Guest elSueco Report post Posted 08/25/2005 04:52 PM Hello! I am using the PBX announced transfer option. It works fine when I call a person and this person answer the phone. But if this person, for some reason, does not answer the phone then I would like to make another call in my application and here it is where the problem appears. I see that VG hangs up on the first call and I also see that VG tries to make the second call, but instead of calling to this second phone number it is on my own phone where I hear the file \VoiceGuide\system\voice\TsfrAskAccept.wav. Here it is what I get in the file 0825vgm Quote 184909,14 12 [Call_locksmith_both] Announced Transfer to 084429042 (Generate) 184909,14 12 tapic lineGenerateDigits(65624 [!] 100) => ok 184909,80 12 generate LINEGENERATETERM_DONE 184909,80 12 timer set 1 EV_TAPI_GENERATE 184910,89 12 timer fired EV_TAPI_GENERATE 184910,89 12 ScriptEventCode 9602 iLineState=1900 184910,89 12 LsXferStart EV_TAPI_GENERATE 184910,89 12 timer set 1 EV_HOOKFLASHFINISHED 184912,08 12 timer fired EV_HOOKFLASHFINISHED 184912,08 12 ScriptEventCode 9200 iLineState=1905 184912,08 12 LsXferPlayVts EV_HOOKFLASHFINISHED 184912,08 12 tapic lineGenerateDigits(65624 [084429042] 100) => ok 184913,78 12 generate LINEGENERATETERM_DONE 184913,78 12 timer set 1 EV_TAPI_GENERATE 184914,81 12 timer fired EV_TAPI_GENERATE 184914,81 12 ScriptEventCode 9602 iLineState=1905 184914,81 12 LsXferPlayVts EV_TAPI_GENERATE 184914,81 12 [Call_locksmith_both] Playing (call_transfer.wav) 184914,81 12 play set playid=738312 184914,81 12 PlaySoundStart ok [C:\Voice\Locksmith\call_transfer.wav] 184914,81 12 timer clear 184914,81 12 wa(10464,73831200) 184914,81 12 callinfo MONITORMODES 184925,34 12 play end current play (playid=738312) 184925,34 12 ScriptEventCode 8001 iLineState=1906 184925,34 12 LsXferPlayAnn EV_PLAY_FINISHED 184925,34 12 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 184925,34 12 [Call_locksmith_both] Playing (call_transfer.wav) 184925,34 12 play set playid=748843 184925,36 12 PlaySoundStart ok [C:\Voice\Locksmith\call_transfer.wav] 184925,36 12 timer clear 184925,36 12 wa(10464,74884300) 184925,36 12 callinfo MONITORMODES 184935,89 12 play end current play (playid=748843) 184935,89 12 ScriptEventCode 8001 iLineState=1906 184935,89 12 LsXferPlayAnn EV_PLAY_FINISHED 184935,89 12 LsXferPlayAnn EV_TIMEOUT_REPLAYMSG 184935,89 12 [Call_locksmith_both] Playing (call_transfer.wav) 184935,89 12 play set playid=759390 184935,91 12 PlaySoundStart ok [C:\Voice\Locksmith\call_transfer.wav] 184935,91 12 timer clear 184935,91 12 wa(10464,75939000) 184935,91 12 callinfo MONITORMODES 184946,44 12 play end current play (playid=759390) 184946,44 12 ScriptEventCode 8001 iLineState=1906 184946,44 12 LsXferPlayAnn EV_PLAY_FINISHED 184946,45 12 tapic lineGenerateDigits(65624 [!] 100) => ok 184947,11 12 generate LINEGENERATETERM_DONE 184947,11 12 timer set 1 EV_TAPI_GENERATE 184948,17 12 timer fired EV_TAPI_GENERATE 184948,17 12 ScriptEventCode 9602 iLineState=1906 184948,17 12 LsXferPlayAnn EV_TAPI_GENERATE 184948,17 12 eng PlayFinishCause=CallAcceptWaitTimedOut 184948,17 12 eng Going down Timeout path (iXferType=1) 184948,17 12 timer clear 184948,17 12 [Play 5] Playing 184948,17 12 [Play 5] Playing (tack message.wav) 184948,17 12 play set playid=771671 184948,17 12 PlaySoundStart ok [C:\Voice\Locksmith\tack message.wav] 184948,17 12 timer clear 184948,17 12 RunModule PLAY end 184948,17 12 wa(6759,77167100) 184948,17 12 callinfo MONITORMODES 184954,95 12 wb(77167100) 184955,02 12 play end current play (playid=771671) 184955,02 12 ScriptEventCode 8001 iLineState=1100 184955,02 12 LsPlayMsg EV_PLAY_FINISHED 184955,02 12 timer set 10 EV_TIMEOUT_HANGUP 184955,02 12 timer set 0 EV_TIMEOUT_GOTOMODULE 184955,02 12 ScriptEventCode 9002 iLineState=1101 184955,02 12 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 184955,02 12 rv lg add [Play 5]{timeout} 184955,02 12 timer clear 184955,02 12 timer set 0,4 EV_TIMEOUT_READYTOBEGINTRANSFER 184955,45 12 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 184955,45 12 ScriptEventCode 9012 iLineState=1900 184955,45 12 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 184955,45 12 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 184955,45 12 [Transfer Call 19] Announced Transfer to 0739389890 (Generate) 184955,45 12 tapic lineGenerateDigits(65624 [!] 100) => ok 184956,11 12 generate LINEGENERATETERM_DONE 184956,11 12 timer set 1 EV_TAPI_GENERATE 184957,20 12 timer fired EV_TAPI_GENERATE 184957,20 12 ScriptEventCode 9602 iLineState=1900 184957,20 12 LsXferStart EV_TAPI_GENERATE 184957,20 12 timer set 1 EV_HOOKFLASHFINISHED 184958,36 12 timer fired EV_HOOKFLASHFINISHED 184958,36 12 ScriptEventCode 9200 iLineState=1905 184958,36 12 LsXferPlayVts EV_HOOKFLASHFINISHED 184958,36 12 tapic lineGenerateDigits(65624 [0739389890] 100) => ok 185000,27 12 generate LINEGENERATETERM_DONE 185000,27 12 timer set 1 EV_TAPI_GENERATE 185001,31 12 timer fired EV_TAPI_GENERATE 185001,31 12 ScriptEventCode 9602 iLineState=1905 185001,31 12 LsXferPlayVts EV_TAPI_GENERATE 185001,31 12 [Transfer Call 19] Playing (call_transfer.wav) 185001,31 12 play set playid=784812 185001,31 12 PlaySoundStart ok [C:\Voice\Locksmith\call_transfer.wav] 185001,31 12 timer clear 185001,31 12 wa(10464,78481200) 185001,31 12 callinfo MONITORMODES 185010,42 12 dtmf 1 (65624,49,2) 185010,42 12 ScriptEventCode 49 iLineState=1906 185010,44 12 LsXferPlayAnn 1 185010,44 12 rv lg add [Transfer Call 19]{1} 185010,44 12 timer set 1 EV_PLAY_FINISHED 185010,48 12 PlaySoundStop err=0 185010,48 12 dtmf 1 (65624,49,2) 185010,48 12 ScriptEventCode 49 iLineState=1906 185010,48 12 LsXferPlayAnn 1 185010,48 12 rv lg add [Transfer Call 19]{1} 185010,48 12 timer set 1 EV_PLAY_FINISHED 185010,48 12 PlaySoundStop err=0 185011,50 12 timer fired EV_PLAY_FINISHED 185011,50 12 ScriptEventCode 8001 iLineState=1906 185011,50 12 LsXferPlayAnn EV_PLAY_FINISHED 185011,50 12 ScriptEventCode 9602 iLineState=1906 185011,50 12 LsXferPlayAnn EV_TAPI_GENERATE 185011,50 12 eng PlayFinishCause=CallAccepted 185011,50 12 eng Success path not defined - hanging up (iXferType=1) 185011,50 12 timer set 1 EV_TIMEOUT_HANGUP 185012,59 12 timer fired EV_TIMEOUT_HANGUP 185012,59 12 ScriptEventCode 9001 iLineState=1906 185012,59 12 LsXferPlayAnn EV_TIMEOUT_HANGUP 185012,59 12 rv lg add [Hangup Time]{2005-08-25 18:50:12} 185012,59 12 Hanging up call... 185012,59 12 RecSoundStop ok 185012,59 12 PlaySoundStop err=0 185012,59 12 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP 185012,59 12 fnHangupCall end 185012,64 12 linedevstate 2048 0 0 185012,64 12 callstate IDLE 65624 0 0 185012,64 12 WorkingMode@Idle= 185012,64 12 timer clear 185012,69 12 timer set 1 EV_TIMEOUT_TIMETOREINITLINE 185012,70 12 tapi Reply (LineEvReply) ok 66393 0 185013,69 12 timer fired EV_TIMEOUT_TIMETOREINITLINE 185013,69 12 ScriptEventCode 9008 iLineState=900 185013,69 12 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 185013,69 12 ReinitTelephony due to IDLE 185013,69 12 tapic lineDeallocateCall(MainCall:65624) 0 185013,75 12 lineOpen(12)=> 185013,75 12 Waiting for a call... 185013,75 12 LineHandle=66017 185013,75 12 amchk set AMdet=False in Reinit@idle 185013,75 12 timer set 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 185013,80 0 dial start any summary:|6:dok=0|7:dok=0|8:dok=0|9:dok=0|10:idx=0|11:idx=0|12:rdy=0|13:idx=0| 185017,03 12 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 185017,03 12 ScriptEventCode 9013 iLineState=900 What am I doing wrong? Any help? Thank you ! Jose Share this post Link to post
SupportTeam Report post Posted 08/25/2005 11:50 PM Which version of VoiceGuide are you using? Are you using a Dialogic card? Share this post Link to post
Guest elSueco Report post Posted 08/26/2005 08:08 AM Hello! Quote Which version of VoiceGuide are you using? VoiceGuide version 5.2.4000 Enterprise, VG Dialer. Quote Are you using a Dialogic card? Yes, D/41 JCT. I do not understand how this work. What I am trying to do is the following: Phone A calls my application, and the application tries to call Phone B; now if Phone B answers then voiceguide completes the transfer and Phone A speaks to Phone B. But when Phone B does not answer the call, then the application should call Phone C, but this is what happens depending on: - If Phone A did not hang up then it is Phone A which listens to the sound file before accepting the call which I think it is wrong since it is Phone A that made the call. - If Phone A did hang up then the application will call Phone C and when Phone C pick up the call, first I hear the sound file before accepting the call and when Phone C accepts the call the only thing I hear it is some music. However, Phone A hanged up before, so why is the application calling Phone C? Thank you! Jose Share this post Link to post
SupportTeam Report post Posted 08/26/2005 08:51 AM Please switch to using VG for Dialogic and try the transfers again. Your current registration code will work. Share this post Link to post
Guest elSueco Report post Posted 08/28/2005 12:20 PM Hello! Quote Please switch to using VG for Dialogic and try the transfers again. [/code] I do not think I understand your answer. Could you explain what you mean by switching to using VG for Dialogic? Or could you tell me where I can read the information that I need? Thank you! Jose Share this post Link to post
SupportTeam Report post Posted 08/28/2005 08:31 PM On our WWW's Downloads page you will see a link to "VoiceGuide for Dialogic" (v6.0.2092). Please download that patch and install on your system. Share this post Link to post
Guest elSueco Report post Posted 09/02/2005 09:44 AM Hello! I have installed this patch and nothing works as it used to even though I followed the instrucctions according to the Readme file. I am using voiceguide version 6.0.2001 and I have two cards in my computer; D/41 JCT-LS and D/4PCI. So I have edited the Config.xml file so that voiceguide will control the eight lines. So far so good, but when I try to use the button "Setup wizard" to select the script for each line, it pops up a window saying "Edit the LinesConfig.xml file" which does not exist. However, there is another file "ConfigLine.xml" which I don´t know if it is this one the popup window means and even if it means this file I don´t know what I have to edit. Anyway, I could select the script for each line and run the current script but its behaviour was very strange; for example when I called the script and the script started running then I just hanged up the phone but the script continued. Here I send you the two files (Config.xml and ConfigLine.xml) in case it may help you to understand my problems. Thank you for your help! Jose Config.zip Share this post Link to post
SupportTeam Report post Posted 09/02/2005 02:04 PM Quote then I just hanged up the phone but the script continued. On analog lines yon need to set the disconnect tone correctly in order for the Dialogic card to know what tone to listen out for when call is ended. The tone is set "ConfigLine.xml". What does the disconnect tone on your system sound like? Can you .ZIP up a recording of it and post it here? Share this post Link to post
Guest elSueco Report post Posted 09/06/2005 03:05 PM Hello! Quote What does the disconnect tone on your system sound like? Can you .ZIP up a recording of it and post it here? I opened this file in the audacity program (View->Plot Spectrum) but I can´t see how to obtain the values that I have to update in the ConfigLine.xml file. Could you help me with that? Thank you! Jose disconnectTone.zip Share this post Link to post
SupportTeam Report post Posted 09/06/2005 10:12 PM The attached recording is very short and does not contain any porting of th disconnect tone. To record the disconnect tone start the record module in VG Script, and Hangup the call when the script reaches that module. Share this post Link to post
Guest elSueco Report post Posted 09/07/2005 01:26 PM Hello! Thank you for your help! Jose disconnectTone.zip Share this post Link to post
Guest Guest Report post Posted 09/09/2005 10:21 AM Hello, I wonder if you got some information from the last file (disconnectedTone.zip), and could you tell me where (TSP, DCM or ConfigLine.xml )I have to introduce these values? Thank you! Jose Share this post Link to post
SupportTeam Report post Posted 09/09/2005 01:05 PM 1. open the file in Audacity 2. highlight the section of the sound file where the tone is present 3. Go to "View" menu and select "Plot Spectrum" 4. Note at what frequency the peak(s) is/are. 5. measure lengths of on/off times by highlighting these sections and looking at the selection's timing data at bottom of Audacity's window. Share this post Link to post
SupportTeam Report post Posted 09/09/2005 11:44 PM Also please see: http://www.voiceguide.com/vghelp/html/Disc...ctionDetect.htm Share this post Link to post
