Guest vgfan Report post Posted 10/08/2005 06:49 AM I have updated my ISDN platforms to 6.0.2224 about mid-sept, and as a regular check, I realize the version has been updated to 6.0.2275 already around late sept. However, I find that the history.txt is just updated to version 2214. Hence, may I ask if the history.txt could be updated, or could you give a quick summary here of the changes between 2214 to 2275 (from the big version difference, it seems that a lot of improvements have been made). I need the info to decide if I want to do the upgrade now to take the benefits on the improvements. Please appreciate that on every upgrade, we would need to do quite some testing. I have learned a hard way that I cannot be lazy and take too many assumptions with updated versions ... though of course, I welcome and thank you for all hard work with the updates to make vg more and more 'perfect' Cheers, Share this post Link to post
SupportTeam Report post Posted 10/10/2005 08:53 AM 6.0.2276 - Fixed bug which was stopping custom defined tones from being reportd correctly - Allowed all of the Dialogic's DTMF dialing options to be used without using a pause character first (Options: T, P, M, L, I, X) 6.0.2275 - Distinctive Ring detection added. - Some changes made to the tags used thoughout the Config.xml and LineConfig.xml files. Share this post Link to post
