14/2005 12:42 AM In TAPI version you should be able to use this path: on {fax} goto [ModuleTitle] Which can lead to a Call Transfer module. I understand the new release was to address the error which some users experienced when exiting VgMulti.exe Share this post Link to post
Dan Clements Report post Posted 08/24/2005 02:33 AM How do we do this in the Vg 4 dialogic version? I have an old D/41d that can detect a fax tone. I just want to transfer any faxes to a fax ext connected to external hardware. Also I am using VG pro 4 line addition ver 6.0.1020 should it be upgraded? What is the cost. I notice that this version doesn’t retain the script settings when powered down. The scripts must be re-selected on reboot. Thanks Dan Clements Share this post Link to post
SupportTeam Report post Posted 08/24/2005 02:52 AM Same path will work in VG for Dialogic as well. It should work in your current version. If you want to update to latest version - your current registration code should work OK. I notice that this version doesn’t retain the script settings when powered down. The scripts must be re-selected on reboot. The scripts need to be set in Config.xml file in VG's \data\ subdirectory. Share this post Link to post
