Protected Script Generates Unprotected Vbs File
I have saved a vg script as protected (*.vgp) to prevent exposure of mySQL database password. It includes a run VB Script module that logs call results to the database.
I find that vg generates a vbs file from the script in this module.
Is there any way to prevent this. If not, is there a scheme for naming the generated vbs file so that I can delete it after the script is run.
Thanks.
The filename used is in format:
vbs_iLineId_iCounter.vbs
Value of iLineId can be accessed using $RV_LINEID.
Value of iCounter starts at 1 for first vbs script ran during a call, and is incremented by 1 for each successive VBS ran on the call.
It is possible to tell from within the VBScript ran as to what is the filename of the running script - use Wscript.ScriptFullPath or Wscript.ScriptName
