Evaluation Madule
In Evaluation Madule we an set amount for a RV.
How many RV can set and get amount in just one evaluation madule?How
Can we Evaluate two or more RV with one evaluation madule? How?
Tanks . I knew.
But i feel some delay on running vbs madule.
Haw Can we accelerate it.
Unless you are doing some time consuming processing in VBScript the time taken to run it would be negligible.
You can see the time taken to run the script within the trace log.
