Transfer Call
Hello,
I am using 3 way call in transfer call module.
The connection accrue and the message to accept the call will play without any problem, then the path goes to module to take track of conversation time.
The other party phone ring and h/she will press 1 to accept the call, but unfortunate two party can not hear each other.
I can not thing of any reason why two parties can not hear each other.
Any advice would be appreciate.
Farzad
