TTS in Get Numbers module
I am new to this how do I go from Play detail to Get Code? Pla Detail waits for a keypress and I want it to go to get code after it plays my text message.
Just specify a text file (.txt) as the file to be played. The text in that file will be TTS'd and played.
That's cool. But what if I want to read stuff from my database. Can I include variables in the txt file?
Version=5.0
DefaultModuleDisplayHeight=
StartModule=GetClientRecord
RunAtHangup=
StartWithoutAnswer=0
CtmAsiName=
[GetClientRecord]
Type=Database Query
DispSize=69
Txt=Retrieve info from database for this client using Caller ID (or the phone number dialed)
DbDatabase=C:\Documents and Settings\Dovid\My Documents\TVR\TVR.mdb
DbUser=
DbConnectString=
DbSql=SELECT Company, OrderName, OrderAmount, OrderCode, ID FROM Accounts, Transactions WHERE Accounts.AccountID=Transactions.AccountID
on {success} goto [PlayDetails]
on {fail} goto [ClientNotFound]
on {success} goto [GetOrderCode]
Position=120,28
[GetOrderCode]
Type=Get Numbers
DispSize=69
Txt=Play a prompt asking the caller to enter a sequence of numbers, speak the sequence back to the caller and ask them to confirm it. Go down different paths depending on the numbers entered...
PlayFile1=welcome.txt
Replay=2,5
GetNbrLen_Min=0
GetNbrLen_Max=0
Confirm=ON
VbScript=
en = Len("$RV_ENTEREDNUMBER")
if $RV[GetClientRecord_4_1] = en then
sResult = "verify_failed"
else
sResult = "verify_passed"
end if
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
VbsHoldPlay=
on {success} goto [update Passed]
on {fail} goto [update Failed]
Position=105,283
[update Passed]
Type=Database Query
DispSize=69
Txt=Update the confirmed field in the database.
DbUser=
DbConnectString=
DbSql=UPDATE TRANSACTIONS SET CONFIRMED = NOW(), PassFail = 'P' WHERE ID = $RV[GetClientRecord_5_1]
Position=464,241
[update Failed]
Type=Database Query
DispSize=69
DbUser=
DbConnectString=
DbSql=UPDATE TRANSACTIONS SET CONFIRMED = NOW(), PassFail = 'F' WHERE ID = $RV[GetClientRecord_5_1]
Position=464,340
You will need to update to v5.2.5 (current release)
v5.2.5 can play .txt files as TTS.
v5.2.3 could not.
It's working now but one problem. It dials and doesn't wait for someone to pickup before it starts the script?
This is the log...right after it dials it goes straight into the script without waiting for the someone to answer....
173358.88 0 dial [33,17186986838,509091732,1,2359,MoTuWeThFrSaSu,,3,NONE,C:\Documents and Settings\Dovid\My Documents\TVR\TVR.vgs,NONE,none,60,2,120,,none]
173358.88 0 rv clear
173358.88 0 dial callque update id=33 next call time 0509091933
173358.89 0 dial callque DB update returned
173358.89 0 amchk set AMdet=False in DialOnLine
173358.89 0 dial found entry: tel[17186986838] ann[NONE] vgs[C:\Documents and Settings\Dovid\My Documents\TVR\TVR.vgs] am[NONE] LineSelection:[]
173358.91 0 Dialing: 17186986838
173358.92 0 MakeCall => 65604
173358.92 0 script interpretor: VgMulti v5.2.5003
173358.92 0 timer set 60 EV_TIMEOUT_MAKECALL_NORESPONSE
173358.94 0 TapiCbTrigSet 65604 7002
173358.95 0 dial start any summary:|0:dial=0|
173358.97 0 tapi Reply (LineEvReply) ok 65604 0
173358.97 0 TapiCbTrigClear
173358.97 0 callstate DIALING 65570 0 0
173358.98 0 callstate PROCEEDING 65570 0 0
173359.95 0 dial start any summary:|0:hc>0|
173402.00 0 callstate CONNECTED 65570 0 0
173402.02 0 callstate CONNECTED 65570,0,0
173402.02 0 WorkingModeTAPI@Connected=
173402.03 0 WorkingModeScript@Connected=
173402.03 0 rv lg add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
173402.05 0 rv lg add [PathApp]{C:\Program Files\VoiceGuide\}
173402.05 0 rv lg add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
173402.06 0 rv lg add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
173402.06 0 rv lg add [OutDial_RetriesLeft]{2}
173402.08 0 rv lg add [$RV_STARTTIME]{9/9/2005 5:34:02 PM}
173402.08 0 rv lg add [$RV_DEVICEID]{0}
173402.09 0 rv lg add [$RV_CIDNAME]{}
173402.09 0 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
173402.11 0 rv lg add [$RV_CALLEDNUMBER]{17186986838}
173402.11 0 rv lg add [$RV_DNIS]{}
173402.11 0 rv lg add [DNIS]{}
173402.13 0 Dialing: Playing introduction message
173402.13 0 StartLoadedVgs at 9/9/2005 5:34:02 PM, script interpretor VgMulti v5.2.5003 0
173402.14 0 rv ns add [scriptsPath]{C:\Documents and Settings\Dovid\My Documents\TVR\}
173402.14 0 rv ns add [scriptPath]{C:\Documents and Settings\Dovid\My Documents\TVR}
173402.16 0 rv lg add [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}
173402.16 0 rv lg add [PathApp]{C:\Program Files\VoiceGuide\}
173402.17 0 rv lg add [PathDataVm]{C:\Program Files\VoiceGuide\data\}
173402.17 0 rv lg add [PathVgSys]{C:\Program Files\VoiceGuide\system\}
173402.17 0 rv lg add [OutDial_RetriesLeft]{2}
173402.19 0 rv lg add [$RV_STARTTIME]{9/9/2005 5:34:02 PM}
173402.19 0 rv lg add [$RV_DEVICEID]{0}
173402.20 0 rv lg add [$RV_CIDNAME]{}
173402.20 0 rv ns add [PathApp]{C:\Program Files\VoiceGuide\}
173402.22 0 rv lg add [$RV_CALLEDNUMBER]{17186586839}
173402.22 0 rv lg add [$RV_DNIS]{}
173402.23 0 rv lg add [DNIS]{}
173402.23 0 timer clear
173402.25 0 [GetClientRecord] DB Query
173402.25 0 db Jet mode used (To use ODBC mode specify ODBC Connect string)
173402.27 0 db About to execute a Retrieve type operation [sELECT Company, OrderName, OrderAmount, OrderCode, ID FROM Accounts, Transactions WHERE Accounts.AccountID=Transactions.AccountID]
173402.27 0 db [GetClientRecord] row count=1
173402.28 0 rv lg add [GetClientRecord_RowCount]{1}
173402.28 0 db get RecordsetGetRowsMax
173402.30 0 db get 999 records. (row count=1)
173402.30 0 db update RVs start
173402.30 0 db update RVs cols=5 rows=1
173402.31 0 db test vRetData(0, 0)=ABC Tech
173402.31 0 db test CStr(vRetData(0, 0))=ABC Tech
173402.33 0 db about to close dbDbqDatabase
173402.33 0 db going down path [True]
173402.34 0 timer clear
173402.34 0 [GetOrderCode] Number Input
173402.36 0 rv replace start: [Hello $RV[GetClientRecord_2_1]This call is to confirm your purchase. Please enter the Order Code that was provided with your order! ]
173402.36 0 rv ns none[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{2}[scriptsPath]{C:\Documents and Settings\Dovid\My Documents\TVR\}[scriptPath]{C:\Documents and Settings\Dovid\My Documents\TVR}[PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[OutDial_RetriesLeft]{2}[$RV_STARTTIME]{9/9/2005 5:34:02 PM}[$RV_DEVICEID]{0}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CALLEDNUMBER]{17186986838}[$RV_DNIS]{}[DNIS]{}[GetClientRecord_RowCount]{1}[GetClientRecord_1_1]{ABC Tech}[GetClientRecord_2_1]{Ira Adress}[GetClientRecord_3_1]{1200}[GetClientRecord_4_1]{123}[GetClientRecord_5_1
{1}
173402.38 0 tts generate start[Hello Ira Adress, you have recently placed an order with ABC Tech in the amount of $1200 . This call is to confirm your purchase. Please enter the Order Code that was provided with your order! ]
173402.39 0 tts generate wait
173402.41 0 dial callque delete id=33
173402.42 0 rv ns add [OutDial_Result]{Contacted_Human}
173402.61 0 tts generate finish. lineCallState=CONNECTED
173402.61 0 amchk test AMdet in TtsToWavFileFinished => False
173402.63 0 [GetOrderCode] Playing (C:\Program Files\VoiceGuide\temp\tts_0_1.wav)
173402.63 0 play set playid=527187
173402.73 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\temp\tts_0_1.wav]
173402.75 0 timer clear
173402.77 0 wa(13611,52718700)
173416.36 0 play end current play (playid=527187)
173416.36 0 ScriptEventCode 8001 iLineState=1300
173416.38 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
173416.39 0 eng set timer EV_TIMEOUT_REPLAYMSG time=5
173416.41 0 timer set 5 EV_TIMEOUT_REPLAYMSG
173421.77 0 timer fired EV_TIMEOUT_REPLAYMSG
173421.77 0 ScriptEventCode 9005 iLineState=1301
173421.78 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
173421.78 0 tts generate reuse (C:\Program Files\VoiceGuide\temp\tts_0_1.wav)
173421.80 0 [GetOrderCode] Playing (C:\Program Files\VoiceGuide\temp\tts_0_1.wav)
173421.80 0 play set playid=546359
173421.92 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\temp\tts_0_1.wav]
173421.94 0 timer clear
173421.94 0 wa(13611,54635900)
Are yon using a Voice modem? Voice modems cannot detect when call is answered, that's why they usually need to play the announce mesasge in a loop - see: http://www.voiceguide.com/vghelp/html/DialListInto.htm
You will need to use a Dialoigc card to detect when an outgoing call is answered.
