Vg For Dialogic Sound Format
It appears that VG for Dialogic needs the PCM 8000Hz 8 bit mono sound files. I had previously used Mu-law for the TAPI version and used pro promts to convert them when upgrading to VG 4 Dialogic. The sound files were all converted to 11500 Hz and sound distorted when played thur the card. Are the 8000 Hz system sound files available any where? I can't seam to find them
Dan Clements
Please follow instructions in the VG for Dialogic's readme.txt file - it tells you how to install VG to have 8kHz sound files installed.
