3 Way Conference
Hello,
I have a 4-port analoge dialogic card , and im using VoiceGuide For Dialogic version 6.0 which you have changed many times before for fixing "Dial and Conferene" Problems I had.
We are not comfortable with using "Dial and Conferene", and we have applied for the "3 way conference" service from telecom company, i checked the service manually and it works fine on phone devices, when implemented it on VG, i had to edit vg.ini file according to the specs and i did, but the system was not able to put the caller on hold to dial the second party. [ maybe couse if short hookflash]
My question is - as long as im not using "dial and conference" anymore- should I return back to "VoiceGuide 5.2" and try to configuire the hookflash parameters acoording to this link
http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm
or there there is someway to define the hookflash length and stuff using the dialogic version???
Please inform if VG 5.2 would recognize "busy tune"or "no response" on the being called party.
Strongly suggest to use "VG for Dialogic" when doing any sort of transfers or conferencing.
See this section in Config.xml file in Vg's \data\ subdirectory:
<SetParm>
<Description>Flash time during dialing</Description>
<Key>DXBD_FLASHTM</Key>
<Value>10</Value>
<Default>10</Default>
</SetParm>
It does, but the Dialogic has some problems with handling some commands after this happens - this is exactly why we recommend using "VG for Dialogic" when doing call transfers.
Hello,
I have tried ur suggestion and tried changing the "Flash time during dialing" in the config.xml for different values, where the value from STC was 100 which equals 1 second, but still the same, I still hear the system dialing the number, means it does not put me on hold.
The manual operation, is that i receive a call, then I put it on hold by pressing "HockFlash then 2" Dial the other number, then press "HockFlash then 3" to make the conference.
what are "AT" "Generate" and "TAPI" parameters in the vg.ini file, the default is "Generate", is that fine ?
please explain how can i acheive this function
Note: in the file config.xml i read a note which says if im using dialogic card, then the configuration in the xml file wil be ignored, and the system will refere to the TSP settings, is that right? and i changed the TSP settings accordingly, but nothing changed !!
advice plz...
When doing it manually does the call go on hold when hookflash is made, or when "2" is pressed?
Yes.
No. Not true and no such comments should exist in Config.xml file.
Can you quote what is the actual entry you have read and indicate exactly where this entry is?
mentioning the file name was enough, here u go
;Preferred Lengths of hookflash and DTMF tones.
;will be used if Generate method is selected. In milliseconds.
;If commented out then the default settings for the device will be used.
;Note: Dialogic cards will ignore this setting and use what is in the Dialogic TSP Configuration settings.
and attached is the file
vg.ini
OK, this comment refers to the setting of the Hookflash length in the "TAPI" version of VoiceGuide. (v5.x.x). The Dialogic TSP Configuration settings only apply to the Dialogic's TAPI driver settings.
"VoiceGuide for Dialogic" does not TAPI drivers.
In VG for Dialogic the Hookflash length is set in Config.xml file - in the section indicated before:
<SetParm>
<Value>10</Value>
</SetParm>
The setting is in 10ms units, so a value of 10 represents 100ms.
Nice, so where can i set the actions to put users on hold and dial another number, and then make the 3 way conference?
this is my actions
HockFlash + 2 >>> puts caller on hold
then dial a number
HockFlash + 3 >>> establishs the conference
and as i told, i have checked this manually on my phone lines, and it works great..
In VoiceGuide Script Designer click on the Edit menu and select PBX Command Strings. (see: http://www.voiceguide.com/vghelp/html/Dial...llTransfers.htm )
What are the settings specified for "Place call on hold before doing a blind or announced conference" ?
Please post a copy of VG.INI file from the VoiceGuide's directory.
Could you please post a copy of VoiceGuide's Debug Printout which captures the attempted 3-way call.
When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call. You can enable the automatic saving of the logs to files in \log\ directory as well.
Hello,
According to your instruction, I have tried with different values of PBX "Command Strings" and
"Hookflash length on Dialogic cards" but the result is the same.
so, attached zip file contains
vg.ini
Log.txt
waiting ..............
Are you now using "VoiceGuide for Dialogic", or are you using v5 of VoiceGuide?
As per previous post:
In VoiceGuide for Dialogic the Hookflash length is set in Config.xml file:
<SetParm>
<Value>10</Value>
</SetParm>
How would you retrieve a call if the destination number is busy? The use of "!3" when "Retrieve a call from announced call tranfer" does not seem correct.
