Create A Csv File
August wrote:
I'm very interested in your IVR product. I believe it will do what we need
it to do, except I have one question. We are creating a script for
Do-Not-Calls. We ask the caller to put in their phone number with area code
and confirm that it is correct. Is there a simple way to create a CSV file
with just the correct number?
Here is a sample VBScript code for saving contents of a Result Variable to a file.
This VBScript will save the number entered in module titled "Get Phone Number" to file c:\output.csv
Const ForReading = 1
Const ForWriting = 2
Const ForAppending = 8
set fso = CreateObject("Scripting.FileSystemObject")
set tsFile = fso.OpenTextFile("c:\output.csv", ForAppending, True)
tsFile.WriteLine "$RV[Get Phone Number]"
tsFile.Close
set tsFile = Nothing
set fso = Nothing
You can add more (comma delimited) information to be saved as required.
The script you sent me works for an hour our two but then it locks up and the phone line stays busy. It also does not complete sucessfully to move to the next step. I have to set it to fail to move to the next step. I removed this script and the system does not lock up.
Are you using an evaluation version of the software or a registered version?
Are you using a Dialogic card or a Voice modem?
A significant amount of Voice modem based system will crash due to problems in voice modem drivers. This is a known problem with voice modem based systems and one of the reasons why we do not recommend using them.
For a reliable system get a Dialogic card.
This card can be used.
You will need to switch to using "VoiceGuide for Dialogic" though - see our WWW Downloads page.
