Dialogic Version 6
Has anyone sucessfully managed to use VoiceGuide with Dialogics release v6? I have installed Voiceguide together with patch 6 for Dialogic and when I load the Voiceguide application it tells me that I need to configure the TAPI. However, Dialogic v6 does not use TAPI or WAVE.
Any ideas.
Thanks.
VoiceGuide v6 does not use TAPI. Can you post a screenshot of the message you are seeing?
Yes, I found out that it doens't use TAPI or WAVE. I've since sorted the problem by downloading and installing the patch VoiceGuide for Dialogic from the website.
Many thanks.
