Digits Are Duplicated
Using Dialogic D/42-NS and Norstar 616.
During all "Getnumbers" operations, the touch tones are doubled. For example, I press "1" on the phone keypad and VoiceGuide displays "11" as the digits entered.
Any ideas?
Sounds like there is a problem with either the phone that is used or with the Dialogic card itself...
Are you using the latest Dialoigc drivers (System Release 5.1 or later)?
