Invalid Vbscript Character
When working on a script today suddenly got
VBscript compilation error: Invalid character.
The problem character was the $ sign at the front of $RV_ENTEREDNUMBER
Is there some script header or system path setting required to prevent this?
TIA
Are you running this from within a "Get Numbers" module?
Have you checked what value $RV_ENTEREDNUMBER is before using it?
Try using this:
vg.Admin_TraceLogAdd 0, 0, "Value is: [$RV_ENTEREDNUMBER]"
set vg = Nothing
From within the VBScript first and see what appears in the log trace file.
The script you suggested compiles ok
Thanks, but I think you misunderstood me.
The script was working just fine. I downloaded it from the customer site to our system here and opened it using VBSedit. It gave a compile error *before* I made any changes to the script.
The script is below. The compiler gives an 'invalid character' error at the $ in $RV_ENTEREDNUMBER
dim retval, numrecs
Const adCmdStoredProc = &H0004
Const adParamInput = &H0001
Const adParamOutput = &H0002
Const adInteger = 3
Const adExecuteNoRecords = 128
set cn = CreateObject("ADODB.Connection")
cn.Open "Provider=SQLOLEDB;Server=Smart-db;UID=Clarion;PWD=bruce;Database=Smart"
Set cmd = CreateObject("ADODB.Command")
With Cmd
.ActiveConnection = cn
.CommandText = "ValidateSafetyCheck"
.CommandType = adCmdStoredProc
.Parameters.Append .CreateParameter ("@KeyPad", adInteger, adParamInput, 10, $RV_ENTEREDNUMBER)
.Parameters.Append .CreateParameter ("RetVal", adInteger, adParamOutput, 10, 0)
End With
SET rs = cmd.Execute (numrecs, , adExecuteNoRecords)
If cn.Errors.Count > 0 Then
' MsgBox("Error: " & cn.Errors(0).Description)
sResult = "verify_failed"
ELSE
RetVal = cmd.Parameters(1).Value
end if
IF RetVal > 0 Then
sResult = "verify_passed"
' MsgBox("Passed!")
ELSE
' MsgBox("Failed! " & RetVal)
end if
Set cmd = Nothing
Set cn = Nothing
Set rs = Nothing
' MsgBox(sResult)
vg.Run_ResultReturn $RV_LINEID, sResult
set vg = Nothing
If you are trying to run what you have quoted above as is directly in a VBScript interpreter it will not work.
It will however work OK if you run it from within VoiceGuide's VBScript module.
$RV_ENTEREDNUMBER and $RV_LINEID are replaced by VG with appropriate values before running the script.
You should replace $RV_ENTEREDNUMBER and $RV_LINEID with some test values and then the VBScript compiler will not give errors...
Thanks, that reduced the range of possibilities.
However I still get an error.
This part of the script works fine:
But when I add another parameter I get the 'Invalid Character' error at the '$' of $RV_CIDNUMBER
.Parameters.Append .CreateParameter ("@CallerID", adInteger, adParamInput, 10, $RV_CIDNUMBER)
Does this mean there is no Caller ID, perhaps?
Are the quoted snippets running from inside a VoiceGuide VBScript module or are you running these VBScripts directly?
If running from VoiceGuide's VBScript module and there is no CallerID then $RV_CIDNUMBER will be replaced with an empty string.
From http://www.voiceguide.com/vghelp/html/Resu...ltVariables.htm :
If a Result Variable is used in the script that has not yet been defined, it will be replaced with nothing (an empty string), not a digit zero.
Eg: If you use expression: C:\SoundFiles\Info$RV[infoNumber].wav and the script has not yet defined $RV[infoNumber] then the resulting string after the Result Variables are replaced will be: C:\SoundFiles\Info.wav
so
would change into
.Parameters.Append .CreateParameter ("@CallerID", adInteger, adParamInput, 10, )
which would result in a syntax error.
And if you are running the above line yourself directly in a VBScript interpreter then you will get error as VBScript does not know what $RV_CIDNUMBER is...
Tip:
It is usually best to use quotes around the RVs which may be empty. eg: this line would not cause an error:
.Parameters.Append .CreateParameter ("@CallerID", adString, adParamInput, 10, "")
(note changing of adInteger to adString)
Nope.
Even this code produces a syntax error at the $ sign:
If $RV_CIDNUMBER = "" Then
CallerID = 'Unknown'
Else
CallerID = $RV_CIDNUMBER
End if
Is this code running from inside a VoiceGuide VBScript module or are you running these VBScripts directly?
Is $RV_CIDNUMBER defined?
Tip (again):
Try changing to:
If "$RV_CIDNUMBER" = "" Then
CallerID = "Unknown"
Else
CallerID = "$RV_CIDNUMBER"
End if
Note the use of quotes above.
- this is being run from inside VoiceGuide
- according to the doco, $RV_CIDNUMBER is a standard Result Variable
I misinterpreted your earlier instruction. So vg is a meta language? Will proceed as instructed.
If Caller ID information did not arrive then VoiceGuide will replace $RV_CIDNUMBER with an empty string before letting the VBScript run.
So, if Caller ID information did not arrive this code:
Else
End if
would be changed to
If = "" Then
Else
CallerID =
End if
Which you can see is not valid VBScript and hence and error will occur.
If you write the code using quotes around the RVs, like this:
Else
End if
and Caller ID information did not arrive then the resulting VBScript which VoiceGuide actually runs would be:
If "" = "" Then
Else
CallerID = ""
End if
Which is a valid VBScript and when running it no errors will be generated and the script will work as expected.
