Voiceguide Hangs Up
Hello!
I have a dialogic card (D/41JCT-LS) on my Windows XP Home Edition and Voiceguide for dialogic v6.0.2092. I also have a phone adapter (PAP2-NA) from Cisco with 2 ports for Voice over IP.
My problem is that when anyone calls the script, voiceguide just hangs up the phone while playing the welcome message. In the trace log I can see the event callstate DISCONNECTED but from who; I mean the only person calling is me and I did not hang up. I have configured the tones in the ConfigLine.xml file according to the tones in the Sweden network.
110947,39 0 btn Exit (4 lines)
110947,39 1 line state =900
110947,39 2 line state =0
110947,39 3 line state =0
110947,39 4 line state =0
110947,39 1 state Exiting...
110947,39 2 state Exiting...
110947,39 3 state Exiting...
110947,39 4 state Exiting...
110948,50 0 exit closing all channels start
110948,50 0 exit close dxxxB1C1(1)=> []
110948,53 0 exit close dxxxB1C2(2)=> []
110948,58 0 exit close dxxxB1C3(3)=> []
110948,61 0 exit close dxxxB1C4(4)=> []
110948,61 0 exit closing all channels end
110949,11 0 ---------------------------------------------------
110949,11 0 Stopping VoiceGuide (Dialogic) start
110949,11 0 v6.0.2092
110949,11 0 Stopping VoiceGuide (Dialogic) end
111011,36 0 ---------------------------------------------------
111011,44 0 VoiceGuide for Dialogic
111011,44 0 v6.0.2092
111011,45 0 ---------------------------------------------------
111011,45 0 rv global loaded >>><<<
111011,47 0 Inband Signaling Config file not specified
111011,73 0 init ApiMode=[DialogicGC]
111011,77 0 vm loading VMB data begin
111011,77 0 vm loading VMB data - about to delete old entries
111011,84 0 vm loading VMB data - sorting/ordering
111011,86 0 vm loading VMB data end
111011,86 0 dial DbConnectString_ADO is blank
111011,88 0 init DB Workspaces
111011,89 0 init Voicemail LoadIniSettings
111011,91 0 init read Config.xml start
111011,92 0 dxxxB1C1 dxxxB1C1 C:\Voice\Locksmith\locksmith.vgs allowDialout=1
111011,92 0 dxxxB1C2 dxxxB1C2 C:\Voice\Locksmith\locksmith.vgs allowDialout=1
111011,92 0 dxxxB1C3 dxxxB1C3 C:\Voice\Locksmith\locksmith.vgs allowDialout=1
111011,92 0 dxxxB1C4 dxxxB1C4 C:\Voice\Locksmith\locksmith.vgs allowDialout=1
111011,92 0 init read Config.xml end
111011,94 0 init LineOpenDialogic dxxxB1C1 => [1]
111011,94 1 iIvrDev=1
111012,06 1 init strDlgcDevName_VoiceResource=[dxxxB1C1] (LoadXMLConfig)
111012,06 0 load start [C:\Voice\Locksmith\locksmith.vgs]
111012,11 0 init hires timer setup start
111012,11 0 init hires timer setup end
111012,11 1 state Waiting for a call...
111012,11 1 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111012,11 0 init lineids: 0-1
111012,13 0 init LineOpenDialogic dxxxB1C2 => [2]
111012,13 2 iIvrDev=2
111012,25 2 init strDlgcDevName_VoiceResource=[dxxxB1C2] (LoadXMLConfig)
111012,25 0 init hires timer setup start
111012,25 0 init hires timer setup end
111012,25 2 state Waiting for a call...
111012,25 1 event callstate IDLE 1 0 0
111012,25 1 WorkingMode@Idle=
111012,25 1 timer clear
111012,25 1 LineState(iLineId).iVgsIdx = 0
111012,25 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
111012,25 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
111012,25 1 event TDX_SETHOOK, code=135, state=0
111012,25 2 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111012,27 0 init lineids: 0-2
111012,30 0 init LineOpenDialogic dxxxB1C3 => [3]
111012,30 3 iIvrDev=3
111012,44 3 init strDlgcDevName_VoiceResource=[dxxxB1C3] (LoadXMLConfig)
111012,44 0 init hires timer setup start
111012,44 0 init hires timer setup end
111012,44 3 state Waiting for a call...
111012,44 2 event callstate IDLE 2 0 0
111012,44 2 WorkingMode@Idle=
111012,44 2 timer clear
111012,44 2 LineState(iLineId).iVgsIdx = 0
111012,44 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
111012,44 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
111012,44 2 event TDX_SETHOOK, code=135, state=0
111012,44 3 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111012,44 0 init lineids: 0-3
111012,48 0 init LineOpenDialogic dxxxB1C4 => [4]
111012,48 4 iIvrDev=4
111012,61 4 init strDlgcDevName_VoiceResource=[dxxxB1C4] (LoadXMLConfig)
111012,61 0 init hires timer setup start
111012,61 0 init hires timer setup end
111012,61 4 state Waiting for a call...
111012,61 3 event callstate IDLE 3 0 0
111012,61 3 WorkingMode@Idle=
111012,61 3 timer clear
111012,61 3 LineState(iLineId).iVgsIdx = 0
111012,61 3 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
111012,61 3 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
111012,61 3 event TDX_SETHOOK, code=135, state=0
111012,61 4 timer set 2 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111012,61 0 init lineids: 0-4
111012,61 0 init route channels start
111012,70 0 init route channels => []
111012,70 0 init no dti channels opened. Not opening signaling channel.
111012,70 0 init iLineDevicesControlled=4
111012,72 0 init main form load end
111012,72 4 event callstate IDLE 4 0 0
111012,72 4 WorkingMode@Idle=
111012,72 4 timer clear
111012,72 4 LineState(iLineId).iVgsIdx = 0
111012,72 4 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
111012,72 4 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
111012,72 4 event TDX_SETHOOK, code=135, state=0
111013,38 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
111013,38 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
111013,38 1 init atidle reinit : start
111013,38 1 init atidle reinit iConferenceOtherLegLid=-1
111013,38 1 init atidle reinit : reset all LineState variables
111013,38 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,38 1 state Waiting for a call...
111013,48 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
111013,48 2 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
111013,48 2 init atidle reinit : start
111013,48 2 init atidle reinit iConferenceOtherLegLid=-1
111013,48 2 init atidle reinit : reset all LineState variables
111013,48 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,48 2 state Waiting for a call...
111013,59 3 timer fired EV_TIMEOUT_TIMETOREINITLINE
111013,59 3 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
111013,59 3 init atidle reinit : start
111013,59 3 init atidle reinit iConferenceOtherLegLid=-1
111013,59 3 init atidle reinit : reset all LineState variables
111013,59 3 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,59 3 state Waiting for a call...
111013,70 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,70 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
111013,70 4 timer fired EV_TIMEOUT_TIMETOREINITLINE
111013,70 4 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=0
111013,70 4 init atidle reinit : start
111013,70 4 init atidle reinit iConferenceOtherLegLid=-1
111013,70 4 init atidle reinit : reset all LineState variables
111013,70 4 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,70 4 state Waiting for a call...
111013,81 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,81 2 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
111013,92 3 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
111013,92 3 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
111014,03 4 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
111014,03 4 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=0
Here, I make a call and just after voiceguide starts playing the welcome message it just hangs up the phone:
111440,69 1 tw dtmf a (1,97,97)
111440,69 1 event a, code=97, state=0
111440,69 1 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
111440,69 1 event TDX_CST, code=134, state=0
111440,84 1 tw dtmf 4 (1,52,52)
111440,84 1 event 4, code=52, state=0
111440,84 1 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
111440,84 1 event TDX_CST, code=134, state=0
111441,00 1 tw dtmf 1 (1,49,49)
111441,00 1 event 1, code=49, state=0
111441,00 1 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
111441,00 1 event TDX_CST, code=134, state=0
111441,16 1 tw dtmf # (1,35,35)
111441,16 1 event #, code=35, state=0
111441,16 1 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
111441,17 1 event TDX_CST, code=134, state=0
111442,78 1 event callstate OFFERING 1 0 0
111442,78 1 script interpretor: VgMulti v6.0.2092
111442,78 1 fired OFFERING event to listeners
111442,78 1 iIvrDev=1
111442,78 1 set linestate CID vars
111442,80 1 call AnswerTheCallIfAllowed
111442,80 1 tw ring 1
111442,80 1 ring time since last ring (ms): 0
111442,80 1 rv clear all
111442,80 1 init LineState ResetAtStartOfNewCall.
111442,80 1 answer the call
111442,81 1 timer clear
111442,81 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
111442,81 1 event TDX_CST, code=134, state=6001
111443,34 1 event callstate CONNECTED 1 0 0
111443,36 1 WorkingModes tapi= script=
111444,36 1 Inband detection not enabled
111444,38 1 StartLoadedVgs at 2005-09-28 11:14:44
111444,38 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
111444,38 1 init StartLoadedVgs_InitLineState start
111444,38 1 rv add [$RV_STARTTIME]{2005-09-28 11:14:44}
111444,38 1 rv add [$RV_DEVICEID]{1}
111444,38 1 rv add [$RV_CIDNAME]{}
111444,39 1 rvns add [PathApp]{C:\Program\VoiceGuide\}
111444,39 1 rvns add [scriptsPath]{C:\Voice\Locksmith\}
111444,39 1 rv add [$RV_CIDNUMBER]{}
111444,39 1 fn RunModule start
111444,39 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
111444,39 1 event TDX_SETHOOK, code=135, state=6001
111444,39 1 tw DialogicEvent 134,TDX_CST,27124,0,0,DE_LCON,,
111444,41 1 event TDX_CST, code=134, state=6001
111444,42 1 timer clear
111444,42 1 state [init_LANGUAGE] Evaluate [1]
111444,42 1 eval[1]
111444,42 1 rvns add [init_LANGUAGE_Input]{1}
111444,42 1 rvns add [init_LANGUAGE]{1}
111444,44 1 rvns add [LANGUAGE]{1}
111444,44 1 Eval Expr result:[1] stored in $RV[LANGUAGE]
111444,44 1 path {1} not found
111444,44 1 fn RunModule start
111444,44 1 timer clear
111444,44 1 Play Module start
111444,45 1 state [WELCOME] Playing
111444,45 1 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
111444,45 1 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-28 11:14:44}[$RV_DEVICEID]{1}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Locksmith\}[$RV_CIDNUMBER]{}[init_LANGUAGE_Input]{1}[init_LANGUAGE]{1}[LANGUAGE]{1}
111444,45 1 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_1.wav]
111444,45 1 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_1.wav)
111444,45 1 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_1.wav
111444,47 1 timer clear
111444,55 1 tw wav->vox convert end 936953,C:\Voice\Locksmith\voice\welcome_locksmith_1.vox,1,0,,
111444,56 1 play start ok, lPlayId=937046
111445,61 1 event callstate DISCONNECTED 1 0 0
111445,61 1 event EV_REMOTEPARTY_DISCONNECT, code=9250, state=1100
111445,63 1 LsPlayMsg EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
111445,63 1 path {EV_REMOTEPARTY_DISCONNECT} not found
111445,63 1 rv add [Hangup Time]{2005-09-28 11:14:45}
111445,63 1 state Hanging up call...
111445,63 1 HangupCall_Common hCall=1
111445,64 1 rec RecSoundStop ok
111445,64 1 play PlaySoundStop ok
111445,64 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
111445,64 1 fnHangupCall end
111445,66 1 tw DialogicEvent 134,TDX_CST,226,0,0,DE_LCOF,,
111445,66 1 event TDX_CST, code=134, state=900
111445,66 1 LsAwaitingCalls EV_UNKNOWN_134
111445,66 1 tw PlayEnd 1 937046
111445,66 1 play end id=937046, (current ID)
111445,66 1 event EV_PLAY_FINISHED, code=8001, state=900
111445,66 1 LsAwaitingCalls EV_PLAY_FINISHED
111445,67 1 tw DialogicEvent 129,TDX_PLAY,937046,0,0,,,
111445,67 1 event TDX_PLAY, code=129, state=900
111445,67 1 LsAwaitingCalls EV_UNKNOWN_129
111445,67 1 tw DialogicEvent 134,TDX_CST,2,0,0,DE_LCON,,
111445,67 1 event TDX_CST, code=134, state=900
111445,67 1 LsAwaitingCalls EV_UNKNOWN_134
111445,69 1 event callstate IDLE 1 0 0
111445,69 1 WorkingMode@Idle=
111445,69 1 timer clear
111445,70 1 rec RecSoundStop ok
111445,70 1 play PlaySoundStop ok
111445,70 1 rv add [CallEndTime]{2005-09-28 11:14:45}
111445,84 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
111445,84 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
111445,84 1 event TDX_SETHOOK, code=135, state=900
111445,84 1 LsAwaitingCalls EV_UNKNOWN_135
111446,84 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
111446,84 1 event EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
111446,84 1 init atidle reinit : start
111446,84 1 init atidle reinit iConferenceOtherLegLid=-1
111446,84 1 init atidle reinit : reset all LineState variables
111446,84 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
111446,86 1 state Waiting for a call...
111447,19 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
111447,19 1 event EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
111758,94 1 tw DialogicEvent 134,TDX_CST,198,0,0,DE_TONEON,TID_FAX2,
111759,05 1 event FAX, code=134, state=900
111759,05 1 LsAwaitingCalls EV_UNKNOWN_134
111759,05 1 event TID_FAX2, code=134, state=900
111759,05 1 event TDX_CST, code=134, state=900
Thank you for your help!
Jose
Please update to current version (v6.0.2275) and try again.
If it still hangs up please post the MMDDtw.txt log capturing the incoming call. These logs are saved in VoiceGuide's /log/ subdirectory when logging is enabled.
Hello!
Ok, I have updated and it is still the same problem, but now I can hear a little bit more of the welcome message and then it just hangs up the phone.
135358,88 0 ---------------------------------------------------
135358,97 0 VoiceGuide for Dialogic
135358,97 0 v6.0.2275
135358,97 0 ---------------------------------------------------
135431,88 1 tw dtmf a (1,97,97)
135431,88 1 event ScriptEventCode a, code=97, state=0
135431,88 1 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
135431,88 1 event ScriptEventCode TDX_CST, code=134, state=0
135432,02 1 tw dtmf 4 (1,52,52)
135432,02 1 event ScriptEventCode 4, code=52, state=0
135432,02 1 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
135432,02 1 event ScriptEventCode TDX_CST, code=134, state=0
135432,19 1 tw dtmf 1 (1,49,49)
135432,19 1 event ScriptEventCode 1, code=49, state=0
135432,19 1 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
135432,19 1 event ScriptEventCode TDX_CST, code=134, state=0
135432,36 1 tw dtmf # (1,35,35)
135432,36 1 event ScriptEventCode #, code=35, state=0
135432,36 1 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
135432,36 1 event ScriptEventCode TDX_CST, code=134, state=0
135433,95 1 event callstate OFFERING 1 2,0,0
135433,95 1 script interpretor: VgMulti v6.0.2275
135433,95 1 fired OFFERING event to listeners
135433,95 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
135433,97 1 iIvrDev=1
135433,97 1 set linestate CID vars
135433,97 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
135433,97 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
135433,97 1 tw ring 1
135433,97 1 ring time since last ring event (sec): 0,00
135433,98 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
135433,98 1 rv clear all
135433,98 1 init LineState ResetAtStartOfNewCall.
135433,98 1 answer the call
135433,98 1 timer clear
135434,00 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
135434,00 1 event ScriptEventCode TDX_CST, code=134, state=6001
135434,61 1 event callstate CONNECTED 1 256,0,0
135434,61 1 LineEvCallState_Connected hDevice=1 params=256,0,0
135434,61 1 WorkingModes tapi= script= LineState().iState=6001
135434,63 1 Inband detection not enabled
135434,63 1 StartLoadedVgs at 2005-09-28 13:54:34 [VgMulti v6.0.2275]
135434,63 1 set LineState().iVgsIdx=1
135434,63 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
135434,63 1 init StartLoadedVgs_InitLineState start
135434,64 1 rv add [$RV_STARTTIME]{2005-09-28 13:54:34}
135434,64 1 rv add [$RV_DEVICEID]{1}
135434,64 1 rv add [$RV_CIDNAME]{}
135434,64 1 rvns add [PathApp]{C:\Program\VoiceGuide\}
135434,64 1 rvns add [scriptsPath]{C:\Voice\Locksmith\}
135434,64 1 rv add [$RV_CIDNUMBER]{}
135434,64 1 fn RunModule start
135434,66 1 timer clear
135434,66 1 state [init_LANGUAGE] Evaluate [1]
135434,66 1 eval[1]
135434,66 1 rvns add [init_LANGUAGE_Input]{1}
135434,66 1 rvns add [init_LANGUAGE]{1}
135434,66 1 rvns add [LANGUAGE]{1}
135434,67 1 Eval Expr result:[1] stored in $RV[LANGUAGE]
135434,67 1 path {1} not found
135434,67 1 fn RunModule start
135434,67 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
135434,67 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
135434,67 1 tw DialogicEvent 134,TDX_CST,3503,0,0,DE_LCON,,
135434,67 1 event ScriptEventCode TDX_CST, code=134, state=6001
135434,69 1 timer clear
135434,69 1 Play Module start
135434,69 1 state [WELCOME] Playing
135434,69 1 rv replace start: [C:\Voice\Locksmith\voice\welcome_locksmith_$RV[LANGUAGE].wav]
135434,69 1 rvns [PathSysVoice]{C:\Program\VoiceGuide\system\voice\}[PathApp]{C:\Program\VoiceGuide\}[PathDataVm]{C:\Program\VoiceGuide\data\}[PathVgSys]{C:\Program\VoiceGuide\system\}[$RV_STARTTIME]{2005-09-28 13:54:34}[$RV_DEVICEID]{1}[$RV_CIDNAME]{}[PathApp]{C:\Program\VoiceGuide\}[scriptsPath]{C:\Voice\Locksmith\}[$RV_CIDNUMBER]{}[init_LANGUAGE_Input]{1}[init_LANGUAGE]{1}[LANGUAGE]{1}
135434,69 1 rv replace end: [C:\Voice\Locksmith\voice\welcome_locksmith_1.wav]
135434,70 1 state [WELCOME] Playing (C:\Voice\Locksmith\voice\welcome_locksmith_1.wav)
135434,70 1 tw ConvertWav2Vox C:\Voice\Locksmith\voice\welcome_locksmith_1.wav
135434,70 1 timer clear
135434,72 1 tw wav->vox convert end 217203,C:\Voice\Locksmith\voice\welcome_locksmith_1.vox,1,0,,
135434,73 1 play start ok, lPlayId=217218
135437,08 1 event callstate DISCONNECTED 1 16384,0,0
135437,08 1 event ScriptEventCode EV_REMOTEPARTY_DISCONNECT, code=9250, state=1100
135437,08 1 LsPlayMsg EV_REMOTEPARTY_DISCONNECT,EV_REMOTEPARTY_DISCONNECT
135437,09 1 path {EV_REMOTEPARTY_DISCONNECT} not found
135437,09 1 rv add [Hangup Time]{2005-09-28 13:54:37}
135437,09 1 state Hanging up call...
135437,09 1 HangupCall_Common hCall=1
135437,11 1 rec RecSoundStop ok
135437,11 1 play PlaySoundStop ok
135437,11 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
135437,11 1 fnHangupCall end
135437,11 1 tw DialogicEvent 134,TDX_CST,247,0,0,DE_LCOF,,
135437,13 1 event ScriptEventCode TDX_CST, code=134, state=900
135437,13 1 LsAwaitingCalls EV_UNKNOWN_134
135437,13 1 tw PlayEnd 1 217218
135437,13 1 play end id=217218, (current ID)
135437,13 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=900
135437,13 1 LsAwaitingCalls EV_PLAY_FINISHED
135437,14 1 tw DialogicEvent 129,TDX_PLAY,217218,0,0,,,
135437,14 1 event ScriptEventCode TDX_PLAY, code=129, state=900
135437,14 1 LsAwaitingCalls EV_UNKNOWN_129
135437,14 1 tw DialogicEvent 134,TDX_CST,1,0,0,DE_LCON,,
135437,14 1 event ScriptEventCode TDX_CST, code=134, state=900
135437,14 1 LsAwaitingCalls EV_UNKNOWN_134
135437,16 1 event callstate IDLE 1 1,0,0
135437,16 1 WorkingMode@Idle=
135437,16 1 timer clear
135437,17 1 rec RecSoundStop ok
135437,17 1 play PlaySoundStop ok
135437,17 1 rv add [CallEndTime]{2005-09-28 13:54:37}
135437,31 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
135437,31 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
135437,31 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
135437,31 1 LsAwaitingCalls EV_UNKNOWN_135
135438,31 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
135438,31 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
135438,31 1 init atidle reinit : start
135438,31 1 init atidle reinit iConferenceOtherLegLid=-1
135438,31 1 init atidle reinit : reset all LineState variables
135438,31 1 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
135438,31 1 state Waiting for a call...
135438,66 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
135438,66 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
135457,83 0 sys cleanup Start
135457,83 0 sys cleanup End
Thank you!
Jose
Looks like Cisco's PAP2-NA drops 'loop current' on the analog port about a second after the call is answered.
Loop current drop is usually used to indicate end of call - so that’s why VoiceGuide hangs up the call (see: http://www.voiceguide.com/vghelp/html/Disc...tionDetect.htm)
Can you configure the Cisco do loop current drop at the end of call? When using analog cards the loop current drop is the best way to determine when the call ends.
Here are the parts of traces which tell you it's the Loop Current Drop that’s happening:
and
151940.156 001 ev    TDX_CST DE_LCOF data=349
151940.156 001 te    LINE_CALLSTATE(1, 0x1, 0x4000, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_DISCONNECTED-DE_LCOF
151940.156 001 ocxfn RecStop(hLine=1, lRecId=0, lParam1=0, lParam2=0, strParam1=, strParam2=)
151940.171 001 ocxfn PlayStop(hLine=1, lPlayId=0(0x0), lParam1=0, lParam2=0, strParam1=, strParam2=)
151940.171 001 ocxfn LineDrop(sLineId=1, sOpt=0)
151940.171     ocxev DoFireDialogic(dwIdx=23, 1, 134, [TDX_CST], 349, 0, 0, [DE_LCOF], [], [])
Hello!
I have also seen in this file 0928tw.txt that there are errors in some parts of the trace. I wonder if that has nothing to do with this problem of hanging up the phone or if they are "normal".
151936.062 001 ev TDX_CST DE_RINGS data=0 ringcount=1 (hli=0x1b9f08, hli->chdev=1, hli->linedev=1)
151936.062 dx_gtextcallid(1,CLIDINFO_CMPLT) error [128]:[Caller ID info/sub-msg not available]
151936.062 dx_gtextcallid(1,CLIDINFO_GENERAL) error [128]:[Caller ID info/sub-msg not available]
151936.062 dx_gtextcallid(1,CLIDINFO_CALLID) error [128]:[Caller ID info/sub-msg not available]
151936.062 dx_gtextcallid(1,CLIDINFO_FRAMETYPE) error [128]:[Caller ID info/sub-msg not available]
Thank you!
Jose
I have not checked yet the loop current drop with my provider, but I am not sure if that is the problem. I have two identical computer (Windows XP Home E., D/41JCT-LS, Voiceguide for dialogic) running the same software and using the same PAP2 phone adapter(s). So when I connect this PAP2 to the other computer voiceguide does not hang up as it does in this computer. Well, there is a difference between these two computers; in this one where I am experiencing this problem I have a trial of voiceguide. I do not know whether this matters or not in the behaviour.
However, I have now tested the same script with a telephone line from another provider and voiceguide hangs up again. Well, the difference now it is that I hear almost two play modules before voiceguide hangs up.
Here it is the tw file.
Thank you!
jose
0929tw.txt
You can see in trace that the hangup is due to Loop Current Drop:
085257.796 002 ev    TDX_CST DE_LCOF data=2165
085257.796 002 te    LINE_CALLSTATE(2, 0x2, 0x4000, 0x0, 0x0) LINE_CALLSTATE-LINECALLSTATE_DISCONNECTED-DE_LCOF
and pretty much as soon as we hangup the call the Loop Current is back up again:
085257.859 002 ev    TDX_CST DE_LCON data=7
085258.000    ocxev DoFireDialogic(dwIdx=2, 2, 135, [TDX_SETHOOK], 0, 0, 0, [DX_ONHOOK], [], [])
085258.000    ocxev DoFireDialogic(dwIdx=3, 2, 134, [TDX_CST], 7, 0, 0, [DE_LCON], [], [])
as for the Caller ID related messages - that's normal when no CallerID was sent as FSK between first and second ring by the Telco.
Hello!
Ok, I see what you mean, but I don´t understand why this is happening because I can do the same call, i.e from the same caller to the same mobile phone number through the same PAP2 without using voiceguide and everything works fine.
So don´t you think it has to be something else that is forcing this tone?
Jose
Loop Current drop is not a tone - it's the current on the line itself.
We'd need to look at disabling VoiceGuide's reaction to it - but then you would need to rely on tone detection alone to determine end of call.
Try placing attached OCX in Windows' System32 directory overwriting existing file and then restart VG - this OCX disables VG's reaction to Loop Current drop
If this works for you then we'll look into disabling Loop Current drop reaction in the ConfigLine.xml file.
ktTelControl_LC_OFF_disabled.zip
Hello!
I tried with this new ocx file but still the same problem, so I changed the dialogic card with another of same model and then I switched back to the "old" ocx file and the loop current drop dissapeared.
However, I can´t make the script work properly. A person calls voiceguide which in turn calls a mobile number but after about 20 to 30 seconds voiceguide just hangs up no matter whether the third party doesn´t pick up the phone or the mobile phone is busy at that moment. Instead, voiceguide should play a message for the caller telling that nobody answered the phone but we will try with another phone number.
Here it is the tw.txt file.
Jose
0929tw.txt
Would be good to get the trace from the new OCX.
If the old OCX works with a different card then looks like the card you had originally was mistakenly detecting loop current drop...
The new problem you describe looks like a scripting problem.
Please post the script you are using and the MMDDvgm.txt trace - but start a new thread for it as it is a different issue (I suspect you do not have the right paths setup in your Transfer Call module).
Hello!
Sorry, but we have already sent the dialogic card back.
Ok, I´ll call the new thread "Script problem".
Thank you!
Jose
Hello!
Is it possible that all my problems are due to the fact that I am using Windows XP Home Edition? I have been looking around (intel,...) and I haven´t seen any place where Windows XP Home Edition is supported or have been tested for this kind of job.
Could you advice me? I have been working with this problem several months now and it feels like I am not moving forward.
Thank you!
Jose
The events we are seeing here are not influenced by the operating system used.
What we are seeing here is caused either the Dialogic card (if it's faulty) or the Cisco. My money's on the Cisco... Have a close look at it’s configuration options. Loop Current Drop behavior should be settable.
So has the problem reappeared again with the new card?
Have you tried using the OCX which was posted a week ago?
Hello!
I have already changed the cisco and still the same.
Well, this event
just dissapeared. I am not sure how but it is gone.
I have now a simple script playing short messages and hookflashes. The idea is that the caller hears the number one, then voiceguide plays a hookflash so the caller does not hear the 3 following numbers, then voiceguide plays another hookflash so the caller now hears the number five and then hangs up.
Well this simple script does not run all the time. If you got lucky then it works 2 or 3 times of five. I mean this is not stable. That it is way I asked you about the operating system. I don´t know what else to do. I have configured the Cisco adapter and my ConfigLine.xml according to this information:
URL: http://www.cisco.com/univercd/cc/td/doc/pr...up/swed_ch2.htm
jose
So what actually happens when the script does not run?
Do you have any trace capturing this “script does not run” situation?
Hello!
Yes, there are several situations where voiceguide (or my Cisco adapter), for some reason that I don´t know, don´t work at all.
In this first trace log, voiceguide hung up the phone. I can see in the trace log this: "165920,66 2 event callstate DISCONNECTED 2 16384,0,0" but I AM SURE that I didn´t hang up the phone. I have recorded and analised the disconnect tone from my Cisco adapter and it has the same configuration as the ConfigLine.xml file.
165918,89 2 tw dtmf a (2,97,97)
165918,89 2 event ScriptEventCode a, code=97, state=900
165918,89 2 LsAwaitingCalls a
165918,89 2 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
165918,89 2 event ScriptEventCode TDX_CST, code=134, state=900
165918,89 2 LsAwaitingCalls EV_UNKNOWN_134
165919,05 2 tw dtmf 4 (2,52,52)
165919,05 2 event ScriptEventCode 4, code=52, state=900
165919,05 2 LsAwaitingCalls 4
165919,05 2 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
165919,05 2 event ScriptEventCode TDX_CST, code=134, state=900
165919,05 2 LsAwaitingCalls EV_UNKNOWN_134
165919,20 2 tw dtmf 1 (2,49,49)
165919,20 2 event ScriptEventCode 1, code=49, state=900
165919,20 2 LsAwaitingCalls 1
165919,20 2 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
165919,20 2 event ScriptEventCode TDX_CST, code=134, state=900
165919,20 2 LsAwaitingCalls EV_UNKNOWN_134
165919,38 2 tw dtmf # (2,35,35)
165919,38 2 event ScriptEventCode #, code=35, state=900
165919,38 2 LsAwaitingCalls #
165919,38 2 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
165919,38 2 event ScriptEventCode TDX_CST, code=134, state=900
165919,39 2 LsAwaitingCalls EV_UNKNOWN_134
165919,97 2 event callstate OFFERING 2 2,0,0
165919,97 2 script interpretor: VgMulti v6.0.2275
165919,97 2 fired OFFERING event to listeners
165919,97 2 set LineState().hCall = 2 in LINECALLSTATE_OFFERING
165919,97 2 iIvrDev=2
165919,98 2 set linestate CID vars
165919,98 2 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
165919,98 2 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
165919,98 2 tw ring 1
165919,98 2 ring time since last ring event (sec): 0,00
165919,98 2 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
165920,00 2 rv clear all
165920,00 2 init LineState ResetAtStartOfNewCall.
165920,00 2 answer the call
165920,00 2 timer clear
165920,02 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
165920,02 2 event ScriptEventCode TDX_CST, code=134, state=6001
165920,61 2 event callstate CONNECTED 2 256,0,0
165920,61 2 LineEvCallState_Connected hDevice=2 params=256,0,0
165920,61 2 WorkingModes tapi= script= LineState().iState=6001
165920,61 2 Inband detection not enabled
165920,61 2 StartLoadedVgs at 2005-10-06 16:59:20 [VgMulti v6.0.2275]
165920,63 2 set LineState().iVgsIdx=2
165920,63 2 set sScriptToRunOnHangup=[] in StartLoadedVgs
165920,63 2 init StartLoadedVgs_InitLineState start
165920,63 2 rv add [$RV_STARTTIME]{2005-10-06 16:59:20}
165920,63 2 rv add [$RV_DEVICEID]{2}
165920,63 2 rv add [$RV_CIDNAME]{}
165920,64 2 rvns add [PathApp]{C:\Program\VoiceGuide\}
165920,64 2 rvns add [scriptsPath]{C:\Voice_jose_testing\hookflah\}
165920,64 2 rv add [$RV_CIDNUMBER]{}
165920,64 2 fn RunModule start
165920,64 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
165920,64 2 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
165920,66 2 tw DialogicEvent 134,TDX_CST,5884,0,0,DE_LCON,,
165920,66 2 event ScriptEventCode TDX_CST, code=134, state=6001
165920,66 2 event ScriptEventCode EV_REMOTEPARTY_DISCONNECT, code=9250, state=6001
165920,66 2 rv add [Hangup Time]{2005-10-06 16:59:20}
165920,66 2 state Hanging up call... [LsModuleTransition]
165920,67 2 HangupCall_Common hCall=2
165920,67 2 rec RecSoundStop ok
165920,67 2 play PlaySoundStop ok
165920,67 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
165920,67 2 fnHangupCall end
165920,69 2 tw DialogicEvent 134,TDX_CST,1,0,0,DE_LCOF,,
165920,69 2 event ScriptEventCode TDX_CST, code=134, state=900
165920,69 2 LsAwaitingCalls EV_UNKNOWN_134
165920,69 2 ERROR RunModule called while iHangupCalledForThisLine>0 (strWorkingModeScript=)
165922,59 2 event callstate IDLE 2 1,0,0
165922,59 2 WorkingMode@Idle=
165922,59 2 timer clear
165922,59 2 rec RecSoundStop ok
165922,61 2 play PlaySoundStop ok
165922,61 2 rv add [CallEndTime]{2005-10-06 16:59:22}
165922,63 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
165922,63 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
165922,63 2 event ScriptEventCode TDX_SETHOOK, code=135, state=900
165922,63 2 LsAwaitingCalls EV_UNKNOWN_135
165923,64 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
165923,64 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
165923,64 2 init atidle reinit : start
165923,64 2 init atidle reinit iConferenceOtherLegLid=-1
165923,64 2 init atidle reinit : reset all LineState variables
165923,64 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
165923,66 2 state Waiting for a call...
165923,98 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
165923,98 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
There is also another situation where voiceguide plays the first hookflash which my Cisco adapter understands, but no the second hookflash so voiceguide iterates with the script 3 times before it hangs up.
Here it is the trace log:
171452,58 2 tw dtmf a (2,97,97)
171452,58 2 event ScriptEventCode a, code=97, state=0
171452,58 2 tw DialogicEvent 134,TDX_CST,97,0,0,DE_DIGITS,,
171452,58 2 event ScriptEventCode TDX_CST, code=134, state=0
171452,73 2 tw dtmf 4 (2,52,52)
171452,73 2 event ScriptEventCode 4, code=52, state=0
171452,73 2 tw DialogicEvent 134,TDX_CST,52,0,0,DE_DIGITS,,
171452,73 2 event ScriptEventCode TDX_CST, code=134, state=0
171452,88 2 tw dtmf 1 (2,49,49)
171452,89 2 event ScriptEventCode 1, code=49, state=0
171452,89 2 tw DialogicEvent 134,TDX_CST,49,0,0,DE_DIGITS,,
171452,89 2 event ScriptEventCode TDX_CST, code=134, state=0
171453,06 2 tw dtmf # (2,35,35)
171453,06 2 event ScriptEventCode #, code=35, state=0
171453,06 2 tw DialogicEvent 134,TDX_CST,35,0,0,DE_DIGITS,,
171453,06 2 event ScriptEventCode TDX_CST, code=134, state=0
171453,66 2 event callstate OFFERING 2 2,0,0
171453,66 2 script interpretor: VgMulti v6.0.2275
171453,66 2 fired OFFERING event to listeners
171453,66 2 set LineState().hCall = 2 in LINECALLSTATE_OFFERING
171453,67 2 iIvrDev=2
171453,67 2 set linestate CID vars
171453,67 2 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171453,67 2 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171453,67 2 tw ring 1
171453,67 2 ring time since last ring event (sec): 0,00
171453,69 2 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171453,69 2 rv clear all
171453,69 2 init LineState ResetAtStartOfNewCall.
171453,69 2 answer the call
171453,69 2 timer clear
171453,70 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171453,70 2 event ScriptEventCode TDX_CST, code=134, state=6001
171454,28 2 event callstate CONNECTED 2 256,0,0
171454,30 2 LineEvCallState_Connected hDevice=2 params=256,0,0
171454,30 2 WorkingModes tapi= script= LineState().iState=6001
171455,31 2 Inband detection not enabled
171455,31 2 StartLoadedVgs at 2005-10-06 17:14:55 [VgMulti v6.0.2275]
171455,31 2 set LineState().iVgsIdx=2
171455,31 2 set sScriptToRunOnHangup=[] in StartLoadedVgs
171455,31 2 init StartLoadedVgs_InitLineState start
171455,33 2 rv add [$RV_STARTTIME]{2005-10-06 17:14:55}
171455,33 2 rv add [$RV_DEVICEID]{2}
171455,33 2 rv add [$RV_CIDNAME]{}
171455,33 2 rvns add [PathApp]{C:\Program\VoiceGuide\}
171455,33 2 rvns add [scriptsPath]{C:\Voice_jose_testing\hookflah\}
171455,33 2 rv add [$RV_CIDNUMBER]{}
171455,34 2 fn RunModule start
171455,34 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171455,34 2 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
171455,34 2 tw DialogicEvent 134,TDX_CST,4594,0,0,DE_LCON,,
171455,34 2 event ScriptEventCode TDX_CST, code=134, state=6001
171455,36 2 timer clear
171455,36 2 Play Module start
171455,38 2 state [1] Playing
171455,38 2 state [1] Playing (C:\Voice_jose_testing\hookflah\1.wav)
171455,38 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\1.wav
171455,38 2 timer clear
171455,41 2 tw wav->vox convert end 595875,C:\Voice_jose_testing\hookflah\1.vox,1,0,,
171455,42 2 play start ok, lPlayId=595906
171456,69 2 tw PlayEnd 2 595906
171456,69 2 play end id=595906, (current ID)
171456,69 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171456,69 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171456,70 2 path {EV_PLAY_FINISHED} not found
171456,70 2 timer set 10 EV_TIMEOUT_HANGUP
171456,70 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171456,70 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171456,70 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171456,70 2 path {EV_TIMEOUT_GOTOMODULE} not found
171456,70 2 fn RunModule start
171456,72 2 timer clear
171456,72 2 Play Module start
171456,72 2 state Playing
171456,72 2 state Playing (!,,) using tw.PlayStart
171456,72 2 play start ok, lPlayId=597218
171456,73 2 tw DialogicEvent 129,TDX_PLAY,595906,0,0,,,
171456,73 2 event ScriptEventCode TDX_PLAY, code=129, state=1100
171456,73 2 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
171456,73 2 path {TDX_PLAY} not found
171458,83 2 tw PlayEnd 2 597218
171458,83 2 play end id=597218, (current ID)
171458,84 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171458,84 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171458,84 2 path {EV_PLAY_FINISHED} not found
171458,84 2 timer set 10 EV_TIMEOUT_HANGUP
171458,84 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171458,84 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171458,86 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171458,86 2 path {EV_TIMEOUT_GOTOMODULE} not found
171458,86 2 fn RunModule start
171458,86 2 timer clear
171458,86 2 Play Module start
171458,86 2 state [2] Playing
171458,88 2 state [2] Playing (C:\Voice_jose_testing\hookflah\2.wav)
171458,88 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\2.wav
171458,88 2 timer clear
171458,88 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171458,88 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171458,89 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171458,89 2 path {TDX_DIAL} not found
171458,97 2 tw wav->vox convert end 599375,C:\Voice_jose_testing\hookflah\2.vox,1,0,,
171458,97 2 play start ok, lPlayId=599468
171459,83 2 tw PlayEnd 2 599468
171459,83 2 play end id=599468, (current ID)
171459,83 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171459,84 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171459,84 2 path {EV_PLAY_FINISHED} not found
171459,84 2 timer set 10 EV_TIMEOUT_HANGUP
171459,84 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171459,84 2 tw DialogicEvent 129,TDX_PLAY,599468,0,0,,,
171459,84 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171459,86 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171459,86 2 path {TDX_PLAY} not found
171500,83 2 timer fired EV_TIMEOUT_GOTOMODULE
171500,83 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171500,83 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171500,83 2 path {EV_TIMEOUT_GOTOMODULE} not found
171500,83 2 fn RunModule start
171500,84 2 timer clear
171500,84 2 Play Module start
171500,84 2 state [3] Playing
171500,84 2 state [3] Playing (C:\Voice_jose_testing\hookflah\3.wav)
171500,84 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\3.wav
171500,89 2 tw wav->vox convert end 601343,C:\Voice_jose_testing\hookflah\3.vox,1,0,,
171500,89 2 play start ok, lPlayId=601390
171502,16 2 tw PlayEnd 2 601390
171502,16 2 play end id=601390, (current ID)
171502,16 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171502,17 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171502,17 2 path {EV_PLAY_FINISHED} not found
171502,17 2 timer set 10 EV_TIMEOUT_HANGUP
171502,17 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171502,17 2 tw DialogicEvent 129,TDX_PLAY,601390,0,0,,,
171502,17 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171502,19 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171502,19 2 path {TDX_PLAY} not found
171503,16 2 timer fired EV_TIMEOUT_GOTOMODULE
171503,16 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171503,16 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171503,16 2 path {EV_TIMEOUT_GOTOMODULE} not found
171503,16 2 fn RunModule start
171503,16 2 timer clear
171503,17 2 Play Module start
171503,17 2 state [4] Playing
171503,17 2 state [4] Playing (C:\Voice_jose_testing\hookflah\4.wav)
171503,17 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\4.wav
171503,17 2 timer clear
171503,20 2 tw wav->vox convert end 603671,C:\Voice_jose_testing\hookflah\4.vox,1,0,,
171503,22 2 play start ok, lPlayId=603703
171504,08 2 tw PlayEnd 2 603703
171504,08 2 play end id=603703, (current ID)
171504,08 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171504,09 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171504,09 2 path {EV_PLAY_FINISHED} not found
171504,09 2 timer set 10 EV_TIMEOUT_HANGUP
171504,09 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171504,09 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171504,09 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171504,11 2 path {EV_TIMEOUT_GOTOMODULE} not found
171504,11 2 fn RunModule start
171504,11 2 timer clear
171504,11 2 Play Module start
171504,11 2 state [flash2] Playing
171504,11 2 state [flash2] Playing (!,,) using tw.PlayStart
171504,13 2 timer clear
171504,13 2 play start ok, lPlayId=604625
171504,13 2 tw DialogicEvent 129,TDX_PLAY,603703,0,0,,,
171504,13 2 event ScriptEventCode TDX_PLAY, code=129, state=1100
171504,13 2 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
171504,13 2 path {TDX_PLAY} not found
171506,23 2 tw PlayEnd 2 604625
171506,23 2 play end id=604625, (current ID)
171506,23 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171506,23 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171506,23 2 path {EV_PLAY_FINISHED} not found
171506,23 2 timer set 10 EV_TIMEOUT_HANGUP
171506,25 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171506,25 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171506,25 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171506,25 2 path {EV_TIMEOUT_GOTOMODULE} not found
171506,25 2 fn RunModule start
171506,25 2 timer clear
171506,27 2 Play Module start
171506,27 2 state [5] Playing
171506,27 2 state [5] Playing (C:\Voice_jose_testing\hookflah\5.wav)
171506,27 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\5.wav
171506,27 2 timer clear
171506,28 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171506,28 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171506,28 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171506,28 2 path {TDX_DIAL} not found
171506,36 2 tw wav->vox convert end 606765,C:\Voice_jose_testing\hookflah\5.vox,1,0,,
171506,38 2 play start ok, lPlayId=606859
171507,23 2 tw PlayEnd 2 606859
171507,23 2 play end id=606859, (current ID)
171507,23 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171507,23 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171507,25 2 path {EV_PLAY_FINISHED} not found
171507,25 2 timer set 10 EV_TIMEOUT_HANGUP
171507,25 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171507,25 2 tw DialogicEvent 129,TDX_PLAY,606859,0,0,,,
171507,25 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171507,27 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171507,27 2 path {TDX_PLAY} not found
171507,36 0 sys cleanup Start
171507,36 0 sys cleanup End
171508,33 2 timer fired EV_TIMEOUT_GOTOMODULE
171508,33 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171508,33 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171508,33 2 path {EV_TIMEOUT_GOTOMODULE} not found
171508,33 2 fn RunModule start
171508,33 2 timer clear
171508,34 2 rv add [Hangup Time]{2005-10-06 17:15:08}
171508,34 2 state Hanging up call... [Hangup Module]
171508,34 2 HangupCall_Common hCall=2
171508,34 2 rec RecSoundStop ok
171508,36 2 play PlaySoundStop ok
171508,36 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171508,36 2 fnHangupCall end
171508,41 2 event callstate IDLE 2 1,0,0
171508,41 2 WorkingMode@Idle=
171508,41 2 timer clear
171508,41 2 rec RecSoundStop ok
171508,41 2 play PlaySoundStop ok
171508,42 2 rv add [CallEndTime]{2005-10-06 17:15:08}
171508,44 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
171508,44 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171508,44 2 event ScriptEventCode TDX_SETHOOK, code=135, state=900
171508,44 2 LsAwaitingCalls EV_UNKNOWN_135
171509,45 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
171509,45 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
171509,45 2 init atidle reinit : start
171509,45 2 init atidle reinit iConferenceOtherLegLid=-1
171509,45 2 init atidle reinit : reset all LineState variables
171509,45 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
171509,47 2 state Waiting for a call...
171509,47 2 event callstate OFFERING 2 2,0,0
171509,47 2 script interpretor: VgMulti v6.0.2275
171509,48 2 fired OFFERING event to listeners
171509,48 2 set LineState().hCall = 2 in LINECALLSTATE_OFFERING
171509,48 2 iIvrDev=2
171509,48 2 set linestate CID vars
171509,48 2 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171509,48 2 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171509,50 2 tw ring 1
171509,50 2 ring time since last ring event (sec): 0,00
171509,50 2 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171509,50 2 rv clear all
171509,50 2 init LineState ResetAtStartOfNewCall.
171509,52 2 answer the call
171509,52 2 timer clear
171509,52 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171509,52 2 event ScriptEventCode TDX_CST, code=134, state=6001
171510,11 2 event callstate CONNECTED 2 256,0,0
171510,13 2 LineEvCallState_Connected hDevice=2 params=256,0,0
171510,13 2 WorkingModes tapi= script= LineState().iState=6001
171510,13 2 Inband detection not enabled
171510,13 2 StartLoadedVgs at 2005-10-06 17:15:10 [VgMulti v6.0.2275]
171510,14 2 set LineState().iVgsIdx=2
171510,14 2 set sScriptToRunOnHangup=[] in StartLoadedVgs
171510,14 2 init StartLoadedVgs_InitLineState start
171510,14 2 rv add [$RV_STARTTIME]{2005-10-06 17:15:10}
171510,14 2 rv add [$RV_DEVICEID]{2}
171510,14 2 rv add [$RV_CIDNAME]{}
171510,16 2 rvns add [PathApp]{C:\Program\VoiceGuide\}
171510,16 2 rvns add [scriptsPath]{C:\Voice_jose_testing\hookflah\}
171510,16 2 rv add [$RV_CIDNUMBER]{}
171510,16 2 fn RunModule start
171510,16 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171510,17 2 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
171510,17 2 tw DialogicEvent 134,TDX_CST,172,0,0,DE_LCON,,
171510,17 2 event ScriptEventCode TDX_CST, code=134, state=6001
171510,17 2 timer clear
171510,17 2 Play Module start
171510,19 2 state [1] Playing
171510,19 2 state [1] Playing (C:\Voice_jose_testing\hookflah\1.wav)
171510,19 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\1.wav
171510,19 2 timer clear
171510,22 2 tw wav->vox convert end 610687,C:\Voice_jose_testing\hookflah\1.vox,1,0,,
171510,23 2 play start ok, lPlayId=610734
171511,50 2 tw PlayEnd 2 610734
171511,50 2 play end id=610734, (current ID)
171511,50 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171511,50 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171511,50 2 path {EV_PLAY_FINISHED} not found
171511,52 2 timer set 10 EV_TIMEOUT_HANGUP
171511,52 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171511,52 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171511,52 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171511,52 2 path {EV_TIMEOUT_GOTOMODULE} not found
171511,52 2 fn RunModule start
171511,53 2 timer clear
171511,53 2 Play Module start
171511,53 2 state Playing
171511,53 2 state Playing (!,,) using tw.PlayStart
171511,55 2 play start ok, lPlayId=612031
171511,55 2 tw DialogicEvent 129,TDX_PLAY,610734,0,0,,,
171511,55 2 event ScriptEventCode TDX_PLAY, code=129, state=1100
171511,55 2 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
171511,55 2 path {TDX_PLAY} not found
171513,64 2 tw PlayEnd 2 612031
171513,66 2 play end id=612031, (current ID)
171513,66 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171513,66 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171513,66 2 path {EV_PLAY_FINISHED} not found
171513,66 2 timer set 10 EV_TIMEOUT_HANGUP
171513,67 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171513,67 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171513,67 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171513,67 2 path {EV_TIMEOUT_GOTOMODULE} not found
171513,67 2 fn RunModule start
171513,69 2 timer clear
171513,69 2 Play Module start
171513,69 2 state [2] Playing
171513,69 2 state [2] Playing (C:\Voice_jose_testing\hookflah\2.wav)
171513,69 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\2.wav
171513,70 2 timer clear
171513,70 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171513,70 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171513,70 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171513,70 2 path {TDX_DIAL} not found
171513,77 2 tw wav->vox convert end 614187,C:\Voice_jose_testing\hookflah\2.vox,1,0,,
171513,78 2 play start ok, lPlayId=614265
171514,64 2 tw PlayEnd 2 614265
171514,64 2 play end id=614265, (current ID)
171514,64 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171514,64 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171514,66 2 path {EV_PLAY_FINISHED} not found
171514,66 2 timer set 10 EV_TIMEOUT_HANGUP
171514,66 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171514,66 2 tw DialogicEvent 129,TDX_PLAY,614265,0,0,,,
171514,66 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171514,67 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171514,67 2 path {TDX_PLAY} not found
171515,66 2 timer fired EV_TIMEOUT_GOTOMODULE
171515,66 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171515,66 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171515,66 2 path {EV_TIMEOUT_GOTOMODULE} not found
171515,66 2 fn RunModule start
171515,67 2 timer clear
171515,67 2 Play Module start
171515,67 2 state [3] Playing
171515,67 2 state [3] Playing (C:\Voice_jose_testing\hookflah\3.wav)
171515,67 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\3.wav
171515,69 2 timer clear
171515,69 2 tw wav->vox convert end 616171,C:\Voice_jose_testing\hookflah\3.vox,1,0,,
171515,70 2 play start ok, lPlayId=616187
171516,97 2 tw PlayEnd 2 616187
171516,97 2 play end id=616187, (current ID)
171516,97 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171516,97 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171516,98 2 path {EV_PLAY_FINISHED} not found
171516,98 2 timer set 10 EV_TIMEOUT_HANGUP
171516,98 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171516,98 2 tw DialogicEvent 129,TDX_PLAY,616187,0,0,,,
171516,98 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171517,00 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171517,00 2 path {TDX_PLAY} not found
171517,98 2 timer fired EV_TIMEOUT_GOTOMODULE
171517,98 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171517,98 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171517,98 2 path {EV_TIMEOUT_GOTOMODULE} not found
171517,98 2 fn RunModule start
171518,00 2 timer clear
171518,00 2 Play Module start
171518,00 2 state [4] Playing
171518,00 2 state [4] Playing (C:\Voice_jose_testing\hookflah\4.wav)
171518,00 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\4.wav
171518,02 2 timer clear
171518,11 2 tw wav->vox convert end 618500,C:\Voice_jose_testing\hookflah\4.vox,1,0,,
171518,13 2 play start ok, lPlayId=618609
171519,00 2 tw PlayEnd 2 618609
171519,00 2 play end id=618609, (current ID)
171519,00 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171519,00 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171519,00 2 path {EV_PLAY_FINISHED} not found
171519,02 2 timer set 10 EV_TIMEOUT_HANGUP
171519,02 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171519,02 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171519,02 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171519,02 2 path {EV_TIMEOUT_GOTOMODULE} not found
171519,03 2 fn RunModule start
171519,03 2 tw DialogicEvent 129,TDX_PLAY,618609,0,0,,,
171519,03 2 event ScriptEventCode TDX_PLAY, code=129, state=6001
171519,03 2 timer clear
171519,03 2 Play Module start
171519,05 2 state [flash2] Playing
171519,05 2 state [flash2] Playing (!,,) using tw.PlayStart
171519,05 2 timer clear
171519,05 2 play start ok, lPlayId=619546
171521,16 2 tw PlayEnd 2 619546
171521,16 2 play end id=619546, (current ID)
171521,16 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171521,17 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171521,17 2 path {EV_PLAY_FINISHED} not found
171521,17 2 timer set 10 EV_TIMEOUT_HANGUP
171521,17 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171521,17 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171521,19 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171521,19 2 path {EV_TIMEOUT_GOTOMODULE} not found
171521,19 2 fn RunModule start
171521,19 2 timer clear
171521,20 2 Play Module start
171521,20 2 state [5] Playing
171521,20 2 state [5] Playing (C:\Voice_jose_testing\hookflah\5.wav)
171521,20 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\5.wav
171521,20 2 timer clear
171521,22 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171521,22 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171521,22 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171521,22 2 path {TDX_DIAL} not found
171521,23 2 tw wav->vox convert end 621703,C:\Voice_jose_testing\hookflah\5.vox,1,0,,
171521,25 2 play start ok, lPlayId=621750
171522,11 2 tw PlayEnd 2 621750
171522,11 2 play end id=621750, (current ID)
171522,13 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171522,13 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171522,13 2 path {EV_PLAY_FINISHED} not found
171522,13 2 timer set 10 EV_TIMEOUT_HANGUP
171522,13 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171522,14 2 tw DialogicEvent 129,TDX_PLAY,621750,0,0,,,
171522,14 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171522,14 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171522,14 2 path {TDX_PLAY} not found
171523,16 2 timer fired EV_TIMEOUT_GOTOMODULE
171523,16 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171523,16 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171523,16 2 path {EV_TIMEOUT_GOTOMODULE} not found
171523,16 2 fn RunModule start
171523,17 2 timer clear
171523,17 2 rv add [Hangup Time]{2005-10-06 17:15:23}
171523,17 2 state Hanging up call... [Hangup Module]
171523,17 2 HangupCall_Common hCall=2
171523,19 2 rec RecSoundStop ok
171523,19 2 play PlaySoundStop ok
171523,19 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171523,19 2 fnHangupCall end
171523,23 2 event callstate IDLE 2 1,0,0
171523,23 2 WorkingMode@Idle=
171523,23 2 timer clear
171523,25 2 rec RecSoundStop ok
171523,25 2 play PlaySoundStop ok
171523,25 2 rv add [CallEndTime]{2005-10-06 17:15:23}
171523,27 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
171523,27 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171523,27 2 event ScriptEventCode TDX_SETHOOK, code=135, state=900
171523,28 2 LsAwaitingCalls EV_UNKNOWN_135
171524,28 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
171524,28 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
171524,28 2 init atidle reinit : start
171524,28 2 init atidle reinit iConferenceOtherLegLid=-1
171524,28 2 init atidle reinit : reset all LineState variables
171524,30 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
171524,30 2 state Waiting for a call...
171524,31 2 event callstate OFFERING 2 2,0,0
171524,33 2 script interpretor: VgMulti v6.0.2275
171524,33 2 fired OFFERING event to listeners
171524,33 2 set LineState().hCall = 2 in LINECALLSTATE_OFFERING
171524,33 2 iIvrDev=2
171524,33 2 set linestate CID vars
171524,34 2 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
171524,34 2 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
171524,34 2 tw ring 1
171524,34 2 ring time since last ring event (sec): 0,00
171524,36 2 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
171524,36 2 rv clear all
171524,36 2 init LineState ResetAtStartOfNewCall.
171524,36 2 answer the call
171524,36 2 timer clear
171524,38 2 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
171524,38 2 event ScriptEventCode TDX_CST, code=134, state=6001
171524,97 2 event callstate CONNECTED 2 256,0,0
171524,97 2 LineEvCallState_Connected hDevice=2 params=256,0,0
171524,97 2 WorkingModes tapi= script= LineState().iState=6001
171524,97 2 Inband detection not enabled
171524,98 2 StartLoadedVgs at 2005-10-06 17:15:24 [VgMulti v6.0.2275]
171524,98 2 set LineState().iVgsIdx=2
171524,98 2 set sScriptToRunOnHangup=[] in StartLoadedVgs
171524,98 2 init StartLoadedVgs_InitLineState start
171525,00 2 rv add [$RV_STARTTIME]{2005-10-06 17:15:24}
171525,00 2 rv add [$RV_DEVICEID]{2}
171525,00 2 rv add [$RV_CIDNAME]{}
171525,00 2 rvns add [PathApp]{C:\Program\VoiceGuide\}
171525,00 2 rvns add [scriptsPath]{C:\Voice_jose_testing\hookflah\}
171525,02 2 rv add [$RV_CIDNUMBER]{}
171525,02 2 fn RunModule start
171525,02 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
171525,02 2 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
171525,03 2 tw DialogicEvent 134,TDX_CST,172,0,0,DE_LCON,,
171525,03 2 event ScriptEventCode TDX_CST, code=134, state=6001
171525,03 2 timer clear
171525,03 2 Play Module start
171525,03 2 state [1] Playing
171525,05 2 state [1] Playing (C:\Voice_jose_testing\hookflah\1.wav)
171525,05 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\1.wav
171525,05 2 timer clear
171525,08 2 tw wav->vox convert end 625546,C:\Voice_jose_testing\hookflah\1.vox,1,0,,
171525,09 2 play start ok, lPlayId=625578
171526,34 2 tw PlayEnd 2 625578
171526,36 2 play end id=625578, (current ID)
171526,36 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171526,36 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171526,36 2 path {EV_PLAY_FINISHED} not found
171526,36 2 timer set 10 EV_TIMEOUT_HANGUP
171526,38 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171526,38 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171526,38 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171526,38 2 path {EV_TIMEOUT_GOTOMODULE} not found
171526,39 2 fn RunModule start
171526,39 2 tw DialogicEvent 129,TDX_PLAY,625578,0,0,,,
171526,39 2 event ScriptEventCode TDX_PLAY, code=129, state=6001
171526,39 2 timer clear
171526,41 2 Play Module start
171526,41 2 state Playing
171526,41 2 state Playing (!,,) using tw.PlayStart
171526,41 2 timer clear
171526,41 2 play start ok, lPlayId=626906
171528,52 2 tw PlayEnd 2 626906
171528,52 2 play end id=626906, (current ID)
171528,53 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171528,53 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171528,53 2 path {EV_PLAY_FINISHED} not found
171528,53 2 timer set 10 EV_TIMEOUT_HANGUP
171528,53 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171528,55 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171528,55 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171528,55 2 path {EV_TIMEOUT_GOTOMODULE} not found
171528,55 2 fn RunModule start
171528,56 2 timer clear
171528,56 2 Play Module start
171528,56 2 state [2] Playing
171528,56 2 state [2] Playing (C:\Voice_jose_testing\hookflah\2.wav)
171528,58 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\2.wav
171528,58 2 timer clear
171528,58 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171528,58 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171528,58 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171528,59 2 path {TDX_DIAL} not found
171528,61 2 tw wav->vox convert end 629078,C:\Voice_jose_testing\hookflah\2.vox,1,0,,
171528,63 2 play start ok, lPlayId=629109
171529,48 2 tw PlayEnd 2 629109
171529,48 2 play end id=629109, (current ID)
171529,48 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171529,48 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171529,50 2 path {EV_PLAY_FINISHED} not found
171529,52 2 timer set 10 EV_TIMEOUT_HANGUP
171529,52 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171529,52 2 tw DialogicEvent 129,TDX_PLAY,629109,0,0,,,
171529,52 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171529,52 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171529,53 2 path {TDX_PLAY} not found
171530,56 2 timer fired EV_TIMEOUT_GOTOMODULE
171530,56 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171530,56 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171530,56 2 path {EV_TIMEOUT_GOTOMODULE} not found
171530,56 2 fn RunModule start
171530,58 2 timer clear
171530,58 2 Play Module start
171530,58 2 state [3] Playing
171530,58 2 state [3] Playing (C:\Voice_jose_testing\hookflah\3.wav)
171530,58 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\3.wav
171530,59 2 timer clear
171530,64 2 tw wav->vox convert end 631078,C:\Voice_jose_testing\hookflah\3.vox,1,0,,
171530,64 2 play start ok, lPlayId=631140
171531,91 2 tw PlayEnd 2 631140
171531,91 2 play end id=631140, (current ID)
171531,91 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171531,92 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171531,92 2 path {EV_PLAY_FINISHED} not found
171531,92 2 timer set 10 EV_TIMEOUT_HANGUP
171531,92 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171531,92 2 tw DialogicEvent 129,TDX_PLAY,631140,0,0,,,
171531,94 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171531,94 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171531,94 2 path {TDX_PLAY} not found
171533,00 2 timer fired EV_TIMEOUT_GOTOMODULE
171533,00 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171533,00 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171533,00 2 path {EV_TIMEOUT_GOTOMODULE} not found
171533,00 2 fn RunModule start
171533,02 2 timer clear
171533,02 2 Play Module start
171533,02 2 state [4] Playing
171533,02 2 state [4] Playing (C:\Voice_jose_testing\hookflah\4.wav)
171533,02 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\4.wav
171533,03 2 timer clear
171533,06 2 tw wav->vox convert end 633515,C:\Voice_jose_testing\hookflah\4.vox,1,0,,
171533,06 2 play start ok, lPlayId=633562
171533,94 2 tw PlayEnd 2 633562
171533,94 2 play end id=633562, (current ID)
171533,94 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171533,94 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171533,95 2 path {EV_PLAY_FINISHED} not found
171533,95 2 timer set 10 EV_TIMEOUT_HANGUP
171533,95 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171533,95 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171533,95 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171533,97 2 path {EV_TIMEOUT_GOTOMODULE} not found
171533,97 2 fn RunModule start
171533,97 2 timer clear
171533,97 2 Play Module start
171533,97 2 state [flash2] Playing
171533,98 2 state [flash2] Playing (!,,) using tw.PlayStart
171533,98 2 timer clear
171533,98 2 play start ok, lPlayId=634484
171533,98 2 tw DialogicEvent 129,TDX_PLAY,633562,0,0,,,
171534,00 2 event ScriptEventCode TDX_PLAY, code=129, state=1100
171534,00 2 LsPlayMsg EV_UNKNOWN_129,TDX_PLAY
171534,00 2 path {TDX_PLAY} not found
171536,09 2 tw PlayEnd 2 634484
171536,09 2 play end id=634484, (current ID)
171536,09 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171536,11 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171536,11 2 path {EV_PLAY_FINISHED} not found
171536,11 2 timer set 10 EV_TIMEOUT_HANGUP
171536,11 2 timer set 0 EV_TIMEOUT_GOTOMODULE
171536,11 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171536,13 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171536,13 2 path {EV_TIMEOUT_GOTOMODULE} not found
171536,13 2 fn RunModule start
171536,13 2 timer clear
171536,14 2 Play Module start
171536,14 2 state [5] Playing
171536,14 2 state [5] Playing (C:\Voice_jose_testing\hookflah\5.wav)
171536,14 2 tw ConvertWav2Vox C:\Voice_jose_testing\hookflah\5.wav
171536,14 2 timer clear
171536,16 2 tw DialogicEvent 132,TDX_DIAL,0,0,0,,,
171536,16 2 event ScriptEventCode TDX_DIAL, code=132, state=1100
171536,16 2 LsPlayMsg EV_UNKNOWN_132,TDX_DIAL
171536,16 2 path {TDX_DIAL} not found
171536,19 2 tw wav->vox convert end 636640,C:\Voice_jose_testing\hookflah\5.vox,1,0,,
171536,20 2 play start ok, lPlayId=636687
171537,06 2 tw PlayEnd 2 636687
171537,06 2 play end id=636687, (current ID)
171537,08 2 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
171537,08 2 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
171537,08 2 path {EV_PLAY_FINISHED} not found
171537,08 2 timer set 10 EV_TIMEOUT_HANGUP
171537,08 2 timer set 1 EV_TIMEOUT_GOTOMODULE
171537,09 2 tw DialogicEvent 129,TDX_PLAY,636687,0,0,,,
171537,09 2 event ScriptEventCode TDX_PLAY, code=129, state=1101
171537,09 2 LsPlayMsgFinished EV_UNKNOWN_129,TDX_PLAY
171537,09 2 path {TDX_PLAY} not found
171538,08 2 timer fired EV_TIMEOUT_GOTOMODULE
171538,08 2 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
171538,08 2 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
171538,08 2 path {EV_TIMEOUT_GOTOMODULE} not found
171538,08 2 fn RunModule start
171538,09 2 timer clear
171538,09 2 rv add [Hangup Time]{2005-10-06 17:15:38}
171538,09 2 state Hanging up call... [Hangup Module]
171538,09 2 HangupCall_Common hCall=2
171538,11 2 rec RecSoundStop ok
171538,11 2 play PlaySoundStop ok
171538,11 2 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
171538,11 2 fnHangupCall end
171538,16 2 event callstate IDLE 2 1,0,0
171538,16 2 WorkingMode@Idle=
171538,17 2 timer clear
171538,17 2 rec RecSoundStop ok
171538,17 2 play PlaySoundStop ok
171538,17 2 rv add [CallEndTime]{2005-10-06 17:15:38}
171538,19 2 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
171538,20 2 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
171538,20 2 event ScriptEventCode TDX_SETHOOK, code=135, state=900
171538,20 2 LsAwaitingCalls EV_UNKNOWN_135
171539,22 2 timer fired EV_TIMEOUT_TIMETOREINITLINE
171539,22 2 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
171539,22 2 init atidle reinit : start
171539,22 2 init atidle reinit iConferenceOtherLegLid=-1
171539,22 2 init atidle reinit : reset all LineState variables
171539,23 2 timer set 0,3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
171539,23 2 state Waiting for a call...
171539,56 2 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
171539,56 2 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
jose
We'll need to see the MMDDtw.txt trace of this to see what happened.
The "Cisco does not recognize the hookflash" issues on your system are being dealt with in this thread: http://voiceguide.com/forums/index.php?showtopic=3194
Please place all posts regarding that issue in the abovementioned thread only.
(as we mentioned already here: http://voiceguide.com/forums/index.php?showtopic=3270)
Hello!
Here I send you this file. I´ll continue in the other threads as you suggest.
Thank you!
jose
1006tw.txt
Trace shows that call was disconnected to Loop Current Drop - confirming that this is the main cause of problems with this system.
You can tell its caused by Loop Current Drop from these entries in trace:
We can see that Loop current seems to be going up and down on this system all the time:
173642.187 002 ev    TDX_CST (CST Event Received)
173642.187 002 ev    TDX_CST DE_LCON data=7577
173642.187 002 ev    TDX_CST DE_LCOF data=1
173642.281 002 ev    TDX_CST (CST Event Received)
173642.281 002 ev    TDX_CST DE_LCON data=9
173642.296 002 ev    TDX_CST (CST Event Received)
173642.296 002 ev    TDX_CST DE_LCOF data=1
173642.390 002 ev    TDX_CST (CST Event Received)
173642.390 002 ev    TDX_CST DE_LCON data=10
173642.421 002 ev    TDX_CST (CST Event Received)
173642.421 002 ev    TDX_CST DE_LCOF data=2
173642.515 002 ev    TDX_CST (CST Event Received)
173642.515 002 ev    TDX_CST DE_LCON data=10
173642.515 002 ev    TDX_CST DE_LCOF data=1
173642.625 002 ev    TDX_CST (CST Event Received)
173642.625 002 ev    TDX_CST DE_LCON data=10
173642.625 002 ev    TDX_CST DE_LCOF data=1
173642.734 002 ev    TDX_CST (CST Event Received)
173642.734 002 ev    TDX_CST DE_LCON data=10
173642.734 002 ev    TDX_CST DE_LCOF data=1
173642.828 002 ev    TDX_CST (CST Event Received)
173642.828 002 ev    TDX_CST DE_LCON data=9
173642.843 002 ev    TDX_CST (CST Event Received)
173642.843 002 ev    TDX_CST DE_LCOF data=2
173642.937 002 ev    TDX_CST (CST Event Received)
173642.937 002 ev    TDX_CST DE_LCON data=9
173642.953 002 ev    TDX_CST (CST Event Received)
173642.953 002 ev    TDX_CST DE_LCOF data=1
173643.046 002 ev    TDX_CST (CST Event Received)
173643.046 002 ev    TDX_CST DE_LCON data=10
173643.078 002 ev    TDX_CST (CST Event Received)
173643.078 002 ev    TDX_CST DE_LCOF data=2
173643.171 002 ev    TDX_CST (CST Event Received)
173643.171 002 ev    TDX_CST DE_LCON data=10
173643.187 002 ev    TDX_CST (CST Event Received)
173643.187 002 ev    TDX_CST DE_LCOF data=1
Looks like this is done by the Cisco as we see this pattern a number of times throughout the trace.
Have you looked into Cisco's configuration? This is something you should be able to control from Cisco's side.
Have you tried using the ktTelControl_LC_OFF_disabled.zip OCX we posted a week ago in this thread?
Is there a pattern to how other this problems happens - some calls must be answered OK as you are posting about problems with call transfers later in the script as well..
Hello!
Yes, I did. The problem with this new OCX file is that voiceguide never hangs up becuase I think that voiceguide ignores or doesn´t detect when the caller hangs up the phone.
You were rigth about my Cisco equipment. It looks like they have a serious problem. I´ve been testing to make a transfer call with a phone and I couldn´t. The PAP2 ignores completely the hookflash tone. I am going to do a little more research about this.
In the mean time, if you come up with something, please let me know.
Thank you very much for your help!
jose
Yes, I did. The problem with this new OCX file is that voiceguide never hangs up becuase I think that voiceguide ignores or doesn’t detect when the caller hangs up the phone.
If the tone detection is set up correctly then the hangup/disconnect tone will be detected and then VoiceGuide will hangup the call then.
VoiceGuide will also hangup after timing out awaiting user input etc.
