Dialogic Inconsistancy
We are atttempting to dial out, sometimes the script executes before the telephone has answered. When we have this early answer, the live person script runs. The phone is still ringing when our outbound message is playing. Enclosed are two traces the first worked the second failed. Same phone number minutes apart.
Using a dialogic d4/pciu version SR5.1.1 DNA5 build 30 Service pack 1 with the pciu update.
Voice guide version 6.0.2277
Can anyone help?
Successful outbound dial trace
094441.92 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
094441.92 0 dial callque insert tel:2318860 scr:c:\Our Software\test\HumanMessage.vgs time:510120944 esc:ErrorError
094441.94 0 dial DialListParseInputXML no <PhoneNumber>
094441.94 0 Loaded 1 entries.
094442.94 1 dial [196,2318860,510120944,0,2359,MoTuWeThFrSaSu,[,dxxxB1C1,],1,,c:\Our Software\test\HumanMessage.vgs,c:\Our Software\test\AMMessage.vgs,[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[
ppointmentDateTime]{10011030},AllowTransfer]{Yes},240,2,1,ErrorError,ErrorError] (search started at 094442.94)
094442.95 1 dial DialOnLine start tel[2318860] ann[] vgs[c:\Our Software\test\HumanMessage.vgs] am[c:\Our Software\test\AMMessage.vgs] rv[[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[AppointmentDateT
me]{10011030},AllowTransfer]{Yes}]
094442.95 0 dial callque update id=196: NextCallTime=0510120946, RetriesLeft=1
094442.97 0 dial callque DB update returned (MSAccess)
094442.97 1 rv clear all
094442.98 1 rv add [DrName]{Williams}
094442.98 1 rv add [Clinic]{5012551425}
094443.00 1 rv add [PatientName]{John}
094443.02 1 rv add [AppointmentDateTime]{10011030}
094443.02 1 rv add [OutDial_RetriesLeft]{2}
094443.03 1 dial making call tel[2318860] ann[] vgs[c:\Our Software\test\HumanMessage.vgs] am[c:\Our Software\test\AMMessage.vgs] OnHangup[] rv[[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[AppointmentDateT
me]{10011030},AllowTransfer]{Yes}[OutDial_RetriesLeft]{2}]
094443.05 1 script interpretor: VgMulti v6.0.2277
094443.05 1 state Dialing 2318860
094443.06 1 lineMakeCall=>[]
094443.08 1 timer set 240 EV_TIMEOUT_MAKECALL_NORESPONSE
094443.61 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
094443.64 1 event ScriptEventCode TDX_SETHOOK, code=135, state=5200
094443.66 1 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
094516.89 1 tw DialogicEvent 133,TDX_CALLP,10,4,0,TDX_CALLP,CR_CNCT,CON_PAMD
094516.92 1 event ScriptEventCode AM, code=133, state=5200
094516.94 1 LsWaitAfterDialingOut : 133,AM,10,4,0,CR_CNCT,CON_PAMD,
094516.95 1 event ScriptEventCode CONNECT, code=133, state=5200
094516.97 1 LsWaitAfterDialingOut : 133,CONNECT,10,4,0,CR_CNCT,CON_PAMD,
094516.98 1 event ScriptEventCode CON_PAMD, code=133, state=5200
094517.00 1 LsWaitAfterDialingOut : 133,CON_PAMD,10,4,0,CR_CNCT,CON_PAMD,
094517.02 1 event ScriptEventCode CR_CNCT, code=133, state=5200
094517.03 1 LsWaitAfterDialingOut : 133,CR_CNCT,10,4,0,CON_PAMD,,
094517.06 1 event ScriptEventCode TDX_CALLP, code=133, state=5200
094517.08 1 LsWaitAfterDialingOut : 133,TDX_CALLP,10,4,0,CR_CNCT,CON_PAMD,
094517.09 1 StartPlayingAnsweringMachineMessage hCall=518656, params=10,4,0
094517.11 0 dial callque delete id=196 (MSAccess)
094517.14 1 rvns add [OutDial_Result]{Contacted_AM}
094517.16 1 set LineState().hCall = 518656 in StartPlayingAnsweringMachineMessage
094517.17 1 state AM - wait for end of welcome message...
094517.19 1 dial awaiting end of answering machine message (lvl:10 for 20)
094517.20 1 RecSoundStart [C:\Program Files\VoiceGuide\data\RecAm_1.wav] ok
094517.23 1 timer set 120 EV_TIMEOUT_HANGUP
094517.25 1 tw DialogicEvent 134,TDX_CST,21260,0,0,DE_LCON,,
094517.27 1 event ScriptEventCode TDX_CST, code=134, state=1152
094517.28 1 LsDialoutRecAnswerMachineWelcMsg EV_UNKNOWN_134
094524.52 1 event ScriptEventCode EV_SILENCE_DETECTED, code=9300, state=1152
094524.53 1 LsDialoutRecAnswerMachineWelcMsg EV_SILENCE_DETECTED
094524.55 1 rec RecSoundStop ok
094524.56 1 rv rec length: AmWelcMsg_RecLen100ms = 74
094524.58 1 rv add [AmWelcMsg_RecLen100ms]{74}
094524.59 1 timer set 1 EV_REC_FINISHED
094524.61 1 tw DialogicEvent 130,TDX_RECORD,0,0,0,TM_MAXSIL,,
094524.63 1 event ScriptEventCode TDX_RECORD, code=130, state=1152
094524.64 1 LsDialoutRecAnswerMachineWelcMsg EV_UNKNOWN_130
094524.69 1 event ScriptEventCode EV_REC_FINISHED, code=8003, state=1152
094524.70 1 LsDialoutRecAnswerMachineWelcMsg EV_REC_FINISHED
094524.72 1 rv replace start: [$RV[AmWelcMsg_RecLen100ms]]
094524.73 1 rvns [PathSysVoice]{C:\Program Files\VoiceGuide\system\voice\}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[DrName]{Williams}[Clinic]{5012551425}[PatientName]{John}[AppointmentDateT
me]{10011030}[OutDial_RetriesLeft]{2}[OutDial_Result]{Contacted_AM}[AmWelcMsg_Re
Len100ms]{74}
094524.77 1 rv replace end: [74]
094524.78 1 state Run Answer Machine script [c:\Our Software\test\AMMessage.vgs]
094524.81 1 tr NewVgsVgm_Goto c:\Our Software\test\AMMessage.vgs,,,,,0
094524.83 1 rv add [scriptEnd_Time]{10/12/2005 9:45:24 AM}
094524.84 1 rv add [scriptEnd_Goto_Script]{c:\Our Software\test\AMMessage.vgs}
094524.86 1 rv add [scriptEnd_Goto_Module]{}
094524.88 1 rv add [scriptStart_Time]{10/12/2005 9:45:24 AM}
094524.91 1 rv add [scriptStart_CalledFrom_Module]{Hangup the Call 34}
094524.92 1 FindFullPathToScript_VgsOrVgp start [c:\Our Software\test\AMMessage.vgs]
094524.94 1 FindFullPathToScript_VgsOrVgp 1
094524.95 0 load start [c:\Our Software\test\AMMessage.vgs]
094524.97 0 MemStructVgs_ClearVgs [3]
094525.00 0 load end
094525.02 1 loaded [c:\Our Software\test\AMMessage.vgs] into:3
094525.03 1 rvns add [scriptsPath]{c:\Our Software\test\}
094525.05 1 StartModuleDefault=[AMMessage]
094525.06 2 tr NewVgsVgm_Goto 1
094525.08 2 tr NewVgsVgm_Goto 2
094525.09 1 fn RunModule start
094525.11 1 timer clear
094525.13 1 Play Module start
094525.14 1 state [AMMessage] Playing
094525.16 1 state [AMMessage] Playing (C:\test\MessageForAAnsweringMachine.wav)
094525.17 1 tw ConvertWav2Vox c:\Our Software\test\MessageForAAnsweringMachine.wav
094525.19 1 timer clear
094525.20 2 tr NewVgsVgm_Goto end
094525.23 1 tw wav->vox convert end 526734,c:\Our Software\test\MessageForAAnsweringMachine.vox,1,0,,
094525.25 1 play start ok, lPlayId=526812
094527.72 1 tw PlayEnd 1 526812
094527.73 1 play end id=526812, (current ID)
094527.75 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
094527.77 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
094527.80 1 path {EV_PLAY_FINISHED} not found
094527.81 1 timer set 10 EV_TIMEOUT_HANGUP
094527.83 1 timer set 0 EV_TIMEOUT_GOTOMODULE
094527.84 1 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
094527.86 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
094527.88 1 path {EV_TIMEOUT_GOTOMODULE} not found
094527.89 1 fn RunModule start
094527.91 1 tw DialogicEvent 129,TDX_PLAY,526812,0,0,,,
094527.92 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
094527.94 1 timer clear
094527.95 1 rv add [Hangup Time]{10/12/2005 9:45:27 AM}
094527.97 1 state Hanging up call... [Hangup Module]
094527.98 1 HangupCall_Common hCall=518656
094528.00 1 rec RecSoundStop ok
094528.02 1 play PlaySoundStop ok
094528.03 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094528.05 1 fnHangupCall end
094528.09 1 event callstate IDLE 1 1,0,0
094528.11 1 WorkingMode@Idle=
094528.13 1 timer clear
094528.14 1 rec RecSoundStop ok
094528.16 1 play PlaySoundStop ok
094528.17 1 rv add [CallEndTime]{10/12/2005 9:45:28 AM}
094528.19 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094528.20 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094528.22 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
094528.25 1 LsAwaitingCalls EV_UNKNOWN_135
094529.25 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
094529.27 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
094529.28 1 init atidle reinit : start
094529.30 1 init atidle reinit iConferenceOtherLegLid=-1
094529.31 1 init atidle reinit : reset all LineState variables
094529.31 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094529.33 1 state Waiting for a call...
094529.67 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094529.69 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
Unsuccessful outbound trace
094723.66 0 Loading from C:\Program Files\VoiceGuide\data\OutDial_New.xml
094723.67 0 dial callque insert tel:2318860 scr:c:\Our Software\test\HumanMessage.vgs time:510120947 esc:ErrorError
094723.69 0 dial DialListParseInputXML no <PhoneNumber>
094723.69 0 Loaded 1 entries.
094724.69 1 dial [198,2318860,510120947,0,2359,MoTuWeThFrSaSu,[,dxxxB1C1,],1,,c:\Our Software\test\HumanMessage.vgs,c:\Our Software\test\AMMessage.vgs,[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[
ppointmentDateTime]{10011030},AllowTransfer]{Yes},240,2,1,ErrorError,ErrorError] (search started at 094724.69)
094724.70 1 dial DialOnLine start tel[2318860] ann[] vgs[c:\Our Software\test\HumanMessage.vgs] am[c:\Our Software\test\AMMessage.vgs] rv[[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[AppointmentDateT
094724.72 0 dial callque update id=198: NextCallTime=0510120949, RetriesLeft=1
094724.73 0 dial callque DB update returned (MSAccess)
094724.73 1 rv clear all
094724.77 1 rv add [DrName]{Williams}
094724.78 1 rv add [Clinic]{5012551425}
094724.80 1 rv add [PatientName]{John}
094724.81 1 rv add [AppointmentDateTime]{10011030}
094724.83 1 rv add [OutDial_RetriesLeft]{2}
094724.84 1 dial making call tel[2318860] ann[] vgs[c:\Our Software\test\HumanMessage.vgs] am[c:\Our Software\test\AMMessage.vgs] OnHangup[] rv[[DrName]{Williams},[Clinic]{5012551425},[PatientName]{John},[AppointmentDateT
094724.86 1 script interpretor: VgMulti v6.0.2277
094724.89 1 state Dialing 2318860
094724.91 1 lineMakeCall=>[]
094724.92 1 timer set 240 EV_TIMEOUT_MAKECALL_NORESPONSE
094725.44 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
094725.45 1 event ScriptEventCode TDX_SETHOOK, code=135, state=5200
094725.47 1 LsWaitAfterDialingOut : 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_OUTBOUND,
094725.58 1 tw DialogicEvent 134,TDX_CST,1622,0,0,DE_LCON,,
094725.59 1 event ScriptEventCode TDX_CST, code=134, state=5200
094725.61 1 LsWaitAfterDialingOut : 134,TDX_CST,1622,0,0,DE_LCON,,
094747.19 1 tw DialogicEvent 133,TDX_CALLP,9,0,0,CR_NORB,,
094747.20 1 event ScriptEventCode NORINGBACK, code=133, state=5200
094747.22 1 LsWaitAfterDialingOut : 133,NORINGBACK,9,0,0,CR_NORB,,
094747.23 1 event ScriptEventCode CR_NORB, code=133, state=5200
094747.25 1 LsWaitAfterDialingOut : 133,CR_NORB,9,0,0,,,
094747.27 1 event ScriptEventCode TDX_CALLP, code=133, state=5200
094747.28 1 LsWaitAfterDialingOut : 133,TDX_CALLP,9,0,0,CR_NORB,,
094747.30 1 LineEvCallState_OutgoingCallWasAnswered 9,0,0
094747.31 1 init OnCallAnswered_StartScript start
094747.33 1 init StartLoadedVgs_InitLineState start
094747.34 1 rv add [$RV_STARTTIME]{10/12/2005 9:47:47 AM}
094747.36 1 rv add [$RV_DEVICEID]{1}
094747.39 1 rv add [$RV_CIDNAME]{}
094747.41 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
094747.42 1 WARN rv ScriptsPath could not be set as LineState(iLineId).iVgsIdx = 0 in StartLoadedVgs_InitLineState
094747.44 1 rv add [$RV_CALLEDNUMBER]{2318860}
094747.45 1 set LineState().hCall = 668859 in OnCallAnswered_StartScript
094747.47 0 dial callque delete id=198 (MSAccess)
094747.48 1 rvns add [OutDial_Result]{Contacted_Human}
094747.50 1 state live person answered. start [c:\Our Software\test\HumanMessage.vgs]
094747.52 1 tr NewVgsVgm_Goto c:\Our Software\test\HumanMessage.vgs,,,,,0
094747.53 1 rv add [scriptEnd_Time]{10/12/2005 9:47:47 AM}
094747.55 1 rv add [scriptEnd_Goto_Script]{c:\Our Software\test\HumanMessage.vgs}
094747.56 1 rv add [scriptEnd_Goto_Module]{}
094747.58 1 rv add [scriptStart_Time]{10/12/2005 9:47:47 AM}
094747.59 1 rv add [scriptStart_CalledFrom_Module]{Hangup the Call 16}
094747.61 1 FindFullPathToScript_VgsOrVgp start [c:\Our Software\test\HumanMessage.vgs]
094747.63 1 FindFullPathToScript_VgsOrVgp 1
094747.64 0 LoadedVgs_Find c:\Our Software\test\HumanMessage.vgs at idx=2
094747.66 1 rvns add [scriptsPath]{C:\Our Software\test\}
094747.67 1 StartModuleDefault=[HumanMessage]
094747.69 2 tr NewVgsVgm_Goto 1
094747.70 2 tr NewVgsVgm_Goto 2
094747.72 1 fn RunModule start
094747.73 1 timer clear
094747.75 1 Play Module start
094747.78 1 state [HumanMessage] Playing
094747.78 1 state [HumanMessage] Playing (C:\test\MessageForAHuman.wav)
094747.81 1 tw ConvertWav2Vox C:\Our Software\test\MessageForAHuman.wav
094747.84 1 timer clear
094747.86 2 tr NewVgsVgm_Goto end
094747.94 1 tw wav->vox convert end 669375,C:\Our Software\test\MessageForAHuman.vox,1,0,,
094747.95 1 play start ok, lPlayId=669515
094750.66 1 tw PlayEnd 1 669515
094750.66 1 play end id=669515, (current ID)
094750.67 1 event ScriptEventCode EV_PLAY_FINISHED, code=8001, state=1100
094750.69 1 LsPlayMsg EV_PLAY_FINISHED,EV_PLAY_FINISHED
094750.70 1 path {EV_PLAY_FINISHED} not found
094750.72 1 timer set 10 EV_TIMEOUT_HANGUP
094750.73 1 timer set 0 EV_TIMEOUT_GOTOMODULE
094750.77 1 event ScriptEventCode EV_TIMEOUT_GOTOMODULE, code=9002, state=1101
094750.78 1 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE,EV_TIMEOUT_GOTOMODULE
094750.78 1 path {EV_TIMEOUT_GOTOMODULE} not found
094750.80 1 fn RunModule start
094750.83 1 tw DialogicEvent 129,TDX_PLAY,669515,0,0,,,
094750.83 1 event ScriptEventCode TDX_PLAY, code=129, state=6001
094750.84 1 timer clear
094750.86 1 rv add [Hangup Time]{10/12/2005 9:47:50 AM}
094750.88 1 state Hanging up call... [Hangup Module]
094750.89 1 HangupCall_Common hCall=668859
094750.91 1 rec RecSoundStop ok
094750.92 1 play PlaySoundStop ok
094750.94 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094750.95 1 fnHangupCall end
094751.00 1 event callstate IDLE 1 1,0,0
094751.02 1 WorkingMode@Idle=
094751.03 1 timer clear
094751.05 1 rec RecSoundStop ok
094751.05 1 play PlaySoundStop ok
094751.06 1 rv add [CallEndTime]{10/12/2005 9:47:51 AM}
094751.08 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094751.09 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094751.11 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
094751.13 1 LsAwaitingCalls EV_UNKNOWN_135
094752.13 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
094752.14 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
094752.16 1 init atidle reinit : start
094752.16 1 init atidle reinit iConferenceOtherLegLid=-1
094752.17 1 init atidle reinit : reset all LineState variables
094752.19 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094752.20 1 state Waiting for a call...
094752.55 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094752.56 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
094811.27 1 event callstate OFFERING 1 2,0,0
094811.30 1 script interpretor: VgMulti v6.0.2277
094811.31 1 fired OFFERING event to listeners
094811.33 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
094811.34 1 iIvrDev=1
094811.36 1 set linestate CID vars
094811.38 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
094811.39 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
094811.41 1 tw ring 1
094811.42 1 ring time since last ring event (sec): 0.00
094811.44 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
094811.45 1 rv clear all
094811.47 1 init LineState ResetAtStartOfNewCall.
094811.48 1 answer the call
094811.50 1 timer clear
094811.52 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
094811.53 1 event ScriptEventCode TDX_CST, code=134, state=6001
094812.13 1 event callstate CONNECTED 1 256,0,0
094812.14 1 LineEvCallState_Connected hDevice=1 params=256,0,0
094812.16 1 WorkingModes tapi= script= LineState().iState=6001
094812.19 1 Inband detection not enabled
094812.20 1 StartLoadedVgs at 10/12/2005 9:48:12 AM [VgMulti v6.0.2277]
094812.22 1 set LineState().iVgsIdx=1
094812.23 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
094812.25 1 init StartLoadedVgs_InitLineState start
094812.27 1 rv add [$RV_STARTTIME]{10/12/2005 9:48:12 AM}
094812.28 1 rv add [$RV_DEVICEID]{1}
094812.30 1 rv add [$RV_CIDNAME]{}
094812.31 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
094812.33 1 rvns add [scriptsPath]{C:\Our Software\test\}
094812.34 1 rv add [$RV_CIDNUMBER]{}
094812.36 1 fn RunModule start
094812.38 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
094812.41 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
094812.42 1 tw DialogicEvent 134,TDX_CST,2113,0,0,DE_LCON,,
094812.44 1 event ScriptEventCode TDX_CST, code=134, state=6001
094812.45 1 timer clear
094812.47 1 rv add [Hangup Time]{10/12/2005 9:48:12 AM}
094812.48 1 state Hanging up call... [Hangup Module]
094812.50 1 HangupCall_Common hCall=1
094812.52 1 rec RecSoundStop ok
094812.53 1 play PlaySoundStop ok
094812.56 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094812.58 1 fnHangupCall end
094814.09 1 event callstate IDLE 1 1,0,0
094814.11 1 WorkingMode@Idle=
094814.13 1 timer clear
094814.14 1 rec RecSoundStop ok
094814.16 1 play PlaySoundStop ok
094814.17 1 rv add [CallEndTime]{10/12/2005 9:48:14 AM}
094814.19 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094814.20 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094814.22 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
094814.23 1 LsAwaitingCalls EV_UNKNOWN_135
094815.23 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
094815.23 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
094815.25 1 init atidle reinit : start
094815.27 1 init atidle reinit iConferenceOtherLegLid=-1
094815.28 1 init atidle reinit : reset all LineState variables
094815.30 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094815.31 1 state Waiting for a call...
094815.66 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094815.67 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
094820.48 1 event callstate OFFERING 1 2,0,0
094820.50 1 script interpretor: VgMulti v6.0.2277
094820.52 1 fired OFFERING event to listeners
094820.53 1 set LineState().hCall = 1 in LINECALLSTATE_OFFERING
094820.55 1 iIvrDev=1
094820.56 1 set linestate CID vars
094820.58 1 call AnswerTheCallIfAllowed from LINECALLSTATE_OFFERING
094820.59 1 rings=0, min rings before answer=0 (iCallerIdHasArrived=0)
094820.61 1 tw ring 1
094820.63 1 ring time since last ring event (sec): 0.00
094820.64 1 rings=1, min rings before answer=0 (iCallerIdHasArrived=0)
094820.66 1 rv clear all
094820.66 1 init LineState ResetAtStartOfNewCall.
094820.67 1 answer the call
094820.69 1 timer clear
094820.72 1 tw DialogicEvent 134,TDX_CST,0,0,0,DE_RINGS,ET_RON,
094820.73 1 event ScriptEventCode TDX_CST, code=134, state=6001
094821.33 1 event callstate CONNECTED 1 256,0,0
094821.34 1 LineEvCallState_Connected hDevice=1 params=256,0,0
094821.36 1 WorkingModes tapi= script= LineState().iState=6001
094821.38 1 Inband detection not enabled
094821.41 1 StartLoadedVgs at 10/12/2005 9:48:21 AM [VgMulti v6.0.2277]
094821.42 1 set LineState().iVgsIdx=1
094821.44 1 set sScriptToRunOnHangup=[] in StartLoadedVgs
094821.45 1 init StartLoadedVgs_InitLineState start
094821.47 1 rv add [$RV_STARTTIME]{10/12/2005 9:48:21 AM}
094821.48 1 rv add [$RV_DEVICEID]{1}
094821.50 1 rv add [$RV_CIDNAME]{}
094821.52 1 rvns add [PathApp]{C:\Program Files\VoiceGuide\}
094821.53 1 rvns add [scriptsPath]{C:\Our Software\test\}
094821.55 1 rv add [$RV_CIDNUMBER]{}
094821.56 1 fn RunModule start
094821.58 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_OFFHOOK,CALL_INBOUND,
094821.59 1 event ScriptEventCode TDX_SETHOOK, code=135, state=6001
094821.61 1 tw DialogicEvent 134,TDX_CST,723,0,0,DE_LCON,,
094821.64 1 event ScriptEventCode TDX_CST, code=134, state=6001
094821.66 1 timer clear
094821.67 1 rv add [Hangup Time]{10/12/2005 9:48:21 AM}
094821.69 1 state Hanging up call... [Hangup Module]
094821.70 1 HangupCall_Common hCall=1
094821.72 1 rec RecSoundStop ok
094821.73 1 play PlaySoundStop ok
094821.77 1 timer set 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
094821.78 1 fnHangupCall end
094823.30 1 event callstate IDLE 1 1,0,0
094823.31 1 WorkingMode@Idle=
094823.33 1 timer clear
094823.34 1 rec RecSoundStop ok
094823.36 1 play PlaySoundStop ok
094823.38 1 rv add [CallEndTime]{10/12/2005 9:48:23 AM}
094823.39 1 timer set 1 EV_TIMEOUT_TIMETOREINITLINE
094823.41 1 tw DialogicEvent 135,TDX_SETHOOK,0,0,0,DX_ONHOOK,,
094823.42 1 event ScriptEventCode TDX_SETHOOK, code=135, state=900
094823.44 1 LsAwaitingCalls EV_UNKNOWN_135
094824.44 1 timer fired EV_TIMEOUT_TIMETOREINITLINE
094824.45 1 event ScriptEventCode EV_TIMEOUT_TIMETOREINITLINE, code=9008, state=900
094824.47 1 init atidle reinit : start
094824.48 1 init atidle reinit iConferenceOtherLegLid=-1
094824.48 1 init atidle reinit : reset all LineState variables
094824.50 1 timer set 0.3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
094824.52 1 state Waiting for a call...
094824.86 1 timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
094824.88 1 event ScriptEventCode EV_TIMEOUT_ATERIDLE_ALLOWOUT, code=9013, state=900
In the second trace the call was connected as the Dialogic card informed VoiceGuide that on the outgoing call it has never detected any Ringbacks:
You may want to modify the Ringback tone definitions in ConfigLine.xml file to better match the ringbacks played on the line when the number is dialed.
(digital T1 ISDN lines do not have such problems)
