Date And Currency Format
Currently I am retreiving my dollar and cents value from the database as -7933 (which is - $79.33)
Voice guide is pronouncing this value as "seventy nine minus dollars and thirty three cents"
Instead of minus/negative seventy nine dollars and thirty three cents
I am retreiving my date format as 20051004
Which is October 4th 2005
Does anyone know of any solution for this problem.
Thanks for your help.
Please place attached lib_num2wav.vbs file in VoiceGuide's \system\vbs\ subdirectory, overwriting existing file (you may want to backup existing file)
This will fix the bug you encountered. 'Minus' will now play before the entire amount is spoken.
Future releases of VG will use this attached file.
lib_num2wav.vbs
