System Rvs / Result Variables
Hi, I wonder if there are any system RVs which are available, but not visible/published/documented which could be used to help program flow?
I just wondered if there was something like "$RV_PreviousModule" (which is documented, but doesn't work across a gosub call, ie: gives itself if its the first module in a subscript called via gosub)...?
Something like:
$RV_CallingScript
$RV_CallingModule
$RV_CalledScript
$RV_CalledModule
Or if there is a var/RV which is set true when in hangup mode or similar?
Clearly, these values are available "behind the scenes" - but it would be very helpful if some of these values could be made available programatically, ideally as RVs.
(Yes, I am still trying to get my hangup scripts working. Knowing which script called a gosub could solve some issues easily for me).
Thanks - Tim.
PS: Any help appreciated - I really am getting desparate.
Sometimes, you can't see the wood for the trees !! I think I have found a working solution by carefully inspecting the debug log for the information I was looking for.
$RV[scriptEnd_Time]
$RV[scriptEnd_Goto_Script]
$RV[scriptEnd_Goto_Module]
$RV[scriptStart_Time]
$RV[scriptStart_CalledFrom_Script]
$RV[scriptStart_CalledFrom_Module]
Yep, figured those out and tried em - worked fine. Didn't want to "publish" my findings as you may have prefered to keep them under wraps.
