Busy Signals.
We are using 4 lines for both outbound and inbound calls. We are having a problem when a caller is in the middle of a script on an inbound line and a second caller tries to dial in on the same number. Instead of getting a busy signal, it seems to freeze VG on the module the 1st caller was listening to when the second call attempts to connect to that same phone line. Any suggestions on how to prevent this interruption of the calls in progress?
