Microsoft Sapi Tts
Coen wrote:
Would appreciate if you could help me with the following.
I have installed the Microsoft SAPI. All the text to speech test, using the VB TTS Application on the menu of the Microsoft Speech SDK 5.1 are working fine.
If I go to the control panel and in the window "text to speech" it works fine when I select on the Audio Out button the sound card in the computer.
However when I select Dialogici Wave (dxxxB 1C1) I get an error message saying another voice or another audio output has to be used.
Are there any help pages for me to consult? I could not find any.
How does Voice Guide know that the TTS has to be used i.s.o. a wave file?
thanks again,
There is no need to select "Dialogici Wave (dxxxB 1C1)" etc. in the control panel in order for VoiceGuide to use the TTS.
VoiceGuide just looks what TTS is selected as the Default one and uses it.
