Guest enadhazeem Report post Posted 09/11/2005 01:08 PM Is it necessary for me to enable inband signaling when using VoiceGuide for Dialogic 6.0.2092 in order for me to be able to capture CallerID, knowing that I am not using a PBX, rather, simply just receiving calls from the phone company analog lines?? If so, where do I get the Telco's PBX definition file. Do I use VG.INI to enable inband signaling or do I do that in the Config.xml or ConfigLine.xml ?? Share this post Link to post
SupportTeam Report post Posted 09/11/2005 01:45 PM CallerID as sent by the phone company is automatically detected by the Dialogic card. No special setting in VG.INI, Inband Signaling config file or otherwise is required. Share this post Link to post
