Cannot Bridge Fax Calls After Upgrade
I used to use VG to bridge fax calls (my users want the flexibility to re-direct to different machines without the need to advise new numbers to users).
That used to work nicely in previous ISDN version, but failed to work upon upgrade to the new ISDN version 2092.
Please advise how to make this work again!
Thanks.
Here's the log files -- I've just made a single call to the log.
The script is a simple one with a Transfer module that i selected 'Dialout and Conference - Blind' for my T1 ISDN system.
As I recall, the same script worked previously in an earlier version before upgrade (I'm not sure but probably it was version 2062).
Thanks for investing. Hope to get this fixed because my users have been 'blacked out' for many days since the upgrade.
Thanks,
Henry
Trace shows that you are using v6.0.2053 :
164723.42 4 script interpretor: VgMulti v6.0.2053
Can you try with the current version (6.0.2214) and see if you are still seeing this problem?
During the trace posted:
and incoming fax tone was detected :
164731.98 4 tw DialogicEvent 134,TDX_CST,198,0,0,DE_TONEON,TID_FAX2,
164732.00 4 event FAX, code=134, state=1901
so script jumped to module [ToFax] :
164732.44 4 state [To Fax] Blind Dial and Connect to 26911352
Call was made and two lines bridged (tromboned) :
164732.66 7 lineMakeCall(26911352,CONNECT_IMMEDIATELY) => 0
164732.75 4 conf TwoCalls_Bridge 4<=>7 (dtiB1T1<=>dtiB1T2)
and the outgoing line was ringing:
164738.48 7 event RINGBACK, code=134, state=1911
and it was answered:
164747.34 7 event callstate CONNECTED 7 0 0
but it then soon hung up due to a bug in VG:
164750.14 7 state Hanging up call... [WaitTillFinished - next module not specified]
We'll look into this problem, and should post another answer soon.
Please use the attached .EXE and let us know how you go with this version.
(if you get a message about MSCOMM32.OCX not being on your system, then that OCX is available in v2214 download from our WWW)
VgMulti_6.0.2223.zip
Thanks for getting the updated version so promptly.
Unfortunately, it seems it has not solved the problem. The extract of the log shows (Note the gcev errors):
162739.09 4 StartModuleDefault=[To Fax]
162739.09 2 tr NewVgsVgm_Goto 1
162739.11 2 tr NewVgsVgm_Goto 2
162739.13 4 fn RunModule start
162739.14 4 timer clear
162739.16 4 timer clear
162739.17 2 tr NewVgsVgm_Goto end
162739.28 4 tw DialogicEvent 2050,GCEV_ANSWERED,2050,0,0,,,
162739.28 4 event GCEV_ANSWERED, code=2050, state=6001
162739.30 4 event callstate CONNECTED 4 0 0
162739.31 4 LineEvCallState_Connected hDevice=4 params=256,0,0
162739.33 4 WorkingModes tapi= script=BeforeAnswerRun
162740.36 4 Inband detection not enabled
162740.38 4 fn RunModule start
162740.41 4 timer clear
162740.41 4 timer set 2 EV_TIMEOUT_READYTOBEGINTRANSFER
162742.58 4 timer fired EV_TIMEOUT_READYTOBEGINTRANSFER
162742.59 4 event EV_TIMEOUT_READYTOBEGINTRANSFER, code=9012, state=1901
162742.59 4 LsXfer_1_Start : 9012(EV_TIMEOUT_READYTOBEGINTRANSFER),EV_TIMEOUT_READYTOBEGINTRANSFER,0,0,0,,,
162742.61 4 path {EV_TIMEOUT_READYTOBEGINTRANSFER} not found
162742.63 4 timeout on transfer attempt set by VG.INI [PBX] AnnouncedTransfersMaxWaitTime (30 sec)
162742.64 4 timer set 30 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG
162742.66 4 state [To Fax] Blind Dial and Connect to 26821352
162742.67 0 Search for free lines in LineID range [0-70]
162742.69 4 dial busy: ReadyToDialout=0
162742.69 7 dial reserving: no list specified
162742.70 4 dial found free dev=2 (LineId=7)
162742.72 4 no on-hold file specified to play
162742.75 7 state dialing 26821352 (for conference with dtiB1T1)
162742.75 4 setting CONNECT_IMMEDIATELY as iXferType = XT_DC_BLIND
162742.77 7 lineMakeCall(26821352,CONNECT_IMMEDIATELY) => 0
162742.78 4 timer set 3600 EV_TIMEOUT_HANGUP
162742.80 7 timer set 3600 EV_TIMEOUT_HANGUP
162742.81 4 dial found free dev=2 (LineId=7)
162742.83 4 conf TwoCalls_Bridge 4<=>7 (dtiB1T1<=>dtiB1T2)
162742.84 4 rvns add [TsRoutedTo]{7}
162742.86 7 rvns add [TsRoutedTo]{4}
162742.86 7 rvns add [Conf_DevName_1]{dtiB1T1}
162742.89 7 rvns add [Conf_LineId_1]{7}
162742.89 7 rv add [Conf_DevName_2]{dtiB1T2}
162742.91 7 rv add [Conf_LineId_2]{4}
162742.92 4 rvns add [Conf_DevName_1]{dtiB1T1}
162742.94 4 rvns add [Conf_LineId_1]{7}
162742.95 4 rv add [Conf_DevName_2]{dtiB1T2}
162742.97 4 rv add [Conf_LineId_2]{4}
162742.97 4 TsRoute dtiB1T1<=>dtiB1T2 call
162743.00 4 TsRoute dtiB1T1<=>dtiB1T2 SC_FULLDUP:
162743.02 4 state [To Fax] bridged with dtiB1T2
162743.03 7 state [To Fax] outgoing leg, bridged with dtiB1T1
162745.47 7 tw DialogicEvent 2081,GCEV_ALERTING,2081,0,0,,,
162745.47 7 state [To Fax] outgoing leg, bridged with dtiB1T1 Ringing...
162745.50 7 event GCEV_ALERTING, code=2081, state=1911
162745.52 7 LsXfer_8_WaitEndCall_DialingSide : 2081,[GCEV_ALERTING],2081,0,0,,,
162745.52 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2081,[gcev_alerting],2081,0,0,,,
162745.53 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2081(EV_UNKNOWN_2081),gcev_alerting,2081,0,0,,,
162745.55 4 path {gcev_alerting} not found
162757.36 7 tw DialogicEvent 2082,GCEV_CONNECTED,2082,0,0,,,
162757.38 7 event GCEV_CONNECTED, code=2082, state=1911
162757.39 7 LsXfer_8_WaitEndCall_DialingSide : 2082,[GCEV_CONNECTED],2082,0,0,,,
162757.41 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2082,[gcev_connected],2082,0,0,,,
162757.42 4 LsXfer_6_dc_WaitOutcomeOutgoingCall_RequestXferSide : 2082(EV_UNKNOWN_2082),gcev_connected,2082,0,0,,,
162757.44 4 path {gcev_connected} not found
162757.45 7 event callstate CONNECTED 7 0 0
162757.47 4 event CONNECTED, code=10256, state=1910
162757.47 4 LsXfer_8_WaitEndCall_RequestXferSide : 10256(EV_UNKNOWN_10256),CONNECTED,256,0,0,,,
162757.50 4 path {connected} not found
162757.52 7 LineEvCallState_Connected hDevice=7 params=256,0,0
162757.52 7 WorkingModes tapi= script=
162757.55 7 Inband detection not enabled
162757.55 7 StartLoadedVgs at 17/9/2005 16:27:57 [VgMulti v6.0.2223]
162757.56 7 set LineState().iVgsIdx=3
162757.58 7 set sScriptToRunOnHangup=[] in StartLoadedVgs
Kindly help investigate further. Many thanks!
